E36 (1991 - 1999)
Old 06-18-2012, 04:22 PM
renogt renogt is offline
Mein Auto: BMW 318 convertible
Post Bimmer ABS and Auto Transmission problems :(
318 P Reg 1997 Auto, ABS fault code has come on and I have had machine on it and error code 71 Pump Motor is shown but does not delete code when trying to erase fault.
Can someone kindly direct me to this pump motor and tell me why this is possibly happening?.
Other fault is that the revs climb up but car doesn't move in drive and when I use the 1st 2nd and 3rd its a little better but Drive is sloppy!
Thank you
Old 06-18-2012, 07:10 PM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
sounds like 2 different problems, as the abs is related to the brakes.
as for the trans, i would check the fluid level and condition. fix as necessary.
if within specs, then it looks as if you would have some sort of issue with the trans. i'd look at taking it to a trans shop unless you can find a reman and are able to r&r yourself.
in which case, get some additional new related parts such as trans mounts, guibo, copper exhaust nuts, and exhaust hanger.
as to the abs motor, check the fuse. if it keeps blowing you may need to get a new (reman) unit. never rebuilt one as they tended to require specialty tools that i did not have access to, as well as a liability factor that the shop did not wish to entertain.
df
Old 06-19-2012, 10:29 AM
Hi there, checked the ABS fuse and this is okay, also checked the ABS Pump to find a small leak coming from one of the pipes so guessing this maybe the cause of the ABS fault!.
Still need to check the Trans for fluid level etc.
Regards
Old 06-24-2012, 03:25 PM
Okay Talked to an auto trans specialist and he told me to disconnect the ABS pump ECU connector plug off and the Automatic gearbox is now working perfectly fine :-/
This must mean that the ABS was causing the issue all along!
Old 06-26-2012, 12:20 PM
bmw-mania bmw-mania is offline
Mein Auto: BMW
Thanks for posting your solution!
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 06-26-2012, 01:24 PM
Okay don't know what's that reply all about above!.
I have now fitted the ABS pump and matching ecu and both transmission and abs system are working perfectly so don't know what's all this business about re set/programming I about!!!!!!!!
Guys no need to program early models unless it has a steering angle sensor!.
Old 06-26-2012, 02:18 PM
Mein Auto: BMW
What?
I was giving thanks.
What ECU matching for a ABS pump? eh.. Nevermind.
I have NO IDEA what you're referring to now..
Old 06-26-2012, 02:54 PM
I seen the thumbs up Lol
glad to be of help to anyone who has the same issues!.
Who were you raving on about up there?. Lol someone piss you off!?.
Basically used the abs ecu that came with used pump and it didn't need any resetting as abs error light has now gone and all working fine now so many thank for the advice and help gents well appreciated )
Old 06-26-2012, 02:57 PM
Mein Auto: BMW
was i raving.. (?)
I dont see a rant..
am I losing it?
Old 06-26-2012, 03:20 PM
This is what i was on about lol
Must be someone else ;-)
Originally Posted by kaos_325i
Maybe I haven't been here long enough to realize the knowledge you have to share.
But, from all I can tell you are just an over opinionated, rude, prick.
My .02
Old 06-26-2012, 03:22 PM
Mein Auto: BMW
OH.. Buahahahaha..
That is my SIG.
Old 06-26-2012, 03:26 PM
Pmslol hahahaha hahahahahahahaha my bad :-D
It said quote lol
Old 06-26-2012, 03:30 PM
Mein Auto: BMW
LOL...
Thanks for the laughs!
Old 06-26-2012, 03:34 PM
No probs mate, all in an evenings work lol
At least your not like some of the idiots on the Audi TT forum. Half of them talk **** and the rest think they know it all bar a few decent sensible guys.
Old 06-26-2012, 03:41 PM
Mein Auto: BMW
Aside from a few fellas that know their sh!t on here.. Its about the same
Old 06-26-2012, 03:43 PM
Well such is life and glad there are a few guys hat are okay lol
Im off to Zzzz now so catch you later.
