E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Angel eyes for an E30?
Hello everyone, I have had my 1987 325IS for a couple years now, and I've been wanting to put those stunning HD Angel eyes on my car. The only thing holding me back is that some friends of mine at a BMW tuning company said that a lot of cars that have these lights come back because of electronic and wiring issues. Should I get these lights? If so, where and for how much? Thanks for any help!
no, you should not get them ... ever.
they are pure ricer. they take a classy old bmw and make it look like a cheap piece of crap. Don't ruin your car.
if you want to lead the orchestra, you must turn your back on the crowd ![]() build: http://www.bimmerfest.com/forums/sho...d.php?t=382667 |
You can always make your own as long as you're mechanically inclined
Sent from my N860 using Bimmer App
ALPHA SQAUD SPEED STARS ELITE THE_EXPANSION_TEAM |
if they are installed correctly, which is more often than not by doing the exact opposite of the lost in translation chinese instructions, there is no reason why they should mess with the electrics.
that said, E30s have very tempremental wiring systems to start with, they are perfect as is, but even an aftermarket stereo can cause your indicators to come on when you press the window button etc if not wired correctly I wont bring up my taste preferences
I installed the Hella h11 lenses on my 85, then put a relayed HID setup in the Hella's. Looks great, but get a low beam failure light on my control center. I know there's a way to get by that but never bothered me. ( My opinion is do what you want, I don't like the angel eyes only because takes away from the vintageness... although HID's aren't normally a option either lol.)
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
Spend your money on something else.
WTB: Minty Seat Belt Receptacles - Front |
imo they don't look good on E30's apart from spoiling the originality of the front end
they would just sit out in the open. I'm sure you realise that all modern bimmers have a lens cover over the headlight unit which in turn would protect angel eyes. Leave as stock or upgrade to Smileys or even HID's.
Thanks everyone for your help! I think you guys are likely correct, I'll do some other things to my car instead. I would greatly appreciate even more help with the other threads I will post as those are likely what the money will be spent on instead.
While I agree that angel eyes take away from the look of the e30 I'd like to say if YOU want angel eyes on YOUR car then by all means don't let someone else rain on your parade. That being said and seeing your decision to spend elsewhere, here is my quick thought on the thread...
A short shift kit (if you have a manual) would be a good use of the angel eye money imho
Bilstien PSS9's / SPC Rear Control Arms / DDM Smoked Corners, Sides, Tails / K&N FIPK2 / CXRacing All Aluminum Radiator w Aluminum Shroud and Electric Fan / Stewart Components Waterpump / Aluminum Tstat Housing / SamcoSport Coolant Hoses / Fan Delete Mod - 14" Electric Pull Fan / UBERGROUND Battery Cable / NGK Ir.IX Plugs / Royal Purple Fluids for; Engine, Differential, Transmission, Power Steering. . ![]() ![]() ![]() MEMBER OF THE MOST EXCLUSIVE SECRET CLUB ON THE 'FEST |
AE's on E30's look like poo, plain and simple. Especially the ebay headlights with them. They look way small and just goofy on an E30 front and go around a full circle.
I have seen AE's on ONE E30 that looked OK, and he had raptors tucked behind hella headlight protectors. With the upper cut off it looked better, the HID fogs helped too I suppose.
Stve always got somthingbad to say i made a pair i didnt do a good job but yea u can find some ppl on craigslist make tgem for cheap u can make them only hing i say is make sure u buy nice leds so they look like the new bmws
Spelling owns you!
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
