Old 06-19-2012, 04:51 PM
DaveBZ3 DaveBZ3 is offline
Mein Auto: Z3
Hidden Garage Door Opener
I was tired of my garage door opener being in my console and always having to hide it when I go into a store. Attached is a pic of my completed project. I soldered a couple of pieces of bell wire to the switch on the opener, then to a switch from Radio Shack. The opener is hidden under the second cup holder, which is shorter than the first and therefore there's about an inch of space under it.
To replace the battery all I have to do is remove the single screw in the back of the console. The opener is taped to the console so it all comes out as a single unit. I have not noticed any reduction in range.
The only problem I had is that my soldering abilities have not improved since high school shop!
Name:	Garage Door Opener.jpg
Old 06-19-2012, 08:58 PM
carprep carprep is offline
Chuck
Mein Auto: 1997 Z3 Roadster 2.8
I just put Velcro on my opener and stuck it to the side of the transmission tunnel along with my Fastrak transponder.
Cheers!!
Old 06-20-2012, 01:15 AM
FZbar FZbar is offline
Mein Auto: 2002 Z3 2.5 Roadster
Similar Solution
I did something similar. I used a momentary contact switch mounted in one of the free knock out switch covers connected to the transmitter underneath the center console. I did have to solder two connections in the transmitter in parallel to the transmitter mounted switch. I rarely have to replace batteries.
It's been working on my 2002 Z3 roadster since it was new.
A very worthwhile addition.
Fred
Old 06-20-2012, 05:56 AM
STIHLBOLTS STIHLBOLTS is online now
Hat's On, Tops Down!
Mein Auto: 2008 Z4MR
I guess I was the only one that got a garage door opener with a visor clip? It stays up there all time, no one sees it. What a country.
Regards
2008 Z4M Roadster
BMWCCA/ZSCCA Member
Old 06-20-2012, 06:16 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
UGDO/Homelink
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 06-20-2012, 07:38 AM
zkeeper zkeeper is offline
Mein Auto: 08 Z4 3.0si,11 128Msport
Velcroed mine to underneath side of steering column. It is a small unit, rounded at corners so that worked great. Always there, easy to touch button, hidden and can release it for batts, anytime needed.
Old 06-20-2012, 02:47 PM
TommyZ3 TommyZ3 is offline
Mein Auto: 2002 Z3 3.0i
Here is mine.
I Velcroed the transmitter just under the left lower portion of the dash next the steering column. Did the same thing for wife's Camry. I love tinker and solder.
TommyZ3
2002 3.0i
Sterling Gray/Black/Black
Dinan Strut Brace
No CDV
Whalen Shift Machine
Centric Posi Quiet Ceramic Brake Pads
In-Dash Garage Door Opener
DIY Clutch Stop
Old 06-21-2012, 05:42 AM
Prinz Eugen Prinz Eugen is online now
Mein Auto: 2002 Z3 M
I also have a garage door opener with a visor clip, no problems yet
Old 06-21-2012, 06:57 PM
BlackjackM BlackjackM is offline
Mein Auto: '01 Z3.0 R; '10 MB C300
Fred
This is what I did. Less than $10>$$$$UGDO/HL
Old 06-21-2012, 07:14 PM
KevinC's Avatar
KevinC KevinC is offline
your average JAMF
Mein Auto: '07 Z4MC,'05 330Ci ZHP
Kevin C.
Chandler, AZ
'07 Z4M Coupe ..LL93707
'05 330Ci ZHP ..PD99819
Old 06-21-2012, 08:24 PM
Wheaton2010 Wheaton2010 is offline
Have Fun... Life is short
Mein Auto: 2006 BMW Z4 3.0si
I did the same. I used heavy-duty Velcro, the kind they give you to mount the tollway transponders. Works great!
