Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 06-19-2012, 09:00 PM
mod_junkie mod_junkie is offline
Mein Auto: E30
Anyone ever converted to 5 lug?
Anyone? Is it worth it to go 5 or stay 4? And i was wondering if the e36 suspension was compatible with the e30?
ALPHA SQAUD
SPEED STARS ELITE
THE_EXPANSION_TEAM
Old 06-19-2012, 10:56 PM
_Ethrty-Andy_'s Avatar
_Ethrty-Andy_ _Ethrty-Andy_ is online now
E34 Converted E30 Fanatic
its only worth it if you want to fit low offset 5 stud rims. you need E30 M3 parts to do it properly. It can be done with an E36 ti rear end whihc bolts right in but you need hub spacers, the front is a wee bit more complicated
Old 06-22-2012, 10:56 AM
M-technik-3 M-technik-3 is offline
Mein Auto: 5 E30's
E36 M3 front will bolt on provided you have late model E36 M3 control arms. Very few 16" wheels fit over E36 M3 brakes so be prepared to have 17's. The rear can be done Via Z3M rear or 318Ti as mentioned or E30 M3 setup.
Z3M is pricey as are the E30 M3 suspension setups.
There is a Z3M rear set up on 318Ti.org right now for $900 that is sans the diff but has supposedly all the other stuff you need. Ti suspension is cheap to come by but is limited to the smaller brakes unless you source aftermarket stuff.
Old 06-22-2012, 11:09 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
there is no reason to go 5 lug, stay 4 lug.
the main thing people are not telling you about the crappy e36 5 lug swap is that it completely changes your offsets.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 06-22-2012, 12:04 PM
Mein Auto: 5 E30's
I like my 5 lug set up but it's e30 M3 and it does help since I'm 24V with AA C38 stg II
Old 06-22-2012, 12:19 PM
fcsteve's Avatar
610EUROs
doesnt matter what motor or how much hp you are putting out. 4 lug is pefectly fine. you can buy big brakes for 4 lug just the same as 5 lug and 4 lugs can hold more hp than anyone can throw at it.
Old 06-22-2012, 08:22 PM
markseven markseven is offline
an audience of One
Mein Auto: BMW M Power
BMW went with 5-lug hubs on the M3, with all of its 190 HP, in order to run larger rotors and calipers (you knew that)... to gain the superior braking and fade resistance of a larger pad and swept area.
The only viable 4-lug BBK is the UUC unit, which is great, but I would run StopTech if I could. The other 4-lug BBKs use the adapter plate which introduces flex, which kinda negates the value of a monoblock caliper body.
WTB:
Minty Seat Belt Receptacles - Front
Old 06-22-2012, 08:48 PM
fcsteve's Avatar
610EUROs
there is literally thousands of people running the aluminum hat BBK's safely, from little hondas to 1000hp+ track vehicles. there is also plenty of 800+ hp cars running around on 4 lugs.
a proper e30 m3 5 lug swap is over $1500. for that money you can get a BBK and have a chunk of change left over to throw at some lightweight wheels or tires.
Old 06-22-2012, 08:59 PM
an audience of One
I wasn't referring to the hat.
You could run an 800HP car on drums all around, too.
WTB:
Old 06-22-2012, 09:03 PM
fcsteve's Avatar
610EUROs
i just used that to confirm we were talking about 2 piece rotors. thats what we are talking about, correct ?
i run 1200rwhp with no brakes
Old 06-22-2012, 09:11 PM
an audience of One
Two piece rotors are great. The flex I was talking about is in the adapter that allows BBK calipers to bolt to the 4-lug hub.
Parachutes FTW!
WTB:
Old 06-22-2012, 09:39 PM
fcsteve's Avatar
610EUROs
Parachutes FTW!
i know their older kit used factory wilwood calipers with an adapter plate, but doesn't their latest kit use a caliper specifically designed to bolt up to a 4 lug housing?
Old 06-22-2012, 10:27 PM
an audience of One
UUC is direct fit, the massives (Wilwood) et al are not.
WTB:
Old 06-22-2012, 11:32 PM
fcsteve's Avatar
610EUROs
sorry, i just looked up and you said that before. I'm in a confusing e30/super beetle/model A dilemma that has my mind running all over the place right now.
so to recap :
*don't go 5 lug*
-buy the UUC BBK if thats what you want
-if you are going 5 lug for wheels, buy one of the billion 4 lug wheel sets that are already out there.
sound good ?
Old 06-23-2012, 02:14 AM
Mein Auto: E30
So now that is answered lol is the e36 suspension compatible with the e30?
ALPHA SQAUD
SPEED STARS ELITE
THE_EXPANSION_TEAM
Old 06-23-2012, 06:37 AM
Mein Auto: 5 E30's
Parts of it are, the rear no except the brakes installed on a Z3 or Ti assembly.
Old 06-23-2012, 10:00 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Powerbrake now has a American subsidiary http://www.powerbrakeusa.com/ that will help you with whatever brake kit you need for your Bimmer- race or road.
Tell them http://www.nicksracing.com/ in Namibia sent you
Old 06-23-2012, 02:08 PM
Mein Auto: E30
I don't think you guys are following me are the front and rear shocks and springs compatible with the e30
ALPHA SQAUD
SPEED STARS ELITE
THE_EXPANSION_TEAM
Old 06-23-2012, 02:46 PM
Mein Auto: 5 E30's
If you are venturing down the E36 path only the front struts are but as mentioned you need the late model control arms from a 96-99 M3. The rear shocks are longer due to more travel the fronts are longer too but will work.
Old 06-23-2012, 03:35 PM
Mein Auto: E30
Thank you lol I feel like this thread went totally another direction.
ALPHA SQAUD
SPEED STARS ELITE
THE_EXPANSION_TEAM
Old 06-23-2012, 03:40 PM
an audience of One
No, I think it will help you decide whether or not a 5-lug is worth the time and money.
WTB:
Old 06-23-2012, 05:07 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 06-23-2012, 08:11 PM
an audience of One
Originally Posted by hornhospital View Post
Maybe just a little
WTB:
