7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code! |
Umnitza ICE angel eyes installed. No problem
I am not a guy that tinkers with my car but this was simple. 5 minutes total for install. Great customer service with tracking etc. Very prompt follow up with email(the install diagram was from them). Very nice. No errors
2011 740Li |
In shade/garage they all look great. Can you post a pic outside in sunlight?
F01 750i Daily driver E92 m3 Toy car D2 S8 Race/Toy car |
Image with hood up is driver side ICE , passenger side with OEM yellow. Other picture of one headlight is sun directly into front of car which is why the lighting is funky(iphone picture)
2011 740Li |
Looks good! So you have three resistors on each side?
2 on each side. All color coded so it took 5 minutes to figure out instructions and 5 minutes to install. The entire resistor string fits back into light housing without a problem. I really researched this and I believe this is the light with the easy install, no errors and good outcome. You tube video of the other systems spooked me because of the complex install
2011 740Li |
Thanks for the write up.
Join Our Facebook! - Check Out Photos, Talk to Customers, Ask Us Questions! ![]() Call US! 877 486 6489 Available: 9am-5pm M-F |
So which ones are these on the site? I'll give them a try.
these are the ICE VXX - with extra resistor.
these are the only ones we've tried that work with an extra resistor and doesn't cause errors.
What the difference between them and the Umnitza ICE V5 ?
V5 is half the output and will cause errors.
1. Do you have to connect cables to car's battery as I saw with other solutions?
2. Do you have to drill holes in caps? I am looking for a solution with easy install, without harming caps and as less cables as possible. |
PS: I asked about new VXX
All you do is take out the OEM bulb that"s there by a 1/2 turn and unplugging the connector(2 minutes) max. The new bulb screws in exactly like the original. All you do is plug in. The other side will take 2 minutes total because it is identical and you will be off the learning curve. 10 minutes total both sides no drilling no electric stuff.
2011 740Li |
Great! I am ordering it.
yes, install is very easy.
One more comment. I got the extra set of resistors and had a fault on one side. Lights work but I get a warning on the dash that right light is malfunctioned. Only when the car is out in heat over last few days. I installed a third set of resistors and today I'm good to go in 95+ degree weather
2011 740Li |
I cannot find separate resistor pack on their website. Do they have it? Did they recommend you install another third resistor?
They recommended an extra set but I used two
2011 740Li |
I mean where did you get it? When ordering vxx i can select only one extra set of resistors (as they recommend for f01). And I could not find resistor set for H8 on their website sold separately.
I just installed the Umnitza Angel Eyes on my 2012 750 Li, and, well, as you can see from the picture, its like the outside rings are barely even lighting up.
Per the post here, I bought the ones with the extra resistors. As others have said, the installation couldn't have been easier. However, I'm really disappointed at this point, as....like I said, the outside rings barely look like they have any light. (as an FYI), I just took that picture, and the day here is really overcast. No sun out shining) Even when I put them in last night, they weren't that bright at all. Compared to the other pictures I've seen, I'm wondering if there is something wrong with the ones I got. Will be calling Umnitza today. |
Like any light mine are dull in the direct sun light but yours do look different than mine. Any error codes? Did you try to install at different orientations?
2011 740Li |
![]() 2008 E63 M6 - Black Sapphire - Sepang Bronze Full Merino - Carbon Fiber Trim - Alcantera Headliner - SMG - HUD - Soft Close Doors - Comfort Access - Individual Audio w/Sat and HD Radio 2009 E92 335i - Black Sapphire - Black Dakota - Burl Walnut - Sport - Premium - Cold Weather - Navigation - L7 - Comfort Access - Smoker's Package Member: BMWCCA #471614 |
If you have advice on Specifically what I need to do, I would greatly appreciate it. |
I have seen many threads with issues like you have and I don't recall any that were related to faulty bulbs. If you have someone to stand in front of the car while you work the bulb around and tell you as it gets brighter.
#25
Anyway, back to work (which is quite disappointing, as I was hoping to be able to get out and get the Dinan Stage I installed today) Ughhhh
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
