Old 12-07-2012, 01:44 PM
BOMOW BOMOW is offline
Mein Auto: X5D
BMW X5 Diesels Recall: 2009-2012
Repost
Automobilemag
Recall Central: 2009-2012 BMW X5 Diesels, 2013 Ford Fusion Sedan
Written by: Evan McCausland [G+] on December 7 2012 5:00 AM
The Problem: The bolt used to secure the engine belt idler pulley could loosen over time and ultimately break. Should this happen, the belt could slip, cutting power assist to the steering rack. The effort needed to crank the steering wheel would be much greater than before, and, BMW fears, could "increase the risk of a crash." Additionally, the belt will no longer drive the alternator, triggering a rash of charging error messages in the instrument cluster.
The Fix: The bolt will be replaced and tightened with a new torque procedure, while its threads will be coated with thread lock.
Vehicles Affected: 29,800 2009-2012 X5 xDrive35d models, built between September 2008 and November 2012. As noted, this only applies to diesel X5 models fitted with the 3.0-liter twin-turbo diesel I-6.
Old 12-07-2012, 02:57 PM
the328's Avatar
the328 the328 is offline
Enjoying Your Money
Mein Auto: 2009 328i
No biggie, at least they're taking care of it BEFORE something bad happens. Props to BMW!
Old 12-07-2012, 03:26 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Actually, they are taking care of it because bad things have happened... that's how they found out.
