Old 06-26-2012, 11:46 AM
nevada458 nevada458 is offline
Mein Auto: 540i
Check Coolant warning after using the AC
On my 2000 540i, using the AC causes a "check coolant level" message. Coolant level is ok and AC works ok. I've searched for but can't find a solution to this. Anyone know of one? Thanks.
Old 06-26-2012, 01:59 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is offline
Mein Auto: 01' 540 M-Sport, Scuderia
Most likely one of two things:
1) Coolant level is actually a bit low...when stone cold (never check warm), make sure the top of the stick is about 1" above the top of the filler neck.
2) The level sensor is bad and needs to be replaced.
3) You may have an air pocket in the system. When warm, with engine running, slowly open the bleed screw a little bit (next to the filler neck) and see if you can bleed out any air.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 06-27-2012, 11:31 AM
Mein Auto: 540i
Thanks, the level seems to be ok and I've bled the system twice per instructions on other threads. I'll try the hot bleed next.
Old 06-27-2012, 02:25 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The stick is supposed to be level with the top of the neck.
Old 06-29-2012, 08:11 AM
Mein Auto: 540i
Top of stick is 2" above top of neck and no fluid is visible in upper 4" of expansion tank. Fluid level is at the lower neck about 4" down from top of the neck.
Old 06-29-2012, 09:10 PM
I have found that keeping it a bit higher prevents the silly light from coming on in the dead of winter, upon cold start. Must contract a bit more in the colder weather? I just know that every winter the damn light would come on, so if I kept it a bit higher, eliminated that annoyance.
Old 06-29-2012, 09:12 PM
I would suspect your coolant level sensor could be bad on your expansion tank. No overheating and guage reads okay, right?
Old 06-30-2012, 11:58 AM
Mein Auto: 540i
Yes, must be the sensor. Engine temp gauge is steady at center. I'll replace it.
