E90/E91/E92/E93 (2006 - 2013)
Old 06-25-2012, 10:29 AM
mzkgns mzkgns is offline
Mein Auto: 2008 BMW 335i
Unhappy White Smoke From Tailpipe
Was a little concerned when I turned on my Car this morning, it had a rough start, a cloud of white smoke came from the tailpipes, i let it idle a bit and it went back to normal not smooth but drivable. Then the Check Engine Light came on, then also the Service Light is on as well. Any Ideas? I saw a bit of a leak from the oil filter this AM as well. Going to take it in after work today, but any ideas any experience this same thing? Super Concerned....
2008-BMW 335i
Thank you in advance for your input.
Old 06-25-2012, 10:31 AM
07335i_sport 07335i_sport is offline
Mein Auto: 335i Sport,Premium & Navi
take it in. Could be a slight leak in the head gasket?
Old 06-25-2012, 10:33 AM
Do you know the price range for this sort of stuff? Ballpark?
Old 06-25-2012, 10:48 AM
no, sorry. But it seems straight forward.
Old 06-25-2012, 12:28 PM
The X Men The X Men is offline
Mein Auto: 2012 535xi 2012 X3 35i
I estimate about a $1000 to replace the head gasket.
Old 06-25-2012, 01:29 PM
Eights-n-Aces's Avatar
Eights-n-Aces Eights-n-Aces is offline
Paid Up Though June
Mein Auto: E93
Oil smoke usually has a slight blueish tint and smells (surprisingly) like burnt oil. It could also be leaking coolant into the combustion cylinder but this is usually a much heavier cloud (steam actually) and smells (surprisingly) like boiled coolant. Either way, service is in order.
http://pic90.picturetrail.com/VOL2151/2268046/4440060/399854242.jpg
Old 06-26-2012, 09:58 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Typical for a small coolant leak. Nip it now before you zap the head, much more expensive.
Here's one approach. Check pics of leaking gasket, POST #77
Is there a better DIY for head gasket R&R?
Old 06-26-2012, 10:15 AM
bigugly fab bigugly fab is offline
Dr.BMW
Mein Auto: Just an m3
More like 2500-3000
Old 06-26-2012, 01:44 PM
DSXMachina's Avatar
Automaticallyparsinglinks
I'm guessing it isn't the head gasket. Unless the OP goes in and says "My head gasket is leaking!" Then, after the service manager goes "ka-ching" a tech will find that the head gasket is bad.
Old 06-26-2012, 11:59 PM
Forgot to ask: Was the weather warm, i.e. this isn't startup water vapor in cool weather, and does it dissipate, i.e. is water vapor?
DSX: Rough start....excess water....not a head gasket....what are the probables?
Old 06-27-2012, 07:26 AM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
+1, I'm also interested what else it could be. The two times I've seen this personally, it was coolant leakage, and and at least one of them (my wife's car) was a cracked gasket.
BMW CCA Member
Old 06-27-2012, 07:36 AM
Dr.BMW
I've also seen injectors flood the cylinders and do this as well.....
In fact, that is my guess. Rough start, unburnt fuel makes sense.
Old 06-27-2012, 09:00 AM
DSXMachina's Avatar
Would help to know the code(s)! OP?
