Old 06-21-2013, 04:44 AM
TurboBusa TurboBusa is offline
Mein Auto: 2012 X5 5.0i
26 people couldn’t answer this question about the X5.....can you?
I have called numerous BMW parts and service departments, gave them the VIN to my car. I have called several glass companies and asked them. I have searched the web and came up with conflicting answers......now its your turn.
The question is......on a 2010 to 2013 BMW X5, the panorama roof is made of what type glass? Laminated or Tempered?
Before you answer.....please be SURE of your answer with some details of how you reached that answer. I have a strong feeling its tempered, but im not 100% sure. I even gave the folks the numbers off the sunroof. E000251, DOT 904, AS3, M513, 43R-000265, PGW 26, E11.
Google was my friend, and I learned a lot about glass. According to most website, this is what it says .....”AS3 can be used in certain locations in certain vehicles (and can be laminated or tempered) and has less than 70% light. The E11 with the circle around it indicates the country that certified the glass/windshield. The DOT code is the letters “DOT” followed by a number that the Department of Transportation assigns to the manufacturer of the glass. The M number is a model number for the piece of glass, which identifies the type of construction. The M number is unique to the manufacturer, so an M number of M513 by one manufacturer could be different than glass labeled as M513 by another manufacturer. It identifies the glass construction, including the color and thickness.”
Someone posted that their X5 panorama roof broke with a gunshot sound and shattered into little pieces. I thought, ok, it must be tempered glass until I read the last sentence from a several glass manufactures websites......”All tempered glass, flat or bent, can experience spontaneous breakage. If broken, tempered glass falls out of it's opening in interlocking clumps. For this reason, we recommend against using tempered glass for glazing above populated areas in commercial buildings and skylights in homes. Tempered glass can, on occasion, break into large shards rather than the classic tiny piece pattern.”
so.... can you answer the question??
Old 06-21-2013, 08:23 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
Re: 26 people couldn't answer this question about the X5.....can you?
I like the trivia, but can't help directly since I don't have the car you mention. Still here's a thought.
We are certain that the windshield is laminated (likely tempered laminated glass). Could you see if that's a M513 as well from Pittsburgh Glass? Wouldn't that tell you is the same construction?
UPDATE: I just saw the thread you are referring to and the picture of the accident. That is very indicative of a non laminated glass since the pieces fell out of position. No?
Old 06-21-2013, 08:29 AM
xx xx is offline
Mein Auto: E83 X3, F25 X3 and F15 X5
lol i'm #28 - cannot answer too. If the Saint Gobain glass company had printed "Guardian" or "Sekurit" on the glass itself, it would have been easier to guess!
E83 X3 | E70 X5 (sold) | F25 X3 | F15 X5
Old 06-21-2013, 09:36 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
I think it's pretty obvious from the photo of the broken sunroof that it's not laminated. Look at any broken windshield for an example of what laminated glass looks like when broken - it hangs together and is very difficult to punch a hole through.
The sunroof does appear to be tempered from the break pattern. Non-tempered glass would have classic large jagged edges. The small fragments clearly look tempered.
I'm no expert, but I would expect that large auto glass (windows, windshields, sunroof) are required by law to be either tempered or laminated for safety reasons.
Old 06-21-2013, 11:25 AM
You are right......... What made me rethink was the new Ford Fusion and my old Toyota Camry. Although they are not panorama roofs, the glass clearly says Laminated. The Lincoln MKZ has an all glass roof. This roof doesn't vent or open. I heard this was Laminated glass.
Old 06-21-2013, 11:41 AM
The front windshield has Saint-Gobain, Sekurit M51 on it. This is just getting harder to find out.
I,....like you,....... believe it is tempered, but I don't want to guess. I want to take those numbers off the sunroof, match them up with some manufacturer of glass and have someone say, "oh..... this number means that glass is tempered." Doesn't look like that's gonna happen though.
Old 06-21-2013, 12:12 PM
Here's a hint then: because of the policarbonate layer in the laminated it will sound dull when you tap it with, let's say, a coin.
Try it: tap a window in your house and you'll hear a clear ding. Tap the front windshield and you'll hear it dull. Than tap the sunroof and compare...
Old 06-21-2013, 12:46 PM
Ace88 Ace88 is offline
Mein Auto: 335
Be careful how hard you tap any tempered glass with a metal object....Doesn't take much before it goes kaboom.
Old 06-21-2013, 03:02 PM
ard ard is offline
Resident Curmudgeon
Easy. Tempered.
Tempered because when it shatters it forms small 'cubes'
Not laminated since these cubes all fall down like rain on yoru head. Laminated would be held in place with the plastic internal laminate.
Old 06-21-2013, 03:37 PM
ard ard is offline
Resident Curmudgeon
Which is why it is difficult to discern when a side window or sunroof explodes if it was road debris or some odd internal flaw. A small pebble spun up off your own tire can get captured by a slipstream and 'ping' the glass just right to cause it to shatter....
Old 06-21-2013, 04:20 PM
Easy. Tempered.
But how do you know ard?? For arguments sake.... lets just say we never seen a shattered X5 roof. We wouldn't know about the small cubes because there were no broken roofs. Now then..... how would we find out what type of glass this is?
Old 06-21-2013, 05:11 PM
Rickm5X3 Rickm5X3 is offline
Prefers bhp over mpg
Mein Auto: E70 X5M and 4.8i
contactSekurit@Saint-Gobain.com
2011 X5M Alpine White/Sakhir Orange, Eucalyptus, Spare tire!, Comfort, Soft Close, Tech, Climate Package, Individual dash, Individual Audio, HUD, DVD, USB, Cold, OEM hitch
2016 Sierra 2500HD 6.6l turbodiesel SLT All-Terrain
Gone:
2008 4.8i
2005 X5 4.8is
2004 X5 4.4i Sport
2004 X3 3.0i 6MT
2002 M5
Old 06-21-2013, 10:23 PM
ard ard is offline
Resident Curmudgeon
AFAIK, there are regulatory label requirements for the glass itself- there is a standard for that.
http://beranek.agrrmag.com/tag/european-codes/
Does this let you KNOW?
A
Old 06-24-2013, 04:26 AM
WOW.... Yes it does. This is exactly what I was looking for. I found some sites but the ones I found didn't have European codes. Thanks ard. This is the information I was looking for from the glass shops and the dealerships I called. Even after I gave them the numbers off the glass, they still didn't know.
That site basically says that the V means Glass Panes with less than 70% light transmittance.
A fireman also told me it was tempered. He had to break one because he had to cut someone out of an X5.
Old 08-18-2013, 05:09 PM
iconoclast's Avatar
iconoclast iconoclast is offline
Automotive Addict
Mein Auto: Audi, BMW & RR...
this should help answer some questions:
http://www.bimmerfest.com/forums/sho...d.php?t=703869
Old 08-22-2013, 02:29 PM
guest082613 guest082613 is offline
Mein Auto: 2012 X5 50i
Tempered, due to heat and breakage
