The X5 SAV Forum
Old 06-26-2012, 03:51 AM
zazoom zazoom is offline
Mein Auto: X5
Mayday mayday mayday
BMW X5 4.4i 2004
Got stuck yesterday driving back to the capital from a village in the hinterland of Ghana. Car was doing great until I got the Trans. FailSafe, Red Brake warning yellow ABS and DSC/4x4 lights come on.
Car continued on without any problems except for the warnings still on. Then as it got dark I switched on the headlamps and after about 20mins the headlamps started to go off and on with the car simultaneously revving down to idle . Had to finally stop and got her towed to a friends place. Now also have the Service engine soon warning light too.
I recently changed the battery about 5 months ago and did a thorough service on her 2 months ago and the car runs great just can't figure this one out.
Ran a test this morning and got these codes.
5014 Battery Voltage
53FC Supply, control unit: terminal 30
5F3A Transfer case
5F42 Transmission control limp home
5E52 Wheel Speed sensor EMC front right
5E28 Wheel Speed sensor EMC front left
5DCE Control Module, under voltage
5F02 Wheel-speed sensors-general
Would really appreciate any help and advice from the forum.
Thanks Folks.
Old 06-26-2012, 05:04 AM
phill20 phill20 is offline
Mein Auto: x5 E53
sounds like a battery or alternator issue, you should have the battery checked and check how much charge the alternator is putting back into the battery.
I would not look at the other faults until you know for sure that the above are working correctly, as many faults appear if the voltage is low on the X5.
Phil
2003 E53 4.6is
www.xdrivers.co.uk
Old 06-26-2012, 03:16 PM
Mein Auto: X5
Thanks Phil.......Will get the battery and Alternator checked and tested in the morning and keep you posted. Had the X5 ride on a flatbed back into the city today.
Old 06-28-2012, 06:22 AM
Mein Auto: X5
Got the Alternator and battery checked today and all looked ok.
Guys at the garage couldn't figure it out and now I'm down to surfing the net trying to get an answer..
That's wat its like when ur down here.
Old 06-28-2012, 12:08 PM
Mein Auto: x5 E53
have you had a look on
http://www.xoutpost.com/
this site is usually very good, had a look at some similar problem threads that you have described and they all seem to point at either bad battery or alternator or both, hope you find the answer, and keep us posted.
Phill
2003 E53 4.6is
www.xdrivers.co.uk
