E36 (1991 - 1999)
Old 06-26-2012, 10:47 PM
Dunzo Dunzo is offline
Mein Auto: 1995 318ti
Rough Idle
Been having an issue that just started up on my 95 E36, recently purchased private sale. I start the car cold and it idles really rough at around 400-500rpm. I can feel the underbody shaking and a light smell of gas fumes after I shut it off.
Car is OBD-I so I ran a self-diagnostic, got about 15 codes showing 1222 "Oxygen Sensor Lean/Rich Detect (primary) - If the signal from the O2 sensor indicates a very lean or very rich mixture for more than 10 seconds, then the computer generates this code. It could mean a faulty O2 sensor, or a problem with another component."
Not sure how reliable this is though since there appears to be a great deal many codes stored. They could be old codes not cleared from god knows when since I haven't had the car long enough.
Any ideas??
Old 06-26-2012, 11:12 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
Open the hood and check for any leaks in any of the hoses, mainly the intake boot thing. Cracks mean air is escapinging which can lead to an overdose on the fuel to air ratio.
A search of "e36 rough idle" will give you plenty of ideas to start with, and the majority of them being free and involve pulling parts off and cleaning them. Good luck
You can’t spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 06-26-2012, 11:25 PM
Sounds good thanks.
Old 06-27-2012, 06:48 AM
NiiCKSTERR NiiCKSTERR is offline
Mein Auto: 1994 E36 318is
I have a 318is with the same problem. I've put so much money into it while trying to fix my idle problem. I mean I got an O2 sensor, changed several hoses, changed the boot, got a new icv, changed the spark plugs, freekin mass air flow sensor. And still idle problems. Word of advice..I say go with the Dealer on this one
Or maybe sell it because I guarntee it..it gets worse from here. HA. Good Luck on whatever you decide!
Old 06-27-2012, 11:32 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
HOLYFCK! you actually did a STOMP TEST?!?!
Clean, Clean, Clean the MAF.. remove screens on MAF, use spray FIRST, (and LIGHTLY with q-tip if necessary) clean the element.
Clean Throttle body
Clean Throttle position sensor
Check for vacuum leaks
Check the hoses that are plumbed into the boot on intake
Check O2 sensor
Disconnect, clean, lube, and reconnect all associated electrical connections.
Try runnin real good fuel, top tier 91 octane or better.. add 1 gal of E85 (ethanol/flexfuel) to approx 2/3 of tank.
See if it straightens out.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 06-29-2012, 09:10 PM
Just a small update with some questions.
-Removed air filter housing, MAF and boot.
-Vacuum test, found some smoke coming out of the rear under the intake manifold.
-Removed the manifold (not fun) and inspected gaskets, hoses, no issues found there.
-Tomorrow I'll be removing the ICV, cleaning it and inspecting all connected hoses. I'll also run another vacuum test before that to try to isolate the leak(s) as the manifold and upper hoses appear good. Will also clean the throttle body.
So now I have two questions: First, the air filter cover that bolts onto the MAF was completely cracked and falling apart meaning there was definitely some unfiltered air going through the MAF and into the throttle. Will order a replacement. What impact would this issue have had towards the idle?
Also the MAF in this BMW is the old Bosch Mototronic Meter with a small resistor, a throttle-like flap system with a covered housing you need to cut open. See:
This can't be cleaned as it is not a typical MAF sensor. I am also not cutting it open to mess around with it. Any suggestions there? Can a more modern MAF sensor be installed in it's place? Thanks.
Old 06-30-2012, 01:49 PM
Anyone? Would like some advice before I reassemble. Thanks.
Old 06-30-2012, 02:04 PM
firemedic521 firemedic521 is offline
Mein Auto: Tahoe, 750I
Yeah, I would not open that up . Had a buddy try that and it never worked right again. If you had air leaking in unfiltered after the maf that could account for a lot of problems since that computer isn't accounting for that flow and is sending the wrong amount of fuel
Sent from my EVO using Bimmer App
Old 06-30-2012, 07:06 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Unfiltered air is not good for the engine but it would not effect the idle. As long as the air is measured by the MAF the idle should not drop. You should look into a cold air intake as long as you are replacing the stock air box. A CAI might be cheaper than a stock air box a plus you will get a slight power increase.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 06-30-2012, 07:20 PM
Sorry, I miss understood I though air was leaking in after the maf.
Old 07-02-2012, 12:13 AM
Yeah, this is likely since I have searched pretty hard for one. No parts stores carry them, and there's a couple on ebay but not worth the price. So yeah, I'm either getting a CAI or swinging by a BMW recycling place an hour away to grab a box. I'll do some more research on the possible MPG/performance gains on the 95 E36 before I decide. Since I'm waiting on a solution there and have the intake manifold completely detached, I'm going to clean it out and repaint it.
Question nobody answered: Can the MAF meter be swapped out with the newer, smaller MAF sensors? On the surface they seem very different in function, and not sure if they are cross compatible. Would really appreciate an answer on that. Cheers!
Old 07-02-2012, 12:42 AM
hornhospital's Avatar
D'oh, You Kids!
No, they aren't interchangeable. The older ones are incompatible with the newer ECUs and vise-versa.
Quotes to live by:
Old 07-02-2012, 10:03 AM
The ECU was replaced this year by the previous owner. That almost makes me wonder if they replaced it with the right one. Can the meter be cleaned with maf cleaner? I assume so but MAFs are sensitive and better to check first.
Old 07-02-2012, 10:06 AM
D'oh, You Kids!
Yes.
Why was the ecu replaced?
Quotes to live by:
Old 07-02-2012, 10:26 AM
Yes.
I was told the old one was toast. He left it in the trunk. I'm probably just being paranoid, I doubt the car would have just a simple idle issue if the wrong ECU was installed.
Old 07-03-2012, 11:05 PM
Hatterer4's Avatar
Hatterer4 Hatterer4 is offline
Mein Auto: 1993 BMW 318is
How do you clean this??? May be a dumb question but never heard of it
Old 07-05-2012, 06:57 PM
Just some brake cleaner on the actual sensor area (just a rotating mechanism that attaches to the throttle) and some electrical cleaner on the connection port. You can probably use the electrical cleaner on the sensor area too if you're going to get some anyway.
Old 09-03-2012, 12:46 PM
Okay, so I have completed my overhaul of the intake system. Here's my check list:
-Broken air box replaced with CAI.
-MAF cleaned.
-Throttle Body Housing cleaned.
-Upper and Lower Intake Manifolds cleaned.
-ICV cleaned.
-All associated gaskets replaced.
-All vacuum hoses checked for leaks.
-All associated sensors & connectors cleaned and greased.
-Spark plugs replaced. (NGK)
-Camshaft cover gaskets replaced. (Old plugs were covered in oil)
-O2 sensor replaced. (NTK)
I have spent months and a great deal of time and effort to do this work, everything was reconnected and put back together with precision and patience. I am confident it was all connected properly. So after two months of sitting cold, it finally came time to start it.
And... *drumroll*
The problem is not fixed. The engine still starts and nearly dies unless I give it gas, after holding the RPM at around 1100, the car eventually warmed up after 15 mins and could stay running, but not without the throttle fluctuating. I imagine after a short drive it might stabilize, which is how the car ran when I bought it. The snake was doing this with the car before I would come see it, so I wouldn't notice the issue. He always made up some reason about why the car was running.
Anyway, back to the drawing board. I imagine once I fix this problem all the work I did with the intake will pay off, but for now I am still stuck with my E36 in the garage. I am also still getting code 1222 which is O2 sensor reporting lean/rich. Any more ideas?
Old 09-03-2012, 09:58 PM
Bump.
Old 09-03-2012, 10:33 PM
wengermi wengermi is offline
Mein Auto: 1993 318i
recheck for vacuum leaks. check in between the upper and lower intakes halves. i had a couple leak from in there. also i had a bad leak from my fuel injectors and where the upper and lower haves meet. try replacing/fixing the gasket where the upper and lower intake meet. that was the hardest for me to find and it fixed my lean/rich issue. you can try adding clamps on all the lines to make sure they are sealed right. i also had bad knock sensors which caused my rough idle. i got two used ones from the junk yard and it smoothed my idle out.
Old 09-03-2012, 10:50 PM
All intake gaskets have been replaced. The hoses were checked with absolute scrutiny for cracks and double checked. I actually added some clamps onto some of the hoses as well. I don't think this particular issue is the knock sensors since the OBDI gives a code for that. Also knock sensors are used on a reactive basis and wouldn't account for the engine dying out on a cold start without throttle being applied. I'm leaning towards a fuel intake issue at this point... I should mention I checked all the injectors for clogs when I had the intake disassembled.
Old 09-04-2012, 10:51 AM
how about a compression test and check your spark plugs. most of the time you can read a spark plug and see if its running rich or lean by whats on the tip. you can also try seafoam in the gas tank or change your fuel filter and see if that helps. if its not air thats the problem then its fuel or spark
Old 09-04-2012, 12:52 PM
The sparks were replaced and the issue is the same. The #1 suspect right now is the MAF. I'm going to swap it and see if it makes a difference.
Old 09-04-2012, 01:00 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
when the car is warm, what is the RPM?
does it sort of just idle lower and lower once cold, or does it just completly die?
If you turn on the AC when the car is cold will it idle?
Old 09-04-2012, 02:35 PM
RPM stays at around 1000-1100 RPM when warm for 10 mins. Car will completely die if I don't give throttle while cold. Haven't tried using the AC to see if it makes a diff.
