E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
#26
Just changed my fuel pump and nope...didn't help. I haven't changed my coil pack yet but I think it might help, hopfully.
NiiCKSTURR and Dunzo,
This is getting confusing, since we're diagnosing two cars with apparently the same or very similar problems. I may or may not be addressing both of you, since I can't keep straight who's car is doing what. It doesn't help that you quote each other's postings. So far you two have changed just about everything except the color of the car(s) , but no where in this discussion have I seen any mention of testing the fuel pressure and fuel pressure regulator. Regardless of whether the fuel pump(s) are working correctly, if the fuel pressure regulator(s) aren't working right, the engine(s) won't work right, either. A FPR that's going bad will drop the pressure enough that the engine will run lean. Think about it. You're getting high idle speed. To do that you introduce more air (open the throttle). That's why we always say check for vacuum leaks when presented with a high/rough idle situation. Well, the same thing can happen if the fuel pressure is weak. The mix gets lean, and idle speed goes up as the engine struggles to run.Anyway, check the fuel pressure at the fuel rail. The Bentley manual has a test procedure for the FPR. Look it up, run the test and report back
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
#28
Okay, replacing the MAF did not fix the issue in the slightest. Officially moving away from the air intake. Going to investigate the FPR as Horn suggested.
#29
holy hell..
Check, clean, replace as necessary the MAF and 02 sensors. Stop trying to fix things that arent broken. Re-Stomp test. record codes. reset codes. Buy parts from a reputable source. Look in vendor section on THIS forum if you are unsure of WHERE to buy. DO NOT BUY CHEAP PARTS.. CHINESE CRAP DOES NOT WORK ON GERMAN CARS.
MAF was cleaned, O2 replaced as I previously mentioned. No change.
Replaced the MAF with another one. No change. Same code, same problem. All parts are OEM and/or BMW factory parts. FPR was tested, and I even swapped it out just to see, no change. Might be a bad fuel filter or pump, I don't have the means to check though, car will be in the shop next week for miscellaneous work. I'll have them check the fuel pressure and check the pump. |
#31
Happy to say this problem is now solved. It was a bad IAC valve, which was apparently getting stuck preventing a proper idle. It was not fixable, so it was replaced. Car now runs perfectly, especially with a nice clean intake. Though I would honestly not wish this problem on my worst enemy. Rough idles are extremely difficult to diagnose and half the time you just end up cleaning things and replacing things until you find the problem. Anyway, case closed.
#32
Thanks for posting back with the outcome. Glad you got it sorted.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
