E30 (1982 - 1993)
Old 06-29-2012, 05:16 AM
peter91 peter91 is offline
Mein Auto: e30 320is
engine vibration around 1000k rpm
ok so i did something stupid, i know it was stupid
i was doing a skid and holding it on the brakes, must of held it to hard because the car stalled.
Anyway ever since i have notice this vibration in the motor around 1000 rpm when you first start it. It idles at 650 or so fine , you slowly increase the rpm and it starts vibrating around 1000 rpm then goes away above 1000 rpm or so. After repeating this a few times (does it when out of gear too) or a little bit of driving like down to the end of the road it goes away.
feels like something is off balance? what have i done? (besides been stupid)
Old 06-30-2012, 09:28 AM
downhiller's Avatar
livin large
auto or manual?
Old 06-30-2012, 12:52 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
it does it while parked ?
you said you slowly raised the rpm's, but you didnt say whether you did it parked or just started off driving slow.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 06-30-2012, 11:21 PM
while parked and why driving, but only at the start
it is manual
Old 07-01-2012, 06:11 PM
downhiller's Avatar
livin large
well for one, you forgot to press in the clutch. really hard to tell if you actually damaged something, or youre just alil paranoid. change the oil, put in new fuel filter and some chevron techtron. go from there
Old 07-01-2012, 07:38 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
I have heard of a similar 1k rpm vibration in other e30's dont know the cause though
Old 07-01-2012, 07:43 PM
I meant while parked in neutral or with the clutch in. Can also feel it if i take of from a cold start, goes away by the time i reach the end of the street though. Going on a trip soon + due for oil change anyway, will see how it goes.
Old 07-02-2012, 07:03 PM
downhiller's Avatar
livin large
probably broke an engine mount.
Old 07-02-2012, 08:47 PM
I jacked it up and engine + gearbox mounts look fine from what i can see. I notice I am missing a fan blad though maybe that has something to do with it?
Other than that i just did a about a hundred miles in it and it ran fine
