Old 06-29-2012, 11:43 AM
traviss351 traviss351 is offline
Mein Auto: 2002 z3 roadster
fuel leaking from fuel filter hose ..2001 525i
i replaced the fuel filter on my 525i....also replaced the old rubber fuel lines and hose clamps.....6 months later the rubber fuel line started leaking at the filter so i tightened it up ....two weeks later it started leaking again ...i took it in the garage and let the car run for 10 minutes while watching the line ...no leak!.......it wont leak all the time....anyway tightened up the line some more ......now 6 months later it is leaking again....pulled it in the garage and not leaking .......anyone had this problem .....i cant tighten the clamps much more or they will cut through the hose ......thinking of using a new hose and different style of clamp.....its almost like the pump is putting out a crap load of pressure at times.....causing it to leak .....any ideas would be great!!!!
Old 06-29-2012, 12:23 PM
mifesto mifesto is offline
Mein Auto: m3
i am curious, did you use unleaded gas rated rubber lines? i have seen people use things like standard rubber hoses or fuel lines meant for leaded gas which will degrade with standard unleaded pump gas.
Old 06-30-2012, 09:40 PM
I got the fuel hose from advance so i would assume it is the right hose......? ??
Old 06-30-2012, 11:50 PM
chiefwej's Avatar
chiefwej chiefwej is online now
Freude am Fahren
Mein Auto: 2003 540i/6 //m-tech
What kind of hose clamps did you use? There are ones that are specifically designed for high pressure fuel lines.
chiefwej 2003 540i ///m-tech 6-speed
Black Sapphire Metallic w/gray
Old 07-01-2012, 05:50 AM
Axialflow Axialflow is offline
Mein Auto: 525i 02
If your hose is too big it wont seal. Should be a tight fit
Old 07-01-2012, 01:51 PM
540 M-Sport's Avatar
540 M-Sport 540 M-Sport is online now
Mein Auto: 01' 540 M-Sport cdn, F355
Change the hose clamps immediately! Use only high quality ones...Wurth are good, but there are several other good brands....don't use the crap at OReillys, Pep Boys or AutoZone...find the good imported fromGermany ones. For most jobs, it is worth it to simply use new clamps each time
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
Old 07-01-2012, 04:57 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Napa should have the correct fuel hose clamps.
Also check AutoHausAZ and EACeuroparts.
http://www.autohausaz.com/search/pro...2@Hose%20Clamp
http://www.autohausaz.com/search/pro...el%20Hose/Line
http://www.autohausaz.com/search/ima...0019976990.jpg
Jason
Old 07-03-2012, 09:40 PM
Thanks for the info.......going to replace hose and get higher quality clamps
