1994 525i (e34) - Getting to the fan, thermostat, wp area? - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 06-29-2012, 12:17 PM
magusat999 magusat999 is offline
Mein Auto: 1994 BMW 525i
Question 1994 525i (e34) - Getting to the fan, thermostat, wp area?
Those helper videos mostly use the e39 series - which does not have this thing in the way when you need to get the fan (and especially the thermostat housing) off:
What is that thing - and is there a tutorial that considers it when removing the fan / thermostat housing? (One that actually shows someone removing the fan from an E34, or better a 525i about the same year - not some other model and saying "it's the same procedure with other models" - as it is clearly not the case with that big ole piece of machinery jutting out right there!). Thanks.
Old 06-29-2012, 12:41 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Welcome. That is part of the valve cover and does not have to be removed to get to the WP, etc. The fan shroud and fan and upper radiator hose just need to be removed. Here is a link to where you can find the Bentley manual which will explain it for you.
http://www.bimmerfest.com/forums/sho...d.php?t=629472
Again, welcome
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Last edited by BMR_LVR; 06-29-2012 at 09:25 PM. Reason: Spelling of "Bentley" haha
Old 06-29-2012, 04:48 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
That would be your vanos under there. As noted, no need to remove it to gain access to the WP. Even if you did remove the cover, you wouldn't gain that much room. You also sure don't want to drop anything other than clean, fresh oil in the top of that (your engine)!
Sent from my Droid Incredible
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 06-29-2012, 06:19 PM
Mein Auto: 1989 525i M20B25
Bentley Manual?
Old 06-30-2012, 12:37 PM
I had a few surprises, even after consulting the manual. First off, the waterpump was located behind a pulley - there was no plate separating the pulley and the waterpump area. So I had to remove the belt to pull the entire pulley off. I found the pulley to be a replacement - it was a metal pulley. Evidently someone had been in there already... The waterpump had nothing wrong with it - and ALSO was replaced already, with the same one that I was going to put in there! Inspecting the area, I had to conclude that my leak was not from the waterpump. I did, however, notice coolant spills all around the area, though. Here is a pic of the leak (best I could get at the time):
Maybe someone has a clue where else it could be coming from? I tightened up all the bolts in the area, includung the thermostat housing (my next most likely suspect), but I haven't re-checked yet to see if it's simply something loose yet. The hoses going into the thermostat housing are not leaking either.
Old 06-30-2012, 01:51 PM
BMR_LVR's Avatar
Humble E34 lover
Yes, you do have to remove the belt and then the pulley (after removing the fan clutch and fan assembly). I would suspect the thermostat housing is leaking. It is a good idea to replace it. Most people recommend the aluminum replacement. I, personally, like to stick with the oem plastic one. That is all that is above the WP that could be leaking as far as I know.
It is a good idea to replace the entire cooling system every 1001K miles. It is one of the weakest areas on our beloved E34's.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 06-12-2013, 08:45 PM
Update (finally) - that leaking WAS the waterpump. I pulled it once and it looked like new. I replaced the thermostat and housing. Leak was still there. Took my car to a mechanic and he told me it was the water pump, and also my alternator (got inundated with coolant and blew it out). We had some issues over his prices so I told him to replace the alternator and I will replace the waterpump. When I pulled the waterpump, it looked like it had been dipped in acid - corroded and worn. Don't know how that happened after two weeks but whatever - I replaced it and the car was back to almost normal.
Old 06-13-2013, 05:08 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
It doesn't look like you have BMW approved coolant in there.
Did bobby talk you into using cheap green coolant in your BMW Just kidding, but it is possible to have corrosion problems with the wrong coolant.
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 06-13-2013, 05:36 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
My coolant is green. I use Prestone and have been for literally, hundreds of thousands of miles. Never an issue.
OP, a picture of the "corroded" water pump? I hope its not chocolate milk sludge... Was the old one a plastic impeller? Or a metal impeller?
Plastic
Metal
Take your oil fill cap, and look to see if you have the same "corrosion" under there. If you do, we may have some news for you.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
525i, bmw, cooling, e34, repair
