E34 (1989 - 1995)
Old 06-29-2012, 05:59 PM
Enriquekurt2006 Enriquekurt2006 is offline
Mein Auto: 525i 1994
1994 525i Auto transmission problem!
Hi, I purchased a 1994 525i in good conditions except for the auto transmission, the issue is that it seems to only run in 1st and 2nd gear, it wont change to other gear and sometimes it wont even change to 2nd gear..
Now I know for a fact that the car has not been to transmission service and has 160K miles on it, also I am not getting the TRANS PROGRAM message, any ideas?
Old 06-29-2012, 07:18 PM
Mein Auto: 1989 525i M20B25
You need to check the fluid level and condition.
Old 06-29-2012, 07:41 PM
I checked the fluid it is black but it doesn't smell burned also I think at one time the owner must have put reverse gear while driving because the shifter didn't have the push knob working, could that mean the transmission is gone?
Old 06-29-2012, 09:11 PM
Anyone?
Old 06-29-2012, 09:27 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
First of welcome to the fest Enrique my name is Noel . Do you have any reputable transmission repair shops in Guatemala ? Someone you can trust . But in all honesty , being that you stated that the fluid is black makes me wonder on the condition of the tranny , and it doesn't look to promising .
Sent from my Desire HD using Bimmer App
Old 06-29-2012, 09:37 PM
Thanks! Glad to be part of the fest! There is a transmission repair shop I can trust I will probably go tomorrow
I hope the tranny can be fixed
Old 06-29-2012, 10:01 PM
Yes that's great , I know mine is a GM tranny that's made in France . Im pretty sure yours is the same . But in any case , if you find out what it is , let us know to ...
Old 07-04-2012, 09:35 PM
HI everybody! I just had my transmission service done.. changed oil and filter
Unfortunately the problem persists, it doesnt shift to from 2nd to 3rd gear and up
I am considering that since I will have to rebuild the transmission why not do a 5 speed manual swap instead?
what you think??
Old 07-04-2012, 09:39 PM
Why not?
Search google for "M50 Manual swap". There should be a few good threads.
Old 07-04-2012, 09:40 PM
its a shame, I really liked the way the auto transmission works in that car
Old 07-04-2012, 09:41 PM
And then there was this:
http://forums.bimmerforums.com/forum...d.php?t=873524
Hallelujah.
Old 07-04-2012, 09:48 PM
that is absolutely perfect!!! thanks a lot!!
Old 07-05-2012, 08:55 AM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
Hallelujah.
Soon as I saw who did the swap, I knew it would be a great write-up.
1995 525i auto, 1/95 build, EAT chip, abt 237K miles, , HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 211K
Old 07-07-2012, 08:14 PM
Hi, I've been thinking about that 5 speed swap, the difficult thing is that where I live there is few E34 and nowhere to find a used transmission
If I go replacing the Auto transmission would any GM 4S 310R would do? or does it have to come from the same model as my car?
Old 07-08-2012, 05:47 AM
rdc rdc is offline
Russell
Not sure, but I believe the internal gearing changed for the 93-95 GM 525i tranys.
Old 07-14-2012, 01:06 AM
T.Thorn T.Thorn is offline
Mein Auto: E34 525i
The transmission uses GM (General Motors) clutch packs and is assembled in France (Getrag) making it it one of the most "state of the art" automatic transmissions in existance for that year. The tranny should have been serviced (i.e. filter,fluid,pan gasket and some TLC) before the 150,000 mile mark otherwise, you're looking at a $4,000.00 + transmission replacement. Don,t finance your mechanic's new car, ski boat, or kid's first year of college and sell your beloved BMW for parts or ? - I'm the 2nd owner of my 525i and I have all the service records. The suggested maintenance intervals are key. The car will go 300,000 plus if maintained and loved, and, will of course, drive like a BMW.
Old 07-14-2012, 09:51 AM
Hi, thanks for all the info I have found something really interesting about my BMW transmission.. first of all the dashboard LCD display doesnt work only ocassionaly but when I start driving it I find that it shifts from 1st to 2nd gear just fine but no 3rd gear.. and when in 2nd gear if I go to high revs the dash rings a warning sound and all of a sudden Im stuck in 1st gear, no more shifts only 1st gear.
Then I turn the car off and back on and it starts shifting 1st and 2nd gears again just fine.. Im almost convinced it must have an electrical problem related to the TCM or maybe a solenoid valve?
What you think?
Old 07-14-2012, 09:46 PM
anyone has had this kind of problem?
Old 07-14-2012, 10:14 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Hello Enrique. I know it's a long shot, but have your alternator checked. I have read on this forum of people whose alternator was dying and was causing some of the problems like yours. I would not replace it unless your current one checks out bad.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 07-20-2012, 02:05 PM
joser66 joser66 is offline
Mein Auto: 89 325is;95 525it
I agree with BMR_LVR. Mine has 314k on the clock and I was getting the same error message when I bought it.
You can change the voltage regulator, but I opted in a rebuilt alternator from BMAparts and the error message went away.
Good Luck
Old 05-05-2014, 09:22 AM
Leonard Gammon Leonard Gammon is offline
Mein Auto: 1994 BMW 525i
I my self need to know more about where to locate the dip stick to chech the oil level in the 525's tranny
Old 05-05-2014, 09:26 AM
rdc rdc is offline
Russell
See if this helps understand how to check trany fluid in a e34 without a dipstick. I let my independent BMW shop do it.
http://www.bmwe34.net/E34main/Mainte...0Autotrans.pdf
