X5 radio cluster - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-09-2012, 08:25 AM
Widowson Widowson is offline
Mein Auto: 1994 BMW525i wagon
X5 radio cluster
I cant read my radio cluster, need help if i can change the cluster.
Old 06-09-2012, 01:31 PM
williamX5 williamX5 is offline
Mein Auto: 01 540i/6 & 04 X5 4.4L
Good day,
There is an easy fix for this as I just did it on my 5 two weeks ago... It requires taking the radio down to circuit boards and the connectors on them... The problem is the glue used between the ribbon cable and the circuit board that controls the pixels signal breaks down the connection between the display and the circuit board... you have to pull the ribbon cable off the board, clean off the glue, and then reconnect the cable in the original method... When you get in there you will see what I mean... Do a search for BMW radio fix on google and a number of forums will come up... one or two should have the DIY method... The one I found was on the E38 board...
Good luck!!
Cheers!!
Old 07-01-2012, 06:36 AM
Jurijs@BestPixelRepair Jurijs@BestPixelRepair is offline
Past Sponsor
Mein Auto: E70 35d
If you need some help - we can get you the parts and repair service as well. If you do it by yourself - make sure that you know what you are doing. Easy to damage (to crack the LCD and/or damage gauges needles).
Old 07-01-2012, 10:26 AM
How much will it cost me, im in stockton, california
Old 07-01-2012, 10:35 AM
Past Sponsor
Mein Auto: E70 35d
please go to the www.bestpixelrepair.com , find the service you need (cluster repair service, mid repair service or combo cluster/mid repair service), add to the cart, apply the voucher code BIMMERFEST, choose the shipping service and you'll see your total.
