Old 06-30-2012, 09:08 PM
Stevel94 Stevel94 is offline
Mein Auto: 2007 X5
2007 X5/E70 Water Pump Replacement
Hello,
I am new to the forum and I'm attempting to replace my water pump after it went out at 64K. I cannot identify which is the tensioner. Looks like there is a tensioner under the alternator (16mm bolt) and another under the water pump (takes a 45T Torx). You can supposedly see the tension releasing after unscrewing, but I have turned both and I don't see anything happening. Any help would be greatly appreciated.
Old 07-01-2012, 06:31 PM
Redskin Redskin is offline
Mein Auto: 528i
It is normally a single plastic pulley with a centre bolt that loosens the the inside one winds the pulley up and down. If you go to the dealer that you buy the parts from they should be able to print a flimsy out with the parts diagram.
Hope this helps.
Old 07-01-2012, 08:14 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Hey Steve...Good luck on your repair, I just blew one on my '07 about 2 months ago..at 125k miles...it cost a grand at the dealer to repair...
Old 07-01-2012, 10:02 PM
rattmann rattmann is offline
Mein Auto: 2011 TURBO X5 35i
It is electric pump. Do you still need to remove belt and pulley
Old 07-02-2012, 05:01 AM
Mein Auto: 2007 X5
I do still need to remove the belt and pully. I think the water pump I received is belt driven, but I'm not sure. I see there is a large Torx hole, which I put a breaker bar on to release the tension, but it does not move enough to remove the belt. I might have access to a BMW mechanic through a friend, so I'm going to see today if he makes house calls.
Old 07-02-2012, 01:23 PM
Mein Auto: 2007 X5
It seems I do not have to take the belt off after all. They sent me the wrong water pump. So much for the " guaranteed correct part". Thanks for all the help.
Old 06-10-2013, 05:58 AM
roxbury51 roxbury51 is offline
Mein Auto: bmw e70 3.0
how to get access
Did you have to take anything off to get access to the water pump underneath? and how? thanks
Old 06-10-2013, 05:59 AM
hey steve, did you have to take anything off to get access to the water pump?
Old 07-17-2013, 10:52 AM
paul1994 paul1994 is offline
Mein Auto: 2005 545i
Hey any tips on doing this repair yourself? I am about to tackle this in the next day or so. I plan on replacing the thermostat and water pump at the same time.
