Old 07-01-2012, 05:24 AM
Chicagogas Chicagogas is offline
Mein Auto: 1997 Z3
1997 Z3 seats sliding-need help!!!
My seats slide forward a few inches whenever I stop for a traffic light. How can I fix this?
Old 07-01-2012, 05:43 AM
fw_fw fw_fw is offline
BMW: Freude am Fahren
Mein Auto: 2003 530iA Sport
Common problem......use the search function as it has been covered dozens of times.
Old 07-01-2012, 08:11 AM
KBH22102 KBH22102 is offline
Mein Auto: 1997 Z3 2.8, 2002 M Coupe
http://www.waycoolinc.com/z3/02/100602/shish01.html
Old 07-01-2012, 08:45 AM
whamac whamac is offline
Mein Auto:
Your bushings are all wrapped up and going in the mail tomorrow.
Best of luck with the installation!
-Doug
Doug W.
Old 07-01-2012, 09:46 AM
Mein Auto: 1997 Z3
Can't thank you enough
Old 07-01-2012, 10:42 AM
nfunk nfunk is offline
1998 BMW Z3 2.8L
Mein Auto: 1998 BMW Z3 2.8L
Check Youtube, there is a video showing the removal and installation of the bushings. I did both of mine in under 2 1/2 hours, most time consuming was removing the seats. Also purchase the nylon (or polyethylene) bushing that are being sold on Ebay.
Old 07-01-2012, 03:39 PM
droz3 droz3 is offline
DROZ3
Mein Auto: 2001 Z3 / 2006 X3
Z3 2001 3.0L 5-speeds,Topaz Blue/Sport+Premium package/Stong-Strut/Bilstein shocks/Rogue Engineering RSM/Ireland Engineering rear sub-frame bushing/CDV delete/Conforti CAI/Jim Conforti Shark/DRL module/European Wiper Module/Pioneer AVIC-N4 GPS-Receiver+XM Radio+iPod/iPhone interface+Bluetooth+12CD Charger/ASA-AR1 18" wheels+Michelin PSS/Bi-Xenon upgrade.
Latest mod : 3.73 diff. ... WOW
X3 2006 3.0L Automatic, Silver Gray, all original ... so far ...
Old 07-01-2012, 07:06 PM
Mein Auto: 1997 Z3
thanks for your help
Old 07-03-2012, 02:53 PM
stonea stonea is offline
Mein Auto: 2001 BMW Z3 2.5i
I'm pretty sure you can get bushings from roadstesolutions.
Old 07-03-2012, 03:03 PM
Mein Auto:
I've already shipped his bushings; he probably has them by now.
Doug W.
Old 07-04-2012, 01:42 PM
68v 68v is offline
Mein Auto: 97 Z3/68 Corvette
Just did this on my Z yesterday. Wow was shocked how easy this really was.
Old 09-26-2012, 03:13 PM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
I just completed the bushing replacement in my seat this weekend. Just a couple tidbits of info that some might already be doing, but thought I'd mention it. After a little working the bugs out on the first seat and the second one sitting there waiting, I knocked out the second seat in about 15mins
- Be sure to move your seats to about 2/3rds to the rear before unplugging and removing
- Remove the (2) screws on the track first, then slide the track down to access the larger anchor bolt of the adjustment rod
- I used a 1" belt sander to rough cut first bushing to about 1/2 thickness and then hand sanded to square up
- Adjusted final install by sanding second bushing
- Screw adjuster nut back on adjuster rod. Set both rods same length (+/- 1/16"). Locate both around 3" from the far end
from the adjuster rod anchor bolt. I butted the measuring tape against adjuster rod bracket and measure to farthest threaded
anchor hole in adjuster nut housing
- Slide adjuster assembly back in track. Add flex drive wire into gear drive and adjuster rod after insertion
- Pick one side and tighten up adjuster rod anchor bolt. Then add (2) track screws to anchor track
- Finger tight opposite side adjuster rod anchor bolt and add (2) track screws to anchor track.
- MEASURE MOUNT HOLES DIAGONALLY EYEBALLING CENTER OF HOLE. THIS DIM SHOULD BE +/- 1/16"
- If you're good, remove (2) track screws, tighten adjuster rod bolt, and then attach track. Insert seat.
- If you're off in the dim, loosen and slide track, spin adjuster rod with pliers/hand, and reattach track to check
Once I premeasured my adjuster rods, I only had to move (1) track (2) turns of the adjuster rod and my diagonal was equal.
The seats dropped right back in the car. It might seem like a lot of steps, but it once you do the one, you should be able to snap
thru the second. Hope it helps.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
