Old 07-03-2012, 03:03 PM
nasmo nasmo is offline
Mein Auto: M5 F10
Originally Posted by shawnsheridan View Post
Look in DME2 [12] and DME2 [13] for VMAX setting.
TY very much!!!!
found it!!
these are the values:
Any advice how to proceed?
ID:	331507   Click image for larger version
Old 07-03-2012, 03:09 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
I think changing it to the max 326 would be 326 kph = 202.567009 mph. Can you change it, and post anther picture? I want to see what the Werte value is at 326.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 07-03-2012, 03:15 PM
Mein Auto: M5 F10
You mean this? :
I am not able to upload it now to my car because it is middle of the night ..
Old 07-03-2012, 03:24 PM
Originally Posted by nasmo View Post
You mean this? :
Werte=FF is what I was expecting. Yes, I think that effectively removes the limiter. I am puzzled that your default on an M5 was at 250, but maybe that is a Belgium thing.
I look forward to seeing what Stealth.Pilot's it set to, to see if the Dinan tune is also set to 326 / Werte=FF.
Old 07-03-2012, 03:29 PM
Mein Auto: M5 F10
Yes here in Belgium we aren't able to order performance package .. so limit is 250
Old 07-03-2012, 03:35 PM
An M5 with no Performance Package and capped at 250 kmh / 155 mph...WTF?
Old 07-03-2012, 04:01 PM
miotoo miotoo is offline
Mein Auto: F10 520d
If we find that's all behind the 'electronic speed limiter', it's a major $$$ hit to the modders, I mean even bigger than when the 2 values for VIM were identified...
F10 520d Deep Sea Blue 11.04.2011/16:24
Retrofitted:
5DF Active Cruise Control with Stop & Go incl. Collision Warning with Brake Function /ver. 1
2TB DEC Switch for Normal / Sport / Sport+ Writeup: http://www.bimmerfest.com/forums/sho...d.php?t=685869
8TH SLI Speed Limit Info / KAFAS 1
5AD LDW Lane Departure Warning / KAFAS 1
319 Universal Garage Door Opener
6WA Instrument Cluster with Extended Contents
Old 07-03-2012, 07:29 PM
Stealth.Pilot's Avatar
Stealth.Pilot Stealth.Pilot is offline
The Driver
Mein Auto: 2014 M5
In the spirit of chasing the bunny, I will upload mine tomorrow morning as soon as I get back home.
This is exciting news from Nasmo. US M5s are also limited to 250.
2014 Porsche 911 Turbo S
2015 Mercedes C300 4MATIC
Memberships: BMW CCA, Peachstate PCA, NMA, AAA, RAC
Sold:
2015 Jaguar F-Type R
2014 BMW M5 Individual Dinan Stage 1
2013 BMW M5 Individual
2012 BMW 550i Dinan Stage 2
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 07-04-2012, 02:40 AM
Mein Auto: M5 F10
So what I did; I followed the guide for coding in E-sys;
I changed the value to 326
clicked the save button
Activated the FA
and selected the CAFD file
last step coded the FDL
everything went ok , except first try, when my engine was running, it was not accepted;
So engine off, all te steps again and then logs stated OK
Now I have to test it; But it seems so easy, that I cannot believe it;
In case my fear is grounded, where should I look further or for what do I look for in general?
Did I followed the right steps?
Now I started, I am so eager to learn more about e-sys ..
2 weeks holiday will be good time to read & learn
Old 07-04-2012, 06:24 AM
Mein Auto: M5 F10
Bad news;
My fear was grounded; I changed the values in DME and hit the road, 268 km/h on the HUD when my horses were put on hold meaning the 250 limiter is still in place;
So back to e-sys; I found also the VMAX setting tab in DME13, so I programmed both with same values, thinking they gave a conflict ;
But unfortunately it didn't worked out either;
Reading the car out again, I noticed the values were changed to INPUT 9 and were C9
what should it mean? Dunno; car is driving just the same..
Any thoughts?
Old 07-04-2012, 06:35 AM
Bad news;
Any thoughts?
Well, that sucks. Can you post a pic of the DME 13 VMAX setting and also the INPUT 9 / C9 you mention?
We need to see Stealth.Pilots settings, which I think we will have today.
Also, since you have a M, you should try and add S231A DELETION VMAX to the FA (VO) and then code the DME, and see what both VMAX change to.
Old 07-04-2012, 07:01 AM
Mein Auto: M5 F10
Will post screenshot later today;
S231A DELETION VMAX? Will lookup how to program this ; keep you posted
Are there possible dangers adding this?
Old 07-04-2012, 07:05 AM
Not that I am aware of. You want to follow the guide for Changing FA...then when you are done adding 231 to FA and writing the new VO to the car, you will select DME 12, and then CODE (Not CODE FDL), then do the same for DME 13. DO NOT SELECT CODE DEFAULTS...just "CODE".
Old 07-04-2012, 07:53 AM
Mein Auto: M5 F10
Shawn I tried to code 231 into FA (using the guide which is pretty straight forward)
FAIL
you asked for screenshot --> DME12:
Solution?
Name:	231 FA Code fail.jpg
ID:	331559   Click image for larger version
Name:	Result DME12 after 326 setting.jpg
Old 07-04-2012, 08:45 AM
@nasmo; The error indicates it is dependent on some other VO Code...so maybe 231 is just not compatible with F-Chassis vehicles.
@Stealth.Pilot; Can you check your VO too and see if Dinan maybe altered it and and added any SA Code(s) to it? Hopefully you have a pre Dinan FA reference for comparison.
Old 07-04-2012, 01:24 PM
Mein Auto: M5 F10
Update;
I looked up what module it could be, because in Germany you can order the M Driver's Package with include the 280 km/h limit;
This module = 7ME .. i was able to program it into FA
After coding, DME 12 & 13 the values were kept in place which gave me hope;
But after test-drive and running again against the 250 speed limit I noticed again the
UNKNOWN
werte=C9
Somewhere the car does had a control unit ..
Hope to see the Dinan logs
if someone has other thoughts ..
Old 07-04-2012, 02:01 PM
Update;
UNKNOWN
werte=C9
Well...some progress...so we know that the M Driverís Package, SA 7ME takes the top speed from 250 km/h / 155 mph to 305 km/h / 190 mph, and that you can at least add it to the VO.
After you changed the VO though, you did CODE on both DME 12 and then DME 13 and it automatically changed the VMAX settings in both, or did you manually FDL code both VMAX settings after that?
Old 07-04-2012, 02:17 PM
Mein Auto: M5 F10
First i did the code DME 12 and 13
than I checked everything seemed be equal
but no change in values ;
So yes I manually changed the settings.
Old 07-04-2012, 02:29 PM
Ok...so 7ME can be added to the VO and written to the car, but when the VO is actually applied to the DME Modules, the VMAX settings don't change. This I do not understand on your car since it is an M, and 7ME is a valid Option Code.
I guess we wait and see now if Stealth.Pilot has 7ME in his VO, and what his DME VMAX Settings are.
Old 07-04-2012, 02:37 PM
Mein Auto: M5 F10
Were can I look up the correlation between the FA code (package) and the FDLs?
ie option 230 (close to 231) is EU specific but can't find the contend what this includes.
I keep looking hope some expert can point us in the right direction
Old 07-04-2012, 02:47 PM
I don't think any such animal exists. That would be great though if it did, as you would know for sure every module requiring a manual CODE after VO Change.
I think the better answer is to fully understand E-Sys, as it is capable of taking a modified VO, and automatically identifying and coding every module needed to support the changed VO. This is explained in Page 9 of the E-Sys User Manual...but it's not very clear.
Old 07-04-2012, 04:06 PM
The Driver
Mein Auto: 2014 M5
Here's mine.
Sold:
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 07-04-2012, 05:26 PM
The Driver
Mein Auto: 2014 M5
I don't have 7ME in my VO.
Also I don't have DME2[13]
Here are some more screenshots.
ID:	331588   Click image for larger version
ID:	331589   Click image for larger version
ID:	331590   Click image for larger version
ID:	331591   Click image for larger version
Sold:
2004 BMW M3
2001 BMW 330Ci
1997 BMW 328Ci
1994 BMW 325Ci
Old 07-04-2012, 05:57 PM
@Stealth.Pilot; Thanks for the info. Well, your settings of Wert_02 / Werte=02 match Losco's, and he too supposedly has no Speed Limiter with his Japan spec'd car. So, maybe Wert_02 / Werte=02 is it. I would like to know what your's was set to before the Dinan tune though. Hopefully someone else with a stock 550i can chime in with what their's is set to.
If that is the case though, I am not sure that will help nasmo, as in looking at his pictures, his setting choices appear to be all numeric, without a Wert_02 option. Although in his case, we should be able to figure out how to code his car to accept factory 7ME.
Old 07-04-2012, 06:58 PM
JEG23 JEG23 is offline
Mein Auto: 550i
@shawnsheridan
Here are the values for my stock 550i
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
