E90/E91/E92/E93 (2006 - 2013)
Old 07-01-2012, 10:40 AM
ganny76 ganny76 is offline
Mein Auto: 325i
Run Flat Help
Daughter borrowed my wifes 2007 328i last night. Went i drove it this morning it felt like it had a bad tire. I checked the tires and none feel flat. Never dealt with run flats before. Is this normal? If i decide to replace with regular tires and purchas a spare and jack is there anything i should be worried about. Thanks in advance.
Old 07-01-2012, 10:59 AM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 09 335Cabrio zsp/11 335d
Can you give a more detailed description? N4S
Old 07-01-2012, 11:56 AM
GG Hyundai GG Hyundai is offline
Mein Auto: '08 328xi
Just useless trunk space.
Old 07-01-2012, 11:58 AM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2011 335XI
Check the sidewalls and check for bubbles. If you hit a pothole hard enough with a run flat, a bubble will appear and tire needs replacement.
1997 328i- retired
2007 328i- retired
2006 X5- retired
2006 330xi- retired
2011 X5 -retired
2011 335xi-PCD-12/13/10 Dinan stage 3, intercooler, oilcooler, and exhaust.
bmw cca#443379
Old 07-01-2012, 12:05 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
how did you check them?
and what do you mean none "feel" flat
the proper way to check is to actually check the pressure. a completely deflated runflat will "look" fine
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 07-01-2012, 12:52 PM
AzNMpower32's Avatar
Tar Heel Faithful
Send a message via AIM to AzNMpower32
Mein Auto: X3
Just use a tire pressure gauge......"feeling" a tire for pressure is about as useful as looking at it to determine tire pressure.
Current Ø consumption (X3): Spritmonitor.de (325i) Spritmonitor.de *Click on icon for details.
Old 07-01-2012, 03:17 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
Your car should be equipped with a Tire Pressure Monitoring system. Did you get any warning light on the instrument panel? Check the air pressures?
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 07-01-2012, 08:11 PM
angler's Avatar
angler angler is offline
1 Converted Addict
Mein Auto: 135i M-Sport 6mt Cabrio
You should get rid of the rft's and buy reel tires anyway.
PSS|PPK|PE|LUX H8 V4 EYES Pending
Old 07-02-2012, 06:16 PM
Mein Auto: 325i
Checked pressure. All are at 32 except right rear is a 20. Carrying it to the tire shop tomorrow to get it checked. Been reading on hear a lot and seems like i should just get 4 regular tires and a spare.
Old 07-03-2012, 06:52 AM
Pasa-d Pasa-d is offline
Mein Auto: 335d
People are very quick to bad mouth run flats, but it seems like they did just what they are designed for in this circumstance; mainly, got your daughter home safely on a flat tire.
If you had regular tires on the car, you probably would have gotten a call from her stuck on the side of the road with a flat tire (best case) or stuck in a ditch with a flat tire (worse case) or ??? (worst case).
Not sure why your TPMS didn't go into alarm though, that is strange, and you should have been aware to always check the pressure on low profile tires rather than simply looking at them. Run flat or not, low profile tires can have very little visual difference between properly inflated and severely underinflated, especially if the ground you are parked on is not billiard table flat.
I'm on my second set of run flats now and find them to be perfectly acceptable.
'11 335d M-sport/Le Mans/Oyster/Glacier/Titanium angel eyes
Lifetime avg fuel economy: @27,000 miles, 35 mph, 28.0 mpg
Pollution is bad, but carbon isn't pollution!
