e39 Misfire issue with 6 codes... - Bimmerfest - BMW Forums
Old 07-02-2012, 09:17 AM
cbfurg cbfurg is offline
Mein Auto: 1993 325i
Hey guys,
I've been searching for a few days trying to decide what is going on so my apologies if I overlooked a thread for this but here is what is going on.
2002 530i
Loss of engine power and stalling
Misfire and rough idle
Idles low with difficulty bringing up the rpms
engine dies when I step on the accelerator when idling
terrible gas mileage
Check engine light on
Here are my codes:
P0313 x2 (1 is Pending) - misfire detected with low fuel
P1343 - Misfire cylinder 1 with fuel cut off
P1620 - MAP Cooling control circuit signal high
P0174 - fuel mixture too lean
P0102 Pending - MAF circuit low input
P1344 Pending - Misfire during start cylinder 2
I've cleaned the MAF and checked/cleaned the spade connections on my fuel pump. It seems like the engine is being starved for fuel but let me know if I'm missing something. Any advice about what this might be would be fantastic!
UPDATE
I decided to check out the ICV while pulling the DISA and clean it. While doing so, I noticed a rather large crack in the intake boot. Could this be the cause of my issues? Regardless, I'm replacing the o-ring on the DISA and cleaning the ICV. I'm thinking about doing the valve cover gasket as well since I'm leaking oil at a decent rate.
Old 07-02-2012, 01:24 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
How old is the fuel filter? If original, replace it. BMW now acknowledges a 100k service interval.
Sometimes, cleaning the MAF works; sometimes, it doesn't.
Old 07-02-2012, 02:19 PM
I checked the fuel filter, it looked pretty clean to me. A couple specs but nothing that would clog anything. I tried cleaning the MAF but that didn't help any either.
Old 07-02-2012, 02:25 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I had the same problem ... btw. And almost the exact same codes. See my solution in the misfire threads.
To find them, I'd suggest going to the bestlinks and searching for the 'misfire' thread which will point you to the solution.
Old 07-02-2012, 02:33 PM
Thanks Blue. I'll check that out and report back. I read a bunch of misfire threads but somehow missed yours. Thanks for the help!
Old 07-02-2012, 03:48 PM
Just removed the disa. It seems fine except The rubber seal ring was flush with the housing. Is this normal? I can upload a pic if that helps.
Old 07-02-2012, 07:29 PM
poolman poolman is offline
Mein Auto: 525i station wagon
You have a vacuum leak, do a search with the engine at the top of the page, I have two write upd on this problem--one is more detailed--read up and then attack the problem areas
Old 07-02-2012, 08:42 PM
lild's Avatar
lild lild is offline
livin the 'Fest
Mein Auto: 97' 528i, 06 ninja
Yes the big crack in the maf boot will cause your problems.. Replace it. While your @ it clean & replace the gaskets on the tb. You'll see a difference.
The more you complain, the longer God makes you live. SPHOBA #00002
Old 07-02-2012, 09:23 PM
bluebee's Avatar
Everything said above is listed in these threads ... which I get the same way you would ...
I go to the bestlinks ... and then I do a /vacuum or /disa or /misfire and they all have what is said above.
For example, on the DISA o-ring question:
- Where to get a proper DISA valve repair kit (1) & how some jury-rig 'repair' a rattling DISA unit (1) (2) (3) & how the DISA valve operates (0) (1) (2) (3) (4) & how to test DISA operation (0) (1) (2) (3) (4) & a simple DIY to install an M54 DISA (1) & a nice DISA autopsy (1) (2) & a great DISA group buy (1) & how the disa valve o-ring fails (1) (2) & how it can reputedly cause all sorts of cold-engine rough idle problems (1) (2) & where to get just the DISA valve o-ring (1) & why you want to check the DISA at 100K miles or whenever the airbox is removed (1) (2) & why the DIfferenzierte SAuganlage ("Differential Air Intake") valve flap breaks (1), sometimes with parts sucked into the intake manifold (1) (2) (3) (4) (5) (6) (7) (8) & a well documented example of how a broken DISA flap can ruin your engine (1) & yet another seemingly complex set of misfire codes reputedly traced to a broken DISA valve (1)
Or for the misfire thread question:
- How to diagnose a BMW E39 engine misfire (1)
And, for vacuum leaks:
- How to locate all problematic (between 1/8" & 9/32" ID) 3.5x1.8mm, 3.3x1.8mm & (between 17/64" & 9/32" ID) 7mm ID vacuum tubing (single material), vacuum hoses (multiple material), 3.3mm OD curved vacuum pipes (rigid tubes), 3.5mm & 7mm ID vacuum endcaps (closed end) & 7x3mm manifold o-rings (1) & 7.52X3.52mm and 9.2X2.8mm fuel injection o-rings (1) & gaskets (1) on the M54 engine & where in the USA to get new vacuum tubing & vacuum caps (1) & what SAE sizes to get for all the metric M54 engine vacuum tubes, hoses, pipes, and caps (1) & correcting the F-connector errors in the realoem diagrams (1) & finding the ends of hard-to-locate vacuum tubes (1) & sorely needed clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1) & how to make, borrow, or buy lean-condition misfire test tools to test for vacuum leaks & lean conditions (1) (2)
etc.
Good luck.
Old 07-03-2012, 07:08 AM
Once again, thanks Blue. That is an invaluable resource and I can tell you put in a ton of work. I'll dive in head first and report back once I locate the issue.
Old 07-03-2012, 12:35 PM
EconoBox EconoBox is offline
Mein Auto: 2001 530i (E39) 140k
Duct tape the crack in the intake boot
Other things to checK for misfire:
  • Smoke test (Intake boot leak, Vacuum line leak, Intake Manifold Gasket)
  • CCV
  • MAF
  • O2 sensor
  • Spark Plug
  • Spark Plug Boot
  • Coil (swap coil to test)
  • Camshaft position sensor
  • Crank position sensor
  • Fuel Pump
  • Idle Control Valve (ICV)
  • Oil in spark plug sockets from leaking VCG
Old 07-03-2012, 06:14 PM
Cleaned the idle control valve.
Cleaned the MAF.
Replacing intake boot (on its way from bavauto)
Checked the fuel pump filter. Is there any way to check the pump itself?
Going to continue moving down the list. Thanks!
Old 07-04-2012, 02:22 AM
bluebee's Avatar
See the threads highlighted in bold red below:
- How does the E39 fuel injection work (1) & what are the most often recommended fuel pump & fuel filter brands (1) (2) & a DIY for replacing the fuel filter (0) (1) (2) (3) (4) (5) (6) & a quick test for fuel pump operation (1) (2) and a DIY for replacing the fuel pump (1) (2) (3) (4) (5) & how to replace and service your BMW E39 fuel injectors (1) & details on replacing the 7.52X3.52mm and 9.2X2.8mm fuel injector o-rings (1) & the location of the K96 fuel pump relay (1) & where is the fuel system pressure test Schrader valve for the I6 (1) & where is the fuel pressure test point for the V8 (1) (2) (3) & where is the location of the fuel pump relay K96 (1) & cleaning (1) (2) & replacing the fuel sensor (1) & how much gas should be left to cool the fuel pump (1)
Here's my picture of the autozone fuel pump testing kit, for example, which is available free of charge for a 90-day loan (1):
There should be a DIY for everything on that list.
Old 07-04-2012, 08:48 AM
Did you duct tape up the intake boot ??
That's the most obvious answer.
Old 07-07-2012, 06:57 AM
Intake boot isn't it. I'm thinking that the lean codes are indicating fuel pump issues. I'll get the kit from autozone and see where that takes me.
Old 07-07-2012, 06:18 PM
JamesO JamesO is offline
Mein Auto: '06 330Ci Vert. '03 M5
Fuel pumps soft fail and can cause lean codes. But also check the CCv lower oil drain hose as well, very common problem.
www.bmaparts.com has good pricing on fuel pumps with free shipping if you fine the online discount code, I think it may be specE30?
Old 07-14-2012, 08:00 PM
franan franan is offline
Mein Auto: 2001 530I-2012 535I 5spd
Any good news yet.
Old 07-15-2012, 05:23 AM
This thread covers a lot of the common 6 cylinder BMW driveability issues.
http://forum.e46fanatics.com/showthread.php?t=897616
e39, misfire
