Old 07-02-2012, 04:23 PM
microswitch's Avatar
microswitch microswitch is offline
Mein Auto: 2006 5251
Weird Radio acting
I used a out of market radio for few months, till my son decide He needed his stereo back.
I put back the stock radio on my 2002 E39, however something very funny is happening.
When I shot off the car the radio keep on playing even if the light on the radio are off and I mean all the light are off. I have to physically push on the power button and then push again to shot off the radio. What gives ?
I used a Metra adapter so I did not cut any wire just plug and go.
Any one had same experience or know of the reason and a fix?
Old 07-03-2012, 11:43 AM
After driving for about 20 min the radio shut off on its own indicating to me that only the temp/delay power to the radio is working( will play for about 20 min when car is off).
So now the issue is a probably piched wire that prevent switched power to work on the radio ..
Old 07-03-2012, 12:29 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
there is probably more than one positive wire. you may have them switched. One positive is constant the other only works when the key is in usually.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 07-03-2012, 03:46 PM
Yes indeed however there is no switching possibility. There is a harness that plugs directly into the radio, the original one. No wire were spliced..
And when i installed the after market radio I had to fish the switched power form the fuse box to make the radio work. With the original radio is not necessary. I only need a diagram to find the switched power wire so i can test it.
Old 03-14-2014, 09:13 AM
UsedBits UsedBits is offline
BMW CCA Member #: 444067
Mein Auto: 2002 540iA with sport pkg
Radio plays after ignition is off and keys removed
The radio in my e39 presents the exact problems shown in the original post, except that it plays for only a minute (or so) after the car is shut down and the keys removed from the ignition. The problem started immediately after it was in the shop (water pump plus collateral damage from overheating).
1) the radio plays even though all dash lights (including clock) are off.
.a volume control doesn't affect volume
.b radio presets do not change stations
2) the radio randomly turns off
3) radio does not 'remember' station through power cycle
.a preset #1, when pressed, goes to station then immediately changes to another
This might (or might not) be related. While the car was in the shop (5 weeks), the battery went dead. Overnight temperatures were well below freezing (low 20s). Shop owner replaced the battery (was Interstate, now NAPA). I don't know how long the car was without power.
We can not find a setting for "radio power-off delay" anywhere, including the shop's AutoLogic computer interface.
I'm hoping someone in this forum can suggest some diagnostics or places to look.
Regards,
Steve
2002 e39 (540iA) with factory 'sport package' modified with:
'03 fr. and r. bumpers, front air ducts, and spoiler
18" Staggered MPars (style 37)
Dinan exhaust
shorter springs
European center console arm rest
VECTOR radar detector (non-working)
.|(oOO)\(lll)(lll)/(OOo)|
. \o\0=======|=======0/o/
...|__|.............|__|
Old 03-16-2014, 11:26 AM
Radio plays 20 minutes then powers off
Regarding #2 in my list of symptoms: the power does not shut off randomly. Instead, the power shuts off *exactly* 20 minutes after powering it on.
To review, the radio worked perfectly until it came back from the shop (water pump and extra stuff replaced). Upon return, the radio does not turn off when the ignition is switched off, keys removed, and door opened. Instead, the radio continues playing for about a minute.
When wanting to listen to the radio, it powers down exactly 20 minutes after powering it on.
I've not tested this with CDs (yet).
Regards,
Steve
Dinan exhaust
shorter springs
