EML & DSC light came on during hard acceleration - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 07-02-2012, 05:57 PM
Brando7 Brando7 is offline
Mein Auto: 2000 328ci
hello guys,
Started my 2000 328ci today everything was normal. I let it warm up for about a minute then accelerated quickly, the EML and DSC lights came on. The lights were on for maybe 15 seconds and then went off. I recently changed all my brakes and deleted my muffler about 3 weeks ago.
Any ideas as to why this happened?
Has anyone else experienced this problem?
I read a little on the issue but their are many explanations: O2 sensors, mass airflow sensor, a camshaft position sensor, bad cat converter, etc.
debating on getting codes read
Any advice would be appreciated!
Old 07-02-2012, 06:54 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
You`ll never know WHAT it is until you get the codes scanned....
The road goes ever onward....
(R.I.P. Jever)
Old 07-02-2012, 07:03 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Your DSC light will flicker when the system is engaged. Quick acceleration with wheel slippage will cause this.
The EML light, according to the owner manual: "There is a fault in the electronic engine-management system. You can continue to drive with reduced engine output or engine speed. Please have the system inspected at your BMW Center."
If you got a Check Engine light (picture of an engine) then it could be any number of other things. These codes can be read by most code readers. I am not sure about the EML codes however.
Jeff R.
Old 07-02-2012, 07:45 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Whoever wrote that is just pain lying. Ever try and drive one in EML mode? You get power to 2k rpm's and it promptly cuts out till you get below 2k rpm's again. Try going up a hill like that, it doesn't work. My 323 did this repeatedly. It ate 4, count em 4, throttle bodies. Never did figure that one out.
OP, scan for codes, you should have some.
ds, eml
