Old 07-02-2012, 06:39 PM
rkruz rkruz is offline
Banned
Mein Auto: 750i 2008
Speedo and Tach Illumination?
Are the numbers on the Speedo and Tachometer supposed to be lit up when the headlights are not on?
My instruments cluster is not lit..... and it seems awlfully dark. It lights when the headlights are on though.
This for a 2008 750.
How does yours work?
thanks for the input!
Old 07-03-2012, 05:24 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
I believe that is normal. If the engine is cold and the "variable" tach redline is showing, the gauges are lit; if the cruise control is set, the gauges are lit; if you have a navigation destination active, the gauges are lit other wise they are "dark".
Old 07-03-2012, 02:13 PM
Banned
Very definitive answer GeorgeT. Thank you. Im having some Gremlins in this car now so I guess Im a bit sensitive to what it is supposed to be doing
Thank you.
