Whine, whine, whine - Bimmerfest - BMW Forums
Old 11-05-2012, 08:02 PM
Gokomachi15 Gokomachi15 is offline
Gokomachi15
Mein Auto: 528i Sport Wagon
Whine, whine, whine
Lately, my beloved 2000 528i wagon has started to whine when I turn the steering wheel. Seems, too , that the wheel has become stiffer to turn. Help. No opinion or suggestion is ridiculous
Old 11-06-2012, 04:12 AM
vavet5308 vavet5308 is offline
NADAVAN
Mein Auto: 2002 525it
Seems like something with the power steering system. Have you checked the fluid level lately? It takes standard, off-the-shelf Dexron ATF that you can buy at any auto parts store, and probably even most grocery stores.
Old 11-06-2012, 04:18 AM
Y2K528i Y2K528i is offline
Mein Auto: 528i
I have a leak somewhere on mine, I can always tell when it needs more fluid because it will "whine" as you said. I just keep filling up the power fluid every few days and it stops whining. Im gonna have to pay somebody to find the leak and replace whatever is leaking eventually.
Old 11-06-2012, 04:44 AM
Fudman's Avatar
Fudman Fudman is offline
9 times out of ten, the leak is at the hose connection to the reservoir.
Look directly below the power steering reservoir. A small hose attaches directly to the bottom of the reservoir. You may need to remove the bottom pan or the air filter to improve access. The fix is SIMPLE. Get a small hose clamp, remove the hose from the bottom of the reservoir, cut 1/2" off the end of the hose, reattach it to the reservoir, and secure with the clamp. Or pull out your credit card and pay a mechanic $100 to do it for you.
Old 11-06-2012, 05:01 AM
Mein Auto: 528i
Sounds good to me, thanks!
One thing I do like about these cars is how easy they are to work on. I can change my own oil, change my own light bulbs, changed all the filters by myself. Its funny because its so easy to work on yet places like Wal-mart refuse to even change the oil.
I have an oil service reset tool but its not working for some reason. And my dad lets me work on it at his garage, when he didn't see a battery under the hood he was scratching his head for an hour.
Old 11-06-2012, 05:25 AM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
[QUOTE=Y2K528i;7178321]Sounds good to me, thanks!
I have an oil service reset tool but its not working for some reason. And my dad lets me work on it at his garage, when he didn't see a battery under the hood he was scratching his head for an hour.[/QUOTE
You are in great shape if all you have to worry about is a power steering leak.
Old 11-06-2012, 08:11 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
Those are relatively easy maintenance items. Wait until you have to do a cooling system overhaul, vanos seals or oil filter housing gasket.
