E34 (1989 - 1995)
Old 07-02-2012, 11:21 PM
magusat999 magusat999 is offline
Mein Auto: 1994 BMW 525i
Exclamation Yet another cooling problem... E34
My 1994 BMW 525i's cooling problem just turned into a mystery for me - maybe someone has some advice on how I should proceed from here? It started with the car spitting up coolant when I parked after driving and progressed to overheating.
I checked radiator, waterpump, recovery tank, radiator bleeder screw, and thermostat housing - no leaks from there. I changed hoses, thermostat, sealed the t-stat housing (just in case) because it looked like the radiator fluid was cascading from the housing at first. I also did bleeding like I am supposed to. But even though the car performed a little better, after driving about three miles and parking it the "COOLANT LEVEL +" warning came on and yet again I saw leakage, but I also saw a spray pattern on the back upper side of the passenger side radiator hose (a few inches from the tstat housing going down the engine facing side of the hose about 5 inches). This "spray" could would be impossible to come from the tstat housing - so what could it be? Whatever it is, it's coming from somewhere in the front of the engine, but I am having an impossible time finding it.
Is there a hidden hose? Is there a bleeder screw? Could it be coming directly from the engine block? (Coolant and oils are clean)? What else could it be, spraying coolant from that area???
Old 07-03-2012, 07:26 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
That does not sound like a leak you either have extreme pressure in the coolant line (headgasket?) or thermostat got stuck in closed position.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 07-03-2012, 08:05 AM
Wouldn't bleeding the system take care of the pressure? And its a new thermostat so I don't see how it would be that. There is a spray of coolant on the hose - as I described - which could not come from the tstat area, so I can't see it having anything to do with the thermostat.
Old 07-03-2012, 10:54 AM
1995i540's Avatar
Founder @ Maintenr
I assume you bled it, you have two issues leak and overheating I'm not sure what you are asking? Are you asking if you have a leak and for us to know from where it's leaking?
Old 07-03-2012, 07:26 PM
japbike736 japbike736 is offline
Mein Auto: 1993 525i
I'm guessing the head gasket has givin up on it. Do a compression check....
Old 07-03-2012, 09:29 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Just looking at the engine bay I can tell the car is neglected. Plan on a $500 cooling system over haul.
Old 07-04-2012, 12:22 AM
Sorry it's not so pristine looking but I just started to get to work on it. I've been spending a lot of my time praying I would not have to go under the hood, but my fortunes have been down lately and that's the only reason I'm becoming a weekend grease monkey. I have been doing the minor stuff (oils, fluids, etc.) but the car was running so well I was surprised by this development. It's totally out of left field!
But looking in there (finally) I have to agree that it isn't so pretty... I was thinking about the thermostat housing that I had pulled off of the car and while shopping at an auto parts store I saw Block Sealant on the shelf. I remember there was this strange, thin, hard coating on the inside of the thermostat, and now I think I may have been taken in by the seller of this car. If I am not mistaken, that was the remains of some sort of block sealant - which means someone tried to hide a problem! Sure, the sealant worked up until now, but evidently it wore off and the original problem is back.
What I was wondering here is if there is coolant spraying from the front of the engine area, and it is not the thermostat / housing, waterpump, or any hoses (I addressed all of those already) - then what else could it be? To reiterate, it is spraying behind the hose I pointed out in my pics.
Old 07-04-2012, 12:52 AM
M540FELLA's Avatar
M540FELLA M540FELLA is offline
Josh
Mein Auto: 95 540i m sport
Block sealant would probably be hiding a cracked head my friend.... compression test it like mentioned
Old 07-04-2012, 05:33 AM
BMWGIRL BMWGIRL is offline
Mein Auto: 1992 BMW 525IX SE TOURER
I have a 1992 525ix, mine was down to 2 head bolts snapped so it had a full overall, i.e. New gaskets, new bolts,head skimmed,polished values, etc as its my pride and joy it cost a bit but it was worth it she now runs like a new car.
Sent from my GT-S5570 using Bimmer App
Old 07-21-2012, 05:53 PM
I took the car to a mechanic and he told me it was indeed the waterpump. I feel really stupid now because that's the first thing I thought it was, until I pulled the waterpump out which at that point looked brand new! He said the bearings were worn out on it. I guess I had no clue, because I couldn't tell when I checked it - and returned the new waterpump to the shop! DUHHHH!!!
Well thanks for helping - if that's all it is then I'll be one happy camper to see that mystery solved (and fixed).
Old 07-21-2012, 07:07 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Keep us updated on if it was the water pump or something else- it will give me hope that any cooling problem (including mine) can be solved!
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 11-25-2012, 03:55 PM
MikeyBabii MikeyBabii is offline
Car Crazy
Mein Auto: 92 BMW 525i
My 92 525i has the same problem... Have you found out the issue?
Old 06-12-2013, 08:39 PM
It was the water pump, but the liquid splashed all over the alternator and took that out too, so I had to replace both. I know this took a long time, I've been through some personal difficulties since then, but I feel incomplete not answering this.
bmw, cooling, leak 525i, repair
