car sometimes jerks while coming to a stop
I have a 99 540i auto. Once in a while when i'm slowly coming to a stop, maybe at around 5mph or less, the car would jerk to an almost complete stop as if i suddenly applied more pressure to the brake pedal. But at the same time the engine rpm would drop and felt like it went low enough to stall the engine but it never did stall on me. All these when it happened it happened so quick for a split second but everything always recovers to normal. I couldnt tell if it's the engine sudden rpm drop that caused the jerk.
I just bought this car not too long ago. Here's a list of the problems on my car that i'll soon deal with, and dont know if they have anything to do what the above symtom: - DSC triangle, amber ABS and Brake light constantly on: previous owner claimed that he disconnected it. I did a little research on the forum, and i verified that the speedo and cruise control all works. The brakes appears to work as normal. - cracks on flex disc, the plate where the driveshaft bolts onto. Car makes squeaky noise when it starts rolling from a standstill and sometimes when coming to a stop. Maybe center support bearing is bad also? - Signs of slight oil leak by the transmission shift shaft (it's an auto tranny) will have to check oil level. Maybe it's running low and cause the tranny to act strange. The car was on a lift once at Dinan for something else and the tech handed me a list of things that need attention and no troubleshooting had been done on anything at the time. Some items are just the typical stuff for an E39 with high mileage but the ones i listed above are what i think that needs immediate attention. I'm gonna take my car to a friend that owns a shop and i'll get to work with him together and look at the car in details. Otherwise the car starts and drives fine, no check engine lights and the engine runs normally. However i'm limiting driving this car to a minimum. Its my second car.
99 540i Dinan 5 Last edited by gl4832; 07-03-2012 at 02:38 AM. |
Maybe the torque converter (auto clutch) isnt disengaging smoothly.
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
On a side note, the flex disc and center support bearing on the driveshaft had been replaced after i originally started this thread a while back. The old disc wasnt in a really bad shape but the center support bearing did need replacement. Also checked tranny fluid level and it was fine. Seemed to be changed fairly recently just before i bought the car. I had put maybe 1200 miles on the car since then. There's also a steering shake at around 45-55mph. Guys at Dinan told me i had a bad control arm bushing without me telling them about this problem. My friend and i werent able to dublicate or pinpoint this problem while we had the car on the lift and tried to shake the front wheels. I'm thinking about replacing them soon anyways since it may affect safety. I should research on this more or start another thread.
99 540i Dinan 5 Last edited by gl4832; 09-26-2012 at 12:40 AM. Reason: typos |
I typed /abs F3 in the bestlinks and came up with many links - one of which is this:
- How to diagnose & fix the ABS DSC (or ASC) BRAKE trifecta (1) I typed /vibration F3 in the bestlinks and found this which may help you narrow the issue down: - The main causes of vibration while highway driving (0) (1) (2) (3) (4) (5); while highway braking (1) (2) (3) & why it's not rotor "warp" (1); and severe shuddering while slow speed braking on bumps (1) & TireRack vehicle vibration diagnosis chart (1) (jpg) with match mounting hints (1) & due to worn drive shaft, flex disc, center bearing, or "giunti Boschi", namely the giubo (pronounced sort of like jew'eebo), and sometimes unknowingly misspelled as "guibo" (1) (2) (3) (4) & how to repair the rear driveshaft seal by the differential (1) or the inner constant velocity (CV) half-drive shaft (1). See above links. I typed /torque converter F3 in the bestlinks and found this, which may help: - How to diagnose the P0741 DTC (1) & how to replace your torque converter (1) I typed /rattle F3 in the bestlinks and found heatshield rattles, DISA rattles, catalytic converter rattles, etc. Maybe one of those is your issue?
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
