Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E63 / E64 M6 (2006 - 2010)
Old 07-04-2012, 06:29 PM
Sotomike08 Sotomike08 is offline
Mein Auto: M6
2006 m6 won't start
My m6 won't start all dash lights work no check engine light on it only has 50k, but when I push the start button all I get is a click and it sounds like the starter is no good, so I replaced the starter and I have the same problem. I also put a new battery same problem just a clicking sound like the starter is no good any suggestion?
Old 07-04-2012, 07:09 PM
6spdg37s 6spdg37s is offline
Mein Auto: 2008 Chevy Corvette z06
I had a few e46 beemers in teh past and when I got the clicking noise it was a dead battery, as soon as I hooked it up to jump it or dropped in a new battery it started.
Sorry I could not be more help !
Old 07-04-2012, 07:33 PM
tchavera tchavera is offline
Mein Auto: 323is
check fuse to starter
Old 07-05-2012, 09:12 AM
Mein Auto: M6
Fuse starter
Where is the fuse starter on a 2006 m6. And if the fuse was no good would I get a clicking noise?
Old 08-04-2012, 08:05 PM
Mein Auto: M6
Wow after days of of struggling with my car and hundreds of dollars later. The reason my M6 did not start was the positive wire that runs from where the jumper wire goes. If you follow that wire its connected on the driver side over the cam. there a black nut that holds those wires together. That part was tight but underneath there's another nut that hold the positive wire that goes to the starter. That nut was loose which caused the car not to start. Hope this helps someone with the same problem and I can save them the amount I spent.
Old 08-12-2012, 05:24 PM
SilberGrauE60 SilberGrauE60 is offline
Mein Auto: 2009 M6
Glad you figured it out!
2009 M6 Coupe, SMG
2004 545i Sport, 6 MT (Sold)
