E34 (1989 - 1995)
Missing Blower resitor?
OK, I just got the car a week ago,I have so far got the Windows working the battery stays charged and I found front seats because this car has the Twisted and ripped passenger seat.all interior lights working now and few other things I forgot already...
BUT..... Now Im trying to get the AC working,I have googled and been on the forums and have found how to change the blower resistor,I think I should have mine on the driver side above the Gas pedal??? If so its missing? I see a plug with 4 wires is that the correct Plug and does the resistor snap on the heater housing ? what else can I be missing.....all the duct work was already off so Im asuming the last guy was trying to do the job and never got to it.... rs |
Sounds like it was removed and never put back. Hopefully for no good reason.
pics would help. |
Yes above the gas petal it plugs into the heater housing.About $42 or so shipped.The new are Blue the originals are Brown
blower resistor
Here are some pics... I ordered the resistor the other day on ebay 29.99 free shipping, also theres a pic of a Orange resistor looking part? it opens on a small spot to show a few silver pieces.
thks rs |
Pretty sure the orange connector on pass side is a air bag related. were you able to locate the cabin filter?
E-34 convertable
blower resistor
Lucky I havent looked for the cabin filter as of yet,Im trying to sort thru whats suppose to be where..Im waiting for the resistor to come in and see what happens. Should the AC work without it? I tried charging the ac but the gauge shows high pressure,"stays in the red" and the clutch hasnt come on? the compressor does, should I keep trying to fill it until the clutch engages???.
rs |
The A/C should work as long as the blower fan comes on. You just won't be able to use speeds 1,2,and3, only 4. Sounds like a problem with your pressure switch on the A/C receiver drier. There should be a way to jumper the switch somehow.
The pictures above were of the passenger side glovebox. The resistor is supposed to be on the drivers side directly above the accelerator pedal. Look there instead. Last edited by paperplane94; 07-05-2012 at 07:01 PM. |
blower resistor
paperplan the pics are of both sides, you can see the driver dash stuff removed and the one pic shows above the gas pedal, there is no resistor there at all..? It shipped ,so in a few days Ill get that on , in the mean time the ac clutch hasnt engaged,the AC light is on and the comprssor is on but no cluch doing anythg, maybe ill try more freon... ill try again when its a little cooler out, its 100 plus here and i have other cars to use ...
rs |
Ah hard to tell but now I see. The coolant pipes gave it away finally.
Yeah, throw a resistor on there and see what she does. |
Sent from my Desire HD using Bimmer App |
The only way you can get the system to take r134 in there is to have the clutch engaged . If you don't its useless to even try . You have to bypass that swtich like paperplane sugested
![]() Sent from my Desire HD using Bimmer App |
remove the glove box at lower strap clips and 2 rear release hinge ,remove 2 covers on lower left passenger side carpet panals , . remove Pass side air duct at feet . In the very back left middle of firewall look up to your left with a flashlight. Remove plastic filter access door. Its the only cream colored plastic door back there.Its about 3 in wide and 8 in long One # 8 torks screw low on the door and a funny plastic blade at top that swings left to open. There will be a slim black climate control component box in the way of sliding out the filter.This small box is removable to allow the filter to be easily removed. Filters are 10 to 50 dollars. Bring vacuum with long narrow attachment for filter housing. Be prepared to be completly disgusted by how dirty it is with hair, dirt, dust ,leaves, grease . Watch your heating and cooling system come back to full strength as it can breath again. Very easy change 30min job LD Last edited by luckydog; 07-05-2012 at 11:41 PM. |
blower resitor
Yeaa, Got the resistor,, plugged it in and I have all speeds on the fan, NOW I have to get the Ac working, Where do I jump the compressor to get to see if everythg is working?
rs |
I would research and test related fuses and relays. I know that the green led will come on the button, when the snowflake symbol button is pushed and vent dials are turned to blue and the blower is set to blow. # 5 is the relay in this pic below. I think their is a related fuse too.
blower resistor
OK, Drove 230 miles total today ,Picked up 2 front seats LIKE NEW cond.. some other stuff.Hopefully Ill get to install them tomorro and get driving the car.
On the AC, When I turn it on I hear/see the engine rpms go up ,,the ac button is lit but I do not see a "Green" Light...the clutch is NOT coming on,Ill check the temp switches and others tomorrow.anythg else? This should be r143a already? the gauge fits? rs |
ac relays?
?? the smaller relay box under the hood has 2 relays and looks like a third should be there??? i have a yellow light green and a missing spot I think?
rs |
You need to jumper the switch at the A/C reciever drier to turn the compressor on. I don't know the exact wire or wire color so search! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
