Old 07-05-2012, 12:07 PM
rickystapleton rickystapleton is offline
Mein Auto: x3
2006 BMW x3 Pulsating on acceleration
While accelerating Starting about 3000 RPM's up too 4500 RPM's, pulsating begins; the check engine light has not triggered; It seems to occur in every gear?
What to do?
I've all ready replaced the air filter and plugs!! NO difference!
current miles 84,000
Old 07-05-2012, 01:53 PM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
2 things
1- What grade of gas are you using. During hot weather I have noticed I do not get smooth acceleration using low grade fuel. You might try running some Chevron Techron fuel additive through it.
2- Vanos problems will definitely cause this. Wait till this winter when the temps drop below 50. See if it will hold a steady idle in the morning. Bad Vanos will cause idle to drop to almost a stall and then catch and rev back up.
In the meantime don't drive it above 3000rpm.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 07-06-2012, 01:02 AM
murderland murderland is offline
Mein Auto: x3
do you know if indy shops would be willing to do the vanos seal repair kit?
Old 12-04-2012, 11:16 AM
crash23 crash23 is offline
Mein Auto: '06 X3
I starting having this issue with my 06 X3 around 5k miles ago. Currently @ about 102k. Just replaced the plugs and just ordered a new air filter. Based on your experience, that is not going to resolve it either.
Were you able to fix your issue?
Old 12-04-2012, 04:59 PM
Cchrono Cchrono is online now
Mein Auto: Bmw
Change your o2 sensors and get dme reprogrammed I had same thing and this is what fixed it.
Old 12-15-2012, 06:11 PM
jdeday's Avatar
jdeday jdeday is online now
Send a message via AIM to jdeday
Mein Auto: 2005 BMW X3 3.0
Defiantly the 02 sensors, they require replacement at 100K
2005 X3 3.0, Mystic Blue Metallic, Sand Beige Leather Interior, Birch Grain Light Wood Trim, Steptronic Transmission, Premium Package, Heated Seats, Privacy Glass, Satellite Radio Prep, Xenon Adaptive Headlights, Heated Steering Wheel, Premium Sound, Power Folding Mirrors and NAVIGATION RETROFIT
