The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition. |
3D's AEROSOL GLASS CLEANER
http://www.3dproducts.com/Glass-Clea...tml?a_aid=8013
I normally use 3D's Ready to use glass cleaner, but my wife prefers foam to liquid. We had some Sprayaway at home that she just used up recently and asked me if we had any more. I said sure, but this is 3D's version. I said it is a new can, I just received it so why don't you give it a try. She wanted to clean some mirrors in the house so it was a good opportunity to hear what she thought of the product. I was in the next room doing paperwork, when I hear her say: This smells very nice! And she went on about how 3D really know how to make a chemical product a pleasure to use. When she was done with the first mirror, I went over and checked out the result. There was no smears or any residue left. Highly Recommended!!! ![]() Excellent ethenol-based glass cleaner that can be used to remove oil and smoke film from car windows. If you are a professional detailer or a car wash owner you must get 3D Aerosol Glass cleaner. Glass cleaning is a must if you want to keep your car clean. If your glass windows and even your headlights are not cleaned enough, this may cause some problems, particularly when you are driving. It isn't always advisable that you rely on the car wash to do that job for you, especially if it's something as easy as a task like this. Whenever your glasses start to smug or your lights start getting darker, obviously, you'll have to clean them to get rid of the haze. When it comes to glass and plastic headlight cleaning, Aerosol Glass cleaner is ideal as it foams onto the surface allowing you to see where it is sprayed easily. This glass cleaner gets rid of all kinds of dirt from all glass type materials, windshields, mirrors, and other glass. It easily removes any stubborn stains and at the same time, give it that clear shine. Unlike other invisible glass cleaner, which are not VOC compliant due to recent regulations on aerosol containers. However, this is a VOC compliant aerosol glass cleaner. Great for use on sports cars, used cars, RV’s to remove smoke residue, airborne contaminants, dirt and grime. Don’t use squeegees found at gas stations, as they can harm your windows. Use this easy to use handy glass cleaner with a clean microfiber towel. An affordable solution to a risky pattern. Directions: SHAKE WELL BEFORE EACH USE. WILL NOT SPRAY WHEN COLD. Remove protective cap - hold dispenser upright. Point valve opening towards window or glass to be sprayed, holding about 8 to 12 inches away. Press button - spray on fine mist and wipe clean. For best results, polish with a link-free, cotton cloth
DETAILING MADE SIMPLE www.3dproducts.com First time buyers, use coupon code TD5 www.autopia.org www.hdcarcare.com |
After washing my car with Dawn (yes forever), wipe window with a clean towel, or rag, or tee shirt, or what ever that absorbs or spreads water.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
