Old 07-05-2012, 03:29 PM
biomike biomike is offline
Mein Auto: F430
Battery maintainer on 2010 750LI - Where do I connect?!?!
Sorry for the naive question, but can someone tell me where I connect the hot and cold? I am not finding the usual battery terminals to be easily accessible. :-)
Much appreciated!
Michael
Old 07-05-2012, 06:51 PM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
Under the hood. Check the manual - don't just guess. I almost connected the ground incorrectly.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 07-06-2012, 02:17 AM
BaranE BaranE is offline
Mein Auto: '10 740Li
You can always plug it directly to the battery in the trunk.
Old 07-06-2012, 05:32 AM
6spdg37s 6spdg37s is offline
Mein Auto: 2008 Chevy Corvette z06
my z06 has battery in the trunk and the quick jump under the hood.. connected it to the positive where you would jump from under the hood and then found a nice clean paintless ground
Old 07-06-2012, 06:56 AM
The ground in the 7 series is painted - the same coating as the rest of the engine bay. So that's why it's not very easy to find without knowing where it is. And then it makes sense once you know.
2016 Benz C300
Old 07-06-2012, 01:28 PM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
So when using the battery tender, we should connect it under the hood, not in the trunk? It would make sense though, since one don't want to have the trunk open while he is gone for a month.
2015 X6M, 2014 X1, 2015 Kia Sedona SX-Limited
Old 07-06-2012, 03:31 PM
gassy gassy is offline
BMW 7 Series Obsessed
Mein Auto: 2016 M4 Champagne Quartz
Either location will suffice. The flat electrical cord will compress under the trunk lid and not prevent it from completely closing with most battery tenders, or you can run it under the hood and it too will close without a hitch.
Old 07-07-2012, 06:22 AM
You can also just disconnect the positive terminal.
Old 10-13-2012, 05:29 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
So just purchased a BMW charger because I won't be driving my car during the winter, actually hooked up today and it's fully automated so I don't have to worry about disconnecting it. It's one purchase you should make if you plan to keep your car parked during the winter.
2011 750i
Old 10-15-2012, 12:43 PM
BMW rocks!
Do I really need it if I will be on vacation for 11 days?
Old 10-15-2012, 12:52 PM
You should be fine as long as your battery is charged up prior to you leaving. ie. Make sure your preceding week included a relatively long drive, say 30 min. You can always get a jump from BMW Assist.
2016 Benz C300
Old 10-15-2012, 12:57 PM
BMW rocks!
Thanks Chris, yeah, I plan to do a long drive with minimum electrical usage (no stereo, headlight off, no AC ) before I leave.
Old 10-15-2012, 09:11 PM
king0fspades king0fspades is offline
Mein Auto: 2011 750LI
You are not supposed to close the hood while charging.
Old 10-15-2012, 11:02 PM
+1.
Never close your hood, don't use a power cord and keep the charger as far away from the leads.
2011 750i
Old 10-16-2012, 07:19 AM
For those in the market, the one I have is on sale today at Sears - http://www.sears.com/shc/s/p_10153_1...0x000545&aff=Y
Good security for $23.99.
2016 Benz C300
Old 10-16-2012, 11:26 AM
BMW rocks!
Wow, pretty cheap, I should go grab one just in case. Thanks again Chris!
Old 10-16-2012, 12:05 PM
It's a good investment especially for folks that will keep their cars parked for an extended period of time.
Sent from my SGH-I747M using Bimmer App
2011 750i
Old 10-16-2012, 12:29 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
NEVER hood up the charger DIRECTLY to the battery otherwise you can risk screwing up the electronics that control the battery! The underhood terminal is connected to a power management module that monitors the battery voltage and will allow it to charge properly.
