The X5 SAV Forum
Old 07-06-2012, 01:15 PM
Ratz r Ratz r is offline
Mein Auto: X5
No ac
Just a couple questions... Out of town and ac stopped working. Occasionly will kick on, otherwise ac clutch will not engage. Did try tapping while ac should have been on, no luck..
Also aux fan does not come on. Tried to jump the sensor on the radiator hose but no luck. Checked all fuses and rattled all connections... Any clue? I'm fine with no auxillary for now but need ac because I have a five hour drive to get back home in heat wave... Note, all pressure I'm ac unit was fine.
Old 07-06-2012, 01:28 PM
DirtyDan's Avatar
DirtyDan DirtyDan is offline
Mein Auto: 2003 X5 3.0i
I know this is a long shot, but have you tried taking off the negative battery terminal connection under the spare. You should do it for 2 hours.
Old 07-06-2012, 01:37 PM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
Aux. fan defective? Seems to be a lot of these about lately.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
Old 07-06-2012, 01:41 PM
Mein Auto: X5
If the aux fan doesn't work, will that prevent the compressor for kicking on?
2002 ac
