F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
#26
Ordering 2014 Z4 s35is |
#27
Doesn't need to do 0-60 in M3 times. If it just does 4.9 seconds 0-60, I will be extremely happy. I will be very happy if it does it in 5.0 seconds. And happy if it does it in 5.2 seconds. And mostly that all relates to bragging rights since I'm hardly going to *feel* the difference between 0.3 seconds when getting to 60MPH.
#28
My comment is hybrid F30 v. 335 F30. The hybrid may turn out to be a tick faster, but will not corner/handle as well - pretty much a toss-up in both cases. |
#29
If I want a hybrid I will buy Prius, from BMW I expect uncompromised performance and MPG is my problem from there on.
#30
Why do you say it will not handle/corner as well, when the added weight is placed in the back and low to the ground?
#31
Precisely. It's entirely possible that it could actually handle better. The extra weight is placed in the best possible spot and could actually contribute to the car's road-holding capability.
#32
More weight means more inertia, so slalom time would most likely be impacted.
I guess from the perspective of gravity the car would stick to the road better
#33
Weight is the enemy of handling. Every race car designer, every road car engineer, does everything he can to reduce weight. Every extra pound takes more energy to accelerate and stop, reduces maximum cornering, delays rotational transitions - bad in every way. A lighter car accelerates faster, stops more quickly, can corner at higher speed and transition more aggressively. Remember, cornering is continually accelerating mass with a changing vector. A Heavy vehicle, like a Hummer, does not want to hold onto the road while cornering; it wants to slide off to the outside. A Miata is delighted to rip around the corner. This is not a function of a higher center of gravity. A high center of gravity makes the car want to roll over on its side, not slide sideways. (Yes, suspension issues decreases grip with a higher center of gravity, but this is another can of worms.) Yes, if you must add weight, lower and more centered is less deleterious. Not adding the weight at all is vastly better. |
#34
I think an extra 300 lbs added to the rear axle and to further lower the center of gravity of the car, while this added weight contributes to some additional 115 ft-lb of torque at idle, and raise the mpg by anther 10, is a very good trade off.
Whether it will corner better or not, let's wait and see the test results. |
#35
Remember, by the time you are going walking speed (2-3 MPH) the additional torque is, at most, 30 ft-bs - very modest.
Interestingly, the percentage increase in power is nearly the same as the percentage increase in weight. Quote:
It will not be a bad handling car, but will exhibit a bit less capability than a 335. It will also be an interesting car. Purchase it if you find it intriguing, but do not buy it for increased performance. |
#36
Lower center of gravity will allow the car to turn the corner with less body roll, a benefit in daily driving, more so than the g rating you get during the slalom test. |
#37
Achieving this kind of economy without losing any acceleration is a type of "increased performance" |
#38
![]() In the BMW, the maximum total torque ever available is 332 ft-lb. The N55 generates 300 lb-ft beginning at 1,200 RPM. Thus, when the engine is at 1,200 RPM. the motor torque is 32 lb-ft, using BMW's numbers. Electric motors are capable of a flat torque curve if given large amounts of current. The Tesla carries massive, capable and expensive batteries to maintain this current. The BMW has a very modest set of batteries with a controller which vastly limits current (perfectly appropriate, merely a different implementation). Quote:
This remains true regardless of where in the vehicle the weight is placed. It is, as you indicate, better to place any extra weight low rather than high. An experiment for you: Load three hundred pounds of rock salt in your car, placing it on the floor behind the front seats. This is roughly centered and low in the car. Accelerate, brake and corner. Is the performance "better" because you have lowered the center of gravity? Any change in roll? Does the car feel as quick? As maneuverable? Try it. Seriously. It appears you are in for a bit of a surprise.
#39
Fully agreed and a neat aspect of hybrids.
#40
I had a 2006 330i sport, a 2009 335i sport, and am currently driving a 2011 335d sport. The 335d is 500lbs heavier than the 335i but, in my opinion, it handles better. It just feels great. It's also a torque-monster and has very good fuel economy.
#41
I have a feeling that's going to be the general consensus about the ActiveHybrid 3, too!
#42
But does your 335d corner better than the 335i, or 330i, when the amount of torque is not as important as the weight, and weight distribution of the car?
#43
I don't know if it corners better but it does not corner any worse. I drive pretty aggressively and the overall experience wih the d has been a pervasive feeling of stability, solidity and of being one with the road. Freude am Fahren.
#44
In street driving, as much as we try to drive aggresively at times, it is still no comparison to driving it at autox or on the track. It is not surprising that we don't really feel much difference in handling or cornering. Because all 3ers can handle streets just fine. It is when you attack a corner at 80 mph that the weight of the car can really be felt, but the grip of different tires can be felt even more. |
#45
![]() Who cares? If you can't tell the difference with the most aggressive street driving, what does it matter? If you can't tell the difference on real-world streets, in real-world corners, and real-world highways, that's good enough for me. Afterall, I'm going to be driving mine on real-world roads 99.99% of the time, not a race track where I can pound a corner doing triple digit speeds. If you can't tell the difference when attacking a corner at 40 or 50MPH, seems like that should be the benchmark it's based off of.
Ordering 2014 Z4 s35is Last edited by bmwexecutive; 07-11-2012 at 12:57 PM. |
#46
Yes 99.9% time the only things most people can notice is how fast the car can kick start from a stop light, then how fast it can come to a stop at the next light.
But we are supposed to be the few, who can tell other differences Last edited by dtc100; 07-11-2012 at 01:08 PM. |
#47
My experience, however, is that once you experience what a good car can do you can tell even on slow corners and less than at maximum. The handling of the hybrid will certainly be good, even if it is a tad less than the "standard' F30. My expectation is that those that buy the hybrid will enjoy aspects of the car other than its performance which will more than offset the performance downside. |
#48
No, it's not. No, it couldn't.
Has this car hit the showrooms yet and available for test drives/purchases?
"When the going gets weird, the weird turn pro." - HST |
#50
Think it will hit showrooms at the end of this month. But ONLY for Central Region BMW dealerships, for some reason. No other region got launch allocation and every ActiveHybrid 3 at every dealer will be exactly the same specs -- clone cars.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
