Old 07-06-2012, 09:42 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
Mein Auto: 2011 535i M-Sport
Thumbs up BMW ISTA-P 2.46.3 On VMWare
Courtesy of monekyboy8888 on bmwcoding.com:
password: Garagesoft.BE
RapidShare Links:
https://rapidshare.com/files/5199650...are.part01.rar
https://rapidshare.com/files/1212329...are.part02.rar
https://rapidshare.com/files/4586142...are.part03.rar
https://rapidshare.com/files/1235946...are.part04.rar
https://rapidshare.com/files/4086371...are.part05.rar
https://rapidshare.com/files/8378181...are.part06.rar
https://rapidshare.com/files/3539848...are.part07.rar
https://rapidshare.com/files/2008064...are.part08.rar
https://rapidshare.com/files/3558026...are.part09.rar
https://rapidshare.com/files/1755926...are.part10.rar
https://rapidshare.com/files/5915345...are.part11.rar
https://rapidshare.com/files/2454083...are.part12.rar
https://rapidshare.com/files/1170768...are.part13.rar
https://rapidshare.com/files/9534442...are.part14.rar
https://rapidshare.com/files/5434373...are.part15.rar
https://rapidshare.com/files/1730412...are.part16.rar
https://rapidshare.com/files/6478977...are.part17.rar
https://rapidshare.com/files/2031803...are.part18.rar
https://rapidshare.com/files/1965734...are.part19.rar
https://rapidshare.com/files/2397923...are.part20.rar
https://rapidshare.com/files/3813302...are.part21.rar
https://rapidshare.com/files/1367680...are.part22.rar
https://rapidshare.com/files/1576590...are.part23.rar
https://rapidshare.com/files/1324458...are.part24.rar
https://rapidshare.com/files/1935459...are.part25.rar
https://rapidshare.com/files/1969782...are.part26.rar
https://rapidshare.com/files/1824828...are.part27.rar
https://rapidshare.com/files/7629872...are.part28.rar
Torrent File:
http://fs10n4.sendspace.com/dl/6121e...2.46.3.torrent
1) Needs VMWare or VMWare Player to run VM.
2) Needs Genuine BMW ICOM, or ICOM Clone, or ICOM Emulator.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 01-25-2013, 10:32 AM
dodeemad dodeemad is offline
Mein Auto: F15
Dear
Any idea how to upgrate ISTA-D ? right now im using 2,32 and i want to update to 2.35
I have the dvd and im using VM player
please help
Regards
Old 01-25-2013, 10:40 AM
Originally Posted by dodeemad View Post
Dear
please help
Regards
As far as I know, the VM versions can not be updated.
Old 01-25-2013, 11:17 AM
Mein Auto: F15
Originally Posted by chli1976
Thanks, but i have that
Do you know what the meaning of the below writen?
So in this case how to update my ISTA tools?
I have 48.1 orginal dvd and i have 2.35 dvd but i dont know how to do it
With ISTA/D, I don't think 2.30 vs. 2.32 matters much.
Now with ISTA/P, it matters.
I played with the ISSS.vmdk file. The image file is a Disk made up of 3 Partitions. You can mount the ISSS.vmdk image in WinMount, and then have a choice of which partition. In partition 3 (Disk Index 2), the uncompressed PSDZdata lies here:
\apps\ISTA-P\BMW\Services\data\ecudata\psdzdata
All the CAFD files are here:
\apps\ISTA-P\BMW\Services\data\ecudata\psdzdata\swe\cafd
I tested it, and I can copy CAFD files to and from the image in this fashion.
So, I don't see why you couldn't replace all the 46.3 PSDZdata with the 47.5 PSdZData in the ISTA/P VM Image.
Old 01-25-2013, 11:26 AM
Yes, that is what I wrote after playing with the ISTA/P VM, and learning the file structure.
However, I only tested it with the some of the PSdZData to verify that the VM could be edited and written to. I never took the full PSdZData into the VM, let alone the full ISTA/P, which would be ten times more complicated than just the PSdZData.
Old 01-25-2013, 12:11 PM
Mein Auto: F15
Dear Shawn
Thank you so much for your reply
So you mean to say i cant do any thing with the DVDs i have now ?
But im wonding how people makeing the ISTA wrking in laptop with old versions?
Please if you can do something we can share the DVDs together and have out system update it
Regards
Old 01-25-2013, 12:35 PM
Dear Shawn
Regards
Most people I know that have ISTA/P VM, are always buying newer ISTA/P VM's. They also sell a native version for more money that can be updated with DVD's, but I think it is quite expensive.
For me, I have had no use for ISTA/P. I use E-Sys for everything. You can alter your VO, VO Code, FDL Code (which you can't in ISTA/P), Flash Firmware, and import FSC Codes all with E-Sys. So, the only thing I use the ISTA/P DVD's for is to rip the PSdZData from the .jetarch files so I can turnaround and use it with E-Sys.
In addition, with ISTA/P, you need expensive ICOM or ICOM Clone Interface, or ICOM Emulator with ENET, although the latter is limited in functionality.
So, I guess it begs the question of why bother with all the expense and trouble of ISTA/P? What do you plan to use it for?
Old 01-25-2013, 12:42 PM
Mein Auto: F15
ok.
but which E sys version you have ? and the thing is i never try to flash any ECU by E sys. i old try to code only
Please advice
Thanks alot for all your replys
Old 01-25-2013, 12:44 PM
ok.
Please advice
3.22.5. You can't flash with 3.18.4.
Is that why you wanted ISTA/P?
Old 01-25-2013, 12:48 PM
Mein Auto: F15
Yes My friend.
I even try ti use 3.20 but it did not connact to the car and i had very hard time with it
finaly i run the 3.18 on VM and it work for reading and coding only
but dear if u need 48.1 data i can send it to you
Mein Auto: F15
do you havw skype ?
Old 01-25-2013, 12:52 PM
Yes My friend.
I think you need at least E-Sys 3.22 for flashing. If the KIS/SVT Target I-Step (shipment) is grayed out, and you can not selected the proper I-Step (shipment), then you need a newer E-Sys.
Old 01-25-2013, 12:54 PM
do you havw skype ?
I have Skype on my cell phone, but it only works on the Verizon Wireless network, and right now I am in Europe on business, so I am roaming on Vodafone in Paris at the moment.
So, no Skype until I return to the states.
Old 01-25-2013, 12:59 PM
Mein Auto: F15
which version you are using ? is it working to flash all ECUS?
Old 01-25-2013, 01:01 PM
I have 3.22.5, and it works with HU_CIC and KOMBI, so I assume it works with the rest.
Old 01-25-2013, 01:05 PM
Mein Auto: F15
How can i get it dear?
So i can try if it work with my need
Old 01-25-2013, 06:31 PM
PM sent.
Old 01-26-2013, 12:13 AM
karlmm karlmm is offline
Mein Auto: E46
Shawn, would you mind sending me the information too?
I'm also looking for a way to flash my CIC & kombi.
Old 01-26-2013, 12:29 AM
Mein Auto: F15
Thanks Shawn
My best regards to you
Old 01-26-2013, 01:09 AM
chris88 chris88 is offline
Mein Auto: bmw x3 F25
hi shawn
can you please send me also pm for the esys 3.22
many thanks, chris
Old 01-26-2013, 07:08 AM
Originally Posted by chris88 View Post
hi shawn
many thanks, chris
PM's sent.
Old 01-26-2013, 08:54 AM
Mein Auto: E46
Hi Shawn,
Thank you very much for the PM and the link.
In another post you were talking about a guide on how to flash the control modules using esys.
Do you mind sending me that also?
Karl
Old 01-26-2013, 09:41 AM
Hi Shawn,
many thanks, Chris
Old 01-26-2013, 10:05 AM
Hi Shawn,
Karl
Yes, but it is not suitable for release yet. It is close, and we have successfully flashed ECU's, but we did brick a CIC unit about 3 weeks ago, and we would like to better understand what went wrong there, and update the Guide if needed before publishing it.
Old 01-26-2013, 04:56 PM
markgca markgca is offline
Mein Auto: 2013 M5 F10
Hi Shawn
can you please send me pm for the esys 3.22
thanks,
mark
