Valve Seals Leaking. - Page 3 - Bimmerfest - BMW Forums
Old 03-11-2013, 09:49 AM
bmwoem1 bmwoem1 is offline
Past Sponsor
Mein Auto: X3
If anyone located in the Long Island, ny area needs this repair done, send me a PM. I'm a BMW master tech who can do this job for a fraction of the dealer cost.
Old 03-11-2013, 09:50 AM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
What would the price be??
(just curious. I am not in the area, but mine is beginning to have a little smoke if I sit for 15+ minutes and idle, then rev it up)
Old 03-11-2013, 09:57 AM
Past Sponsor
Mein Auto: X3
I don't want to list prices on the thread because it depends on which model it's in and if you have a check engine light on or not (secondary air faults). PM me with your info
Old 03-11-2013, 10:04 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
yea you are right, somehow 4.5 L is little more to do, that valvetrain spring is looked like pain to installed after all seals are done, right? (the big spring in front the engine at intake side).
BMW CCA Member, Capital Chapter
Old 03-11-2013, 02:05 PM
Past Sponsor
Mein Auto: X3
If you're talking about the valvetronic intermediate lever springs, then you wouldn't have to remove them, the whole assembly comes out with the intake camshaft.
Old 03-11-2013, 02:09 PM
jim165 jim165 is offline
Mein Auto: 2008 BMW 550i Sport
So, what's causing this issue? Are the valve guides and seals just crap or does the 15K mile oil change interval cause this? Thanks for your offer to help...
2008 550i Sport-a.k.a. Hot Kraut Garbage
Others:
2006 Corvette Conv, Z51,6sp (wife)
2007 Honda CBR1000RR Sold
2005 Triumph Daytona 650 (wife) Sold
Old 03-11-2013, 02:22 PM
Past Sponsor
Mein Auto: X3
I think the seals are just no good. The smoke comes from the exhaust valve stem seals because they are running at a much higher temperature when compared to the intake side and fail earlier. The N62 and N62TU have this issue, not other BMW engines (for the most part). If the 15k oil service interval was the cause, then all engines would have this problem.
Old 03-11-2013, 03:22 PM
phlfly's Avatar
Mein Auto: 07' 550i
yes I guess it's one I don't remember seeing one on 5.0 L engine. I saw everything removed but spring is still there. But these guys don't remove valve block as I heard you do at BMW, and rebuild whole assy.
Old 03-13-2013, 03:09 PM
Past Sponsor
Mein Auto: X3
Bump, for anyone in New York that needs this repair done at a reasonable cost
Old 03-14-2013, 06:13 AM
micosan micosan is offline
Mein Auto: 550i
Originally Posted by phlfly View Post
Well I was wrong to say about valve seals in my posts, actually it's common thing on 4.4 L engines, after reading on 7-series forum. One guy did DIY for valve seals. But what more interesting my friend's shop just got car for valve seal on X5 with 4.4 L. They tried oil separator and didn't help. I took couple pictures for 4.4L engine.
Is the area circled burnt oil in the picture? If so, is it the reason the valve seals failed? Any history on the car to indicate the oil may be the reason for seal failure? Keif from the 7 series forum suggested the oil tubes may not be providing enough oil.
2007 550i Sapphire Black, Prod. Date 11/2006, Sport Pkg, Comfort Access, Navigation, TX, USA
Old 03-14-2013, 06:41 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
That is normal amount of sludge baked on to hot engine, I've seen it on all type of engine from 4-banger, I6 and V8.
That's a good hypothesis, could be oil starvation at start up where most of the wear occurs (both on cam lobes, valve guide and valve seals). From what people has been saying since it only happens on this particular BMW engine is because of design flaw.
Old 03-14-2013, 06:59 AM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
What is your mileage?
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 03-14-2013, 09:43 AM
Past Sponsor
Mein Auto: X3
Here's a pic of the last valve stem seal job I did. You can see the difference between the old and new seal. This engine had 69k miles, the valve guides measured within spec, no wear. No more smoking after replacing just the seals.
Old 03-14-2013, 11:17 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
That's the way mine looked , not really bad to the eye.I didn't measure but I've done valve seals on other cars that looked way worse not near the smoke or oil consumption as this n62.What do you think bmwoem1 ,why the wear and so much oil getting by if not that badly worn?This is such a common problem I think someone would have solved this out of curiosity by now.
Old 03-14-2013, 02:13 PM
Past Sponsor
Mein Auto: X3
Well, I know this for sure.... The oil leaks past the exhaust valve stem seals, not the intake side. The exhaust valves obviously run a lot hotter, which in turn cooks the exhaust valve stem seals. So, the oil is not leaking into the combustion chamber but directly into the exhaust manifolds. The spark plugs on these cars are clean. This is why the smoke is so bad out of the tail pipe. The oil is being vaporize by the heat of the manifolds, not burned up during the combustion process. The oil consumption is higher with this issue (in comparison to other engines/brands) because during a deceleration, the vacuum in the exhaust (scavenging effect) is higher than the vacuum in the intake. Valvetronic engines engines have close to 0 intake manifold vacuum when fully warmed up.
Old 03-14-2013, 02:44 PM
So crap, what you're saying is this seal problem is inevitable regardless of what we do to try to prevent it? And here I am, cutting my oil drain intervals in half in hopes of avoiding this issue. Man, as soon as I get this problem, I'm dumping some thick diesel engine oil in it and trading. Proof positive that BMW only engineers these cars to be leased...
Others:
Old 03-14-2013, 04:40 PM
phlfly's Avatar
Mein Auto: 07' 550i
Yes it will happen eventually. I will recommend do alternator bracket and after market cooling transfer pipe (http://www.bimmerzone.com/BMW_Perfor...-PIPE-N62.html) (PRT-URO-PIPE-N62).
Old 03-15-2013, 07:07 PM
phlfly's Avatar
Mein Auto: 07' 550i
couple pic from another 745, just recently was replaced alternator seal.
ID:	366587   Click image for larger version
ID:	366588   Click image for larger version
ID:	366589   Click image for larger version
ID:	366590   Click image for larger version
Old 03-15-2013, 07:22 PM
DIY'er
For those of you who have done alternator seal--do you put the new seal in dry or put some sort of sealant on it? Seems some good sealant couldn't hurt with how often they fail..
Old 03-16-2013, 03:14 AM
phlfly's Avatar
Mein Auto: 07' 550i
I forgot to mention, that my last post, person who owns the car has to replace catalytic because valve seals failed and oil had damaged catalytic converter. Just part itself 1,000 bucks. So if you have oil leak thru the valve seals, don't wait, fix it ASAP, otherwise another 3,000 bucks for repairs, since you have to remove all front engine subframe.
BMWOEM1, please confirm.
Old 03-16-2013, 05:12 AM
dolfan13's Avatar
Mein Auto: 545i
I am of the opinion much of these failures are premature because of the 105c operating thermostat.Ive tried modifying a stock tstat to run cooler but not much luck yet.
Old 03-16-2013, 07:42 AM
DIY'er
You do realize the thermostat is electronically controlled, right?
(although admittedly I don't know if it's 100% computer controlled or not. There's no telling with BMW)
Old 03-16-2013, 09:53 AM
Vapiano's Avatar
The video makes it seem like a doable job for most DIYers.
Old 03-16-2013, 10:29 AM
DIY'er
I agree, seems doable, just very time consuming and intimidating looking at first glance for most DIY'ers.
I'd be replacing most of the plastic hose crap hooked to the intake while I was at it--chances of getting all that off and back on without a crack somewhere is slim to none
Old 03-16-2013, 10:40 AM
phlfly's Avatar
Mein Auto: 07' 550i
If you have willing to drive to Leesburg VA, google European Service Center (Harrison St), ask for Patric and tell him you are from vadim and you want a discount for this job ( i don't make any money on it, just know him for more then 10 years). But as I said before at least do the cooling trasfer pipe, as intake is out anyway.
