Old 03-17-2013, 05:55 AM
JFIVE JFIVE is offline
Mein Auto: 545i
New hear and been reading this thread, I have an 05 545 with a 157,000 miles on it and when I purchased it had 136,000
Changed the oil twice between the miles that are on it now
First oil change took it on a 2 hour road trip then sat for an hour with the engine at idle then started seeing smoke then cleared up
Drove back 2 hours and the idrive came on for oil at minimum level
Went back to the service center where the oil was changed they added a quart and it never happened again smoke or low oil
Changed the oil at about 150,000 at 157,000 got the same smoke and low oil
Is this the beginning of valve seal failure or something else?
Sent from my SPH-L710 using Bimmer App
Old 03-17-2013, 06:37 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
it might hard to say. Check your oil level daily at dip stick. The most time when is blue smoke on idle that is valve seals are bad.
BMW CCA Member, Capital Chapter
Old 03-18-2013, 10:42 AM
Mein Auto: 545i
Thanks will check
Old 05-03-2013, 09:26 PM
Bitna Bitna is offline
Mein Auto: '06 550i
Can anyone recommend a BMW master tech with low overhead in west central Florida? I'm in Inverness but I'm willing to travel to have the seals replaced in my '06 550i as well as whatever else should be done while the genie is out of the bottle.
aTdHvAaNnKcSe
Old 05-03-2013, 09:38 PM
Mein Auto: '06 550i
I wonder if insulating the exhaust manifolds would keep some of the residual heat away from the guide seals thereby extending their life?
Ceramic coating?
Old 05-06-2013, 05:22 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Originally Posted by schpenxel View Post
You do realize the thermostat is electronically controlled, right?
(although admittedly I don't know if it's 100% computer controlled or not. There's no telling with BMW)
This thread already revived ,yes I do know it electronically controlled.A good write up on M62 mod YEP M62 controlling temp by fooling computer to open tstat.If temp lower already DME just won't open it.Ive been running this way ,95c for 7000 miles.Waiting on my UOA to return,but all seems ok.I simply shimmed under the tstat stem. Vette guys showed me this.
