Old 07-07-2012, 02:19 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
X5 2009 3.0 with 40k need help
X5 2009 3.0 with 40k what i need to change before warranty expires. What should I point to dealer.I drive 745i but it is my sister car i have no idea about X5. Thank you guys
I need any info. What ever problem u have with car let me know
engine
transmission
suspension
electric.
Old 07-08-2012, 10:46 PM
no help here?
Old 07-09-2012, 12:02 AM
Thirdy Thirdy is offline
Mein Auto: E70Diesel, E46
Dealership only go by computer base service. Not until computer says it's due for service or if nothing is wrong with car they are not going to do anything with your car
Old 07-09-2012, 12:06 AM
suspension, leaks, robber parts, any common problem computer wont tell you
Old 07-09-2012, 01:54 AM
ard ard is offline
Resident Curmudgeon
We could blather on for 200 pages with problems with the 2009 X5...NONE of this would do you any good.
Here is the only thing that works: Identify REAL problems- a leaking seal, a gasket that is weeping, a noise, a failed switch, noise while braking, etc, etc,... Make sure your complaint is placed on the work order.
BMW dealers WILL NOT find problems in cars based in "oh, could you check XYZ? My warranty will expire soon and I i hear the XYZ has failed before and is a common problem". They wont even LOOK at something unless it has an appropriate symptom you can verbalize and they can confirm.
Perosnally I just put the car up on the rack, insect everything- any cracked rubber, noises, hoses, leaks, electronic glitches all get mentioned inthe work order.
