Old 03-07-2015, 06:38 AM
Skavilla Skavilla is offline
Mein Auto: 2008 535i
2008 535i: possible coolant in oil
I own a 2008 535i. When changing my oil yesterday, it looked like there was coolant in the oil filter housing. Not completely sure but it looked "greenish". I have not done a test on the captured oil from the oil change yet. Anyone know what this could be caused by? I hear a blown head gasket, maybe? Would I see oil in the coolant reservoir if head gasket blown?
Old 03-07-2015, 09:02 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Pics of the problem would help. Also, pics into the oil fill on the head, as well as the oil fill cap.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 10+ Years
Old 03-07-2015, 02:19 PM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
is the oil-filter housing gasket leaking?
OK, see the picture, that section on the lower left is where coolant and the top one where oil is, overtime the gasket breaks down, when that happens coolant can mix with oil.
Old 03-07-2015, 02:26 PM
DJtoad DJtoad is online now
Mein Auto: 2010 535i M Sport
+1 for the oil filter housing gasket.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
JB4 G5 ISO, BMS DCIs, ER Charge Pipe with Forge DVs, Proform Clear Bra, LUX H8 160 LED angel eyes
Old 03-07-2015, 04:32 PM
I will check that tmrw. Thanks for the heads-up.
If it is that gasket, and not something more major, would there be oil in the coolant reservoir, as well? Is that gasket failure more of a "one-way" leak, or does it leak back and forth?
Btw, car is still running great, no smoke in the exhaust, no overheating, no codes.....
Old 03-08-2015, 05:48 AM
if it's OFH gasket it would be two way leak but it's small, but I noticed yogurt like substance on my oil cap when I still had the OFH leak.
the other possible things:
1) I noticed is oil can get onto upper radiator hose when OFH leaks, it swell and oil albeit small quantity can sip into the coolant.
2) you have moisture in oil from condensation and not driving long distance very often.
I'd fix the OFH leak soon, oil and rubber just don't mix, it ruins the upper radiator hose and serpentine belt if it drips even more overtime.
Old 03-08-2015, 07:18 AM
Thanks for all the help. I will tackle that Monday. I want to have the gasket in hand before I open it up. Assuming one of my local BMW $tealers will have one in stock. Online, they are about $15. Can't wait to see what the $tealer charges.
I assume a coolant flush and refill is in order, as well. Getting mixed opinions on that one. Some say antifreeze is antifreeze, green stuff is ok. Others say no, use the BMW blue stuff.
Anyone care to opine?
Old 03-08-2015, 07:47 AM
banglenot's Avatar
Mein Auto: 2007 530
Use the BMW. The green stuff is clearly wrong and shouldn't be used. There are others that are compatible with BMW engines, but the BMW is $25 per gallon and only one gallon is needed when mixed with 1 gallon of distilled. Since a flush is 2-4 years apart, the relative price diff is meaningless.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
2008, 5353i, coolant in oil
