Closed Thread
Old 07-21-2012, 01:35 AM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW F01
Ace, do you know which hex value to change to set the comfort access yet?
How far off are you from trying this out?
This is the hex value data for the coding options, the comfort access values that we currently know of are stored in line 3004 at position number 0:
Code:
CODIERDATENBLOCK : {00003004} 00000000 000B "PA"
PARZUWEISUNG_FSW : {00003004} 00000000 0001 0A81 {} (01) {h} {} // PASSIVE_ACCESS
PARZUWEISUNG_PSW1 : 0007 (01) // aktiv
PARZUWEISUNG_PSW1 : 000B (00) // nicht_aktiv
PARZUWEISUNG_FSW : {00003004} 00000000 0001 01EC {} (02) {h} {} // PASSIVE_ENTRY
PARZUWEISUNG_FSW : {00003004} 00000000 0001 01ED {} (04) {h} {} // PASSIVE_GO
PARZUWEISUNG_FSW : {00003004} 00000000 0001 0201 {} (08) {h} {} // PA_INTERBROADCAST_DELAY
PARZUWEISUNG_FSW : {00003004} 00000000 0001 0202 {} (10) {h} {} // PA_CONFIG_FBDLONG
PARZUWEISUNG_FSW : {00003004} 00000000 0001 0203 {} (20) {h} {} // PA_CONFIG_FBDREFCHECK
PARZUWEISUNG_FSW : {00003004} 00000000 0001 0A87 {} (40) {h} {} // PA_GETRIEBESPERRE_VR
UNBELEGT1 : {00003004} 00000000 0001 {} (80)
UNBELEGT2 : (00)
The bit masks are in the brackets, with this info you should be able to read your CAS, convert the value at position 0 to binary and decode what options are set, then add in the comfort access option.
DFEL750I has value 0x11 at position 0 on line 3004.
in binary this is: 00010001
From the table above passive access coding info is stored at bit 1 of the first byte(bit mask = 0x01), if its a 1 its active a 0 not active.
The 0x01 in binary is 0001, transpose this over the original hex value:
00010001 = orig value at 3004 pos 0
xxxx0001 = bit mask for comfort/passive access
The bits are identical meaning passive access is active in DFEL750I's car... but we already knew that!
The above info is from a .C03 file, the .C04 and .C05 look the same.
Hope this helps??? Im pretty confident just sticking 0x11 in pos 0 in line 3004 will work.
Stuart
  #102
Old 07-21-2012, 02:37 AM
AceFX AceFX is offline
Banned
Mein Auto: BMW 760Li BMW X5 4.8iS
This is great, we are all getting into it. I had a lazy day today. Too much chat on the fest so I didn't look at the CA at all except for the last hour of today. I have been working with the codes sent to my by DFEL750I....I am sure this will work
  #103
Old 07-21-2012, 02:55 AM
Mein Auto: BMW F01
Hmm... Just checked my floor pan area on the front passenger side. There is no provision for the antenna!?
It looks like the plastic part can easily be replaced though!
2008 F01 - Sophistograu with Saddle Brown Leather
Retrofits:
Night Vision, Digital TV, Heated M-Sport Steering Wheel + Paddles, Combox, 6NF Baseplate, 6NR Apps, Rear Entertainment System, Automatic Boot Close and Surround View Cameras.
  #104
Old 07-21-2012, 03:13 AM
Banned
Watch the video, there are two plastic clips holding it in place. Remove the clips and then slide the plastic cover out of the way and you will then see the mount in the foam under the plastic cover.
  #105
Old 07-21-2012, 03:50 AM
Banned
Hey StuartJohn what program are you using to get your files......?
  #106
Old 07-21-2012, 03:55 AM
Mein Auto: BMW F01
Sorry ACE! Its at the end of the I didn't watch all of the vid and immediately went out to have a look. Please accept my apologies! I saw the two clips holding the plastic cover on which forms part of the wire harness guide.
I hear your face lifting the exterior, so won't be completing the install till then. Great work keep us updated!
Stuart
Retrofits:
  #107
Old 07-21-2012, 04:34 AM
Banned
I will complete the Comfort Access in about two or three days. Facelift is not going to stop me getting the CA going.
  #108
Old 07-21-2012, 04:55 AM
Banned
Your right StuartJohn.
  #109
Old 07-21-2012, 05:14 AM
Banned
Comparing coding from my car guys.....
  #110
Old 07-21-2012, 05:18 AM
Banned
There are some changes
  #111
Old 07-21-2012, 05:20 AM
Mein Auto: BMW F01
Hey ACE, awesome! So it's working now? Does it work with the old key?
You just coded the bit in the first byte of line 3004???
Retrofits:
  #112
Old 07-21-2012, 05:26 AM
Mein Auto: BMW F01
Originally Posted by AceFX View Post
Hey StuartJohn what program are you using to get your files......? If I understand you correctly, are you saying the CA code is pos 1 of line 3004?
PS: Did you watch the video in Post 77 yet? I am curious to know the result of what is under the plastic cover under the carpet These plastic cover shields are only in the front, not the back.
Sorry didn't see this post. All information I have supplied is from the CAS files in the NCS/INPA DATEN folders. If you disassemble the coding files it shows what bits and bytes change what options. It maybe very useful for you as your using dashsoft!
Retrofits:
  #113
Banned
The CA is now active.
  #114
Old 07-21-2012, 05:30 AM
Banned
You need the wiring loom etc........
  #115
Old 07-21-2012, 05:41 AM
Banned
And the nay sayers said it couldn't be done!
  #116
Old 07-21-2012, 05:42 AM
Mein Auto: BMW F01
Ha ha! Well let's wait and see, how do you know it's now active?
I'm still very interested to know why there are two versions of the CAS. I know earlier versions of the light modules were specific to xenon or halogen, later modules LM2 for example can be coded for either. Perhaps it's something similar or a subtle hardware/functional change that differs them.
Great work so far! Any change of getting the key coded quicker! Lol
Stuart
Retrofits:
  #117
Old 07-21-2012, 05:46 AM
Banned
Oh Ye of little faith
but if it did turn to custard....... I am the KING of POST post editing...... just ask PAPER
  #118
Old 07-21-2012, 06:06 AM
Banned
In this video I demonstrate the Comfort Access system is now active and that I just need to get the key coded.
  #119
Old 07-21-2012, 06:19 AM
Mein Auto: BMW F01
I will be happy when I see it working fully with the standard CAS!
I'm going to start pricing this up soon, will double check wiring is in the doors etc...
Will most likely make the harnesses myself for the antennas, there is no way I'm going to be able to find it at a breakers! Nor will they remove it for me!
Tyco electronics are quite generous with the samples so hopefully should be able to get something put together properly!
Retrofits:
  #120
Old 07-21-2012, 06:23 AM
Banned
I got everything I needed from a salvage yard in the States
  #121
Old 07-21-2012, 06:26 AM
Mein Auto: BMW F01
Just checked again I have the mouldings as you say, just removed the plastic cover.
Even got a cheeky footprint too ha ha!
Stuart
ID:	333675   Click image for larger version
Retrofits:
  #122
Old 07-21-2012, 06:28 AM
Banned
Awesome....you good to go!
  #123
Old 07-21-2012, 06:33 AM
Mein Auto: BMW F01
I got everything I needed from a salvage yard in the States, and I live in Oz. eima_95 on eBay. He is a very good and highly recommended salvage yard. His name is Nabil. He removed the entire harness, the Passive Go module and all the antennas I needed for about $250 to $300 if I remember right
Is that Australian dollars? That a great price! I'm in the UK, we don't get many wrecked 7's around my way. There is a specialist breakers 50miles away but they are expensive and pretty difficult to deal with. They don't have any with CA in at the moment.
Retrofits:
  #124
Old 07-21-2012, 06:35 AM
Mein Auto: BMW F01
Video is great by the way! Looks like its definitely going to work! Glad we don't have to mess around changing the CAS, that was scaring me a little!
Retrofits:
  #125
Old 07-21-2012, 06:38 AM
Banned
USD Stuart, I get all my parts from the States. There are no specialist BMW salvage yards here either. I have dealt a lot with Nabil and he is always fair, goods always arrive quickly and are always in perfect condition. I highly recommend him. He is dismantling a whole lot of 7's.
Check him on ebay http://stores.ebay.com.au/Esra-Motor...id=p4340.l2563
Closed Thread
