7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#126
Thanks, I will keep an eye out, there are three PA modules on ebay UK at the moment, Do you still have a set of antennas ACE? I may be interested, looks like its going to run in at around £250 - £300 for a set of new antennas from the dealer. then just need to find some handles and a new key and get it programmed!
Stuart |
#127
I have the four footwell antennas, CAS, DME and the Passive Go module $200 AUD plus postage = about 132 GBP plus postage
#128
I'm happy it all worked out with the CAS. I suspected that would be the case and it's good that our logic followed through. I'm having some issues with my driver's door handle. Hopefully I can find a sapphire black one on eBay.
Hey ACE,
I didnt get some of your posts, the app on my phone was not updating properly earlier! I'm just posting to tie up loose ends... Its line 3004 position 0, im sure you know that now though! ![]() I notice you had 0x50 in position 0, rather than 0x11, translating this shows you have the following two options set: PA_CONFIG_FBDLONG PA_GETRIEBESPERRE_VR DFEL750I had the first one too, not sure what they mean, second one is something to do with the gearbox park gear??, but german abbreviations make translation difficult! To maintain the original coding but just ADD comfort access you should have changed pos 0 from 0x50 to 0x51. I have no idea what difference having the PA_GETRIEBESPERRE_VR option set does!? ![]() Stuart |
#131
WoW Ace you sure did a lot of editing in your recent post .
You should have left that info up , All of it was good . Specially the line & code comparison of your car & DFEL750I car . YOU NEED TO LEAVE THE EDIT BUTTON ALONE MR. KING OF EDITING ... LOL JOKE !!!
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
#132
ACE, PAPER,
How do I go about getting a comfort access key fob programmed to my car? Can the dealer do this with a used key? I thought I saw a post from ACE saying PAPER had a DIY on key programming, I can't seem to find the DIY though...? Thanks, Stuart |
#133
Hey PAPER, StuartJohn and DFEL750I....can you guys help me with some NCS info please?
I am retrofiiting FLA (Auto Highbeam) and Adaptive Headlights to my car. Can you please look at the coding in the LM (Light Module) and see if you can find out what the codes are to change in the LM to activate FLA and Adaptive Headlights please. I am going to try and find NCS and load it soo so I cna learn about it....... can you guys give me some pointers please? Regards Ace
#134
Hey ace will have a look later for you, don't have my laptop with me at the moment.
One thing first... I managed to pull the door handles from the passenger front and rear doors... No harness for the CA, well at least nothing that can be seen/tucked away that would be accessible without removing the door card. I do have soft close doors, what build date is your 7? Mine is one of the early ones, I received the original March 2002 price list brochure in the post today and CA was an option but not until June 2002 in the UK. I'm afraid as my car was built Nov 2001 the CA was not yet implemented or finalised and the door loom does not include the CA harness. Bummer! Bit of extra work! Will have a look at wiring diagrams later, this may be too much hassle for me to retrofit if there is loads of bits missing from the looms. Stuart |
#135
Hi Stuart, it's OK. It is a very simple change to your existing door loom. Your door loom is actually in two pieces. One does all the door things, lock, windows, light, airbag etc....and then a small and seperate loom that plugs into that main loom in the door, is the one that will gives you CA and SC. Brand new they are $50 each, but I know you can get these from a Salvage yard in the US for $20 - $25 each.
#136
Do you have the original LM fitted? And not the LM2?
A word of warning, myself and PAPER have both bricked out light modules whilst coding, the early ones are a bit sensitive, this was whilst changing the vehicle order code, it maybe something to do with that and normal coding for functionality may be ok. Anyway I will have a look later, may take a little while it's a very big coding file! A lot more info in there than the MMI! Stuart |
#137
Thanks Stuart
#138
Wow taking those door cards off is a real PITA! Especially with rear blinds! Stuart |
#139
The PA Bus wire is just a feed from the Antenna (the door handle) that goes to the connector block. The door module does not supply power to the door handle. I do not believe any coding of the door module is required because only one part number is listed by BMW for all door modules since production 2001 to 2008
#140
I should have the files on my computer somewhere. They are too large to email but maybe we can upload it to a free FTP site if we can find one. I am not home but when I get home I can pull the coding from the LM module for you. I do have adaptive headlights in my car. Once you get up and running on NCS is will be very easy to compare coding between two modules so we can easily see what the differences are in coding. There is a program built to compare 2 NCS coding files and show the difference.
)Use something like winmerge to see any differences.. FSW_PSW [E65-LM2_E6X.C34].TRC Code:
KALTUEBERWACHUNG_FL_L aktiv KALTUEBERWACHUNG_FL_R aktiv KALTUEBERWACHUNG_SL_V_L aktiv KALTUEBERWACHUNG_SL_V_R aktiv KALTUEBERWACHUNG_NSW_L aktiv KALTUEBERWACHUNG_NSW_R aktiv KALTUEBERWACHUNG_BLK_V_L aktiv KALTUEBERWACHUNG_BLK_V_R aktiv KALTUEBERWACHUNG_BLK_H_L aktiv KALTUEBERWACHUNG_BLK_H_R aktiv KALTUEBERWACHUNG_BL_L nicht_aktiv KALTUEBERWACHUNG_BL_R nicht_aktiv KALTUEBERWACHUNG_BL_M_1 nicht_aktiv KALTUEBERW_RL_BL_1_L nicht_aktiv KALTUEBERW_RL_BL_1_R nicht_aktiv KALTUEBERW_RL_BL_2_L nicht_aktiv KALTUEBERW_RL_BL_2_R nicht_aktiv KALTUEBERWACHUNG_KZL_L aktiv KALTUEBERWACHUNG_KZL_R aktiv KALTUEBERWACHUNG_RFS_L aktiv BI_XENON_BEI_LH nicht_aktiv KALTUEBERWACHUNG_RFS_R aktiv TASTVERH_BEL_WBL_MIN wert_02 ZUWACHS_TASTVERH_WBL_BEL wert_01 WARMUEBERWACHUNG_FL_L aktiv WARMUEBERWACHUNG_FL_R aktiv WARMUEBERWACHUNG_AL_L aktiv WARMUEBERWACHUNG_AL_R aktiv WARMUEBERWACHUNG_SL_V_L aktiv WARMUEBERWACHUNG_SL_V_R aktiv WARMUEBERWACHUNG_NSW_L aktiv WARMUEBERWACHUNG_NSW_R aktiv WARMUEBERWACHUNG_BLK_V_L aktiv WARMUEBERWACHUNG_BLK_V_R aktiv WARMUEBERWACHUNG_BLK_H_L aktiv WARMUEBERWACHUNG_BLK_H_R aktiv WARNBLK_TASTE_KL58G nicht_aktiv WARMUEBERWACHUNG_KZL_L aktiv WARMUEBERWACHUNG_KZL_R aktiv WARMUEBERWACHUNG_RFS_L aktiv WARMUEBERWACHUNG_RFS_R aktiv FEHLERMELDUNG_CC_RFS_L aktiv FEHLERMELDUNG_CC_RFS_R aktiv TASTVERH_KL_58G_MIN wert_01 ZUWACHS_TASTVERH_KL_58G wert_01 VERHALTEN_UEBERWACHUNG wert_01 FEHLERMELDUNG_CC_FL_L aktiv FEHLERMELDUNG_CC_FL_R aktiv FEHLERMELDUNG_CC_AL_L aktiv FEHLERMELDUNG_CC_AL_R aktiv FEHLERMELDUNG_CC_SL_V_L aktiv FEHLERMELDUNG_CC_SL_V_R aktiv FEHLERMELDUNG_CC_BLK_V_L aktiv FEHLERMELDUNG_CC_BLK_V_R aktiv FEHLERMELDUNG_CC_BLK_H_L aktiv FEHLERMELDUNG_CC_BLK_H_R aktiv FEHLERMELDUNG_CC_KZL_L aktiv FEHLERMELDUNG_CC_KZL_R aktiv LEUCHTDICHTE_EXPO nicht_aktiv LENKWINKEL_UEBERSCHREITEN wert_01 LENKWINKEL_UNTERSCHREITEN wert_01 LENKSTOCK_UMSCHALT_VERZ wert_01 U_POTI_DIMM_MIN wert_02 U_POTI_DIMM_DELTA wert_02 MELDUNG_AENDERUNG_DIMMER wert_01 POTI_DIMM_INVERS aktiv POTI_LWR_INVERS nicht_aktiv HEIMLEUCHTEN wert_02 HEIMLEUCHTEN_VERLAENG nicht_aktiv BLINKIMPULS_WARNBLK wert_01 CRASH_58G_EIN aktiv BLINKIMPULS_CRASHBLK wert_01 WERT_CRASHVERHALTEN wert_01 CRASH_WARNBLINKEN aktiv NOTLAUF_FKT_SCHALTERSTELL aktiv PWM_ANSTEUERUNG_BL_M_1 wert_01 WARNBLK_ENERGY_SAVE_MODE aktiv LWR_TREIBER_CODIERUNG_2 wert_01 TIPP_BLK_LOESCHT_IMMER aktiv HEIMLEUCHTEN_ABBRUCH nicht_aktiv LWR_TESTBETRIEB nicht_aktiv LWR_FEHLER_BEWERTUNG wert_02 LWR_SCHRITTABSTAND_GRENZE wert_01 LWR_TEMPERATUR_GRENZE grad_-20 SCHRITTABSTAND_STARTPHASE wert_01 KEINE_PARKLICHT_FUNKT nicht_aktiv HALB/VOLLSCHRITT halbschritt U_LWR_POTI_STELLUNG_0 wert_01 U_LWR_POTI_STELLUNG_1 wert_01 U_LWR_POTI_STELLUNG_2 wert_01 AUTOM_LICHT_ABSCHALTUNG nicht_aktiv NOTLAUF_FKT_GESCHW wert_01 LOAD_DUMP_SCHUTZ_AKTIV aktiv LOAD_DUMP_MAX_TIME wert_01 LOAD_DUMP_PRELL wert_03 LOAD_DUMP_SCHUTZ_KL58G aktiv DEF_HEIMLEUCHTEN_CKM wert_02 LOAD_DUMP_DIMM_WERL_BLK wert_01 AL_KL50_SCHUTZ nicht_aktiv PWM_ANST_RL_BL_1_BL wert_03 PWM_ANST_RL_BL_2_BL wert_02 SL_V_PARKL_FKT aktiv RL_BL_PARKL_FKT nicht_aktiv SL_V_PO_RL_FKT aktiv RL_BL_1_PO_RL_FKT aktiv RL_BL_BREMSL_FKT aktiv RL_BL_2_BREMSL_FKT nicht_aktiv ALC_ERR_BLK_FREQ wert_01 BFD_1_RL_BL_1_ERSCH_BILD wert_01 BFD_1_RL_BL_2_ERSCH_BILD wert_01 BFD_1_BL_M_ERSCH_BILD wert_01 BFD_1_RL_BL_ERSCH_BILD wert_01 BFD_1_NSL_ERSCH_BILD wert_01 BFD_1_WEGFALL nicht_aktiv BFD_1_MIN_GESCHW wert_01 BFD_1_THERM_TIMEOUT wert_01 BFD_1_WERT_AX_RUCK wert_01 BFD_1_STUFE_DELAY wert_01 BFD_1_BLINK_FREQ_AUS wert_01 BFD_1_BLINK_FREQ_EIN wert_01 BFD_1_ENTPRELL_ABS wert_01 BFD_1_ENTPRELL_AX wert_01 BFD_2_ALGORITHMUS nicht_aktiv BFD_2_RL_BL_1_ERSCH_BILD wert_01 BFD_2_RL_BL_2_ERSCH_BILD wert_01 BFD_2_BL_M_ERSCH_BILD wert_02 BFD_2_RL_BL_ERSCH_BILD wert_01 BFD_2_NSL_ERSCH_BILD nicht_aktiv BFD_2_WEGFALL nicht_aktiv BFD_2_MIN_GESCHW wert_01 BFD_2_THERM_TIMEOUT wert_01 BFD_2_WERT_AX_RUCK wert_01 BFD_2_STUFE_DELAY wert_01 BFD_2_BLINK_FREQ_AUS wert_03 BFD_2_BLINK_FREQ_EIN wert_03 BFD_2_ENTPRELL_ABS wert_01 BFD_2_ENTPRELL_AX wert_01 ALC_FAHRZEUG aktiv LWR_ANSTEUERN nicht_aktiv FL_UND_NSW_NICHT_GLEICHZ nicht_aktiv SIDEMARKER_US nicht_aktiv WARMUEBERWACHUNG_NSL_R aktiv KALTUEBERWACHUNG_NSL_L aktiv KALTUEBERWACHUNG_NSL_R aktiv WARMUEBERWACHUNG_NSL_L aktiv FEHLERMELDUNG_CC_NSL_L aktiv FEHLERMELDUNG_CC_NSL_R aktiv BFD_1_ALGORITHMUS aktiv BFD_1_WERT_AX_EIN wert_02 wert_03 BFD_2_WERT_AX_EIN wert_01 XENON_LI wert_01 wert_02 XENON_AL_VERBAUT aktiv KALTUEBERWACHUNG_AL_L nicht_aktiv KALTUEBERWACHUNG_AL_R nicht_aktiv LWR_HYSTERESE_START wert_02 LWR_VORBESTROMUNG wert_02 QUITT_BLK_SICHERN nicht_aktiv QUITT_BLK_ENTSICHERN nicht_aktiv TAGFAHRLICHT_ECE nicht_aktiv DEF_TAGFAHRLICHT_ECE_CKM nicht_aktiv AUTOM_LICHT_KONTROLLE aktiv COMFORT_ACCESS_LICHT aktiv STANDKLIMA nicht_aktiv WARMUEBERWACHUNG_BL_L nicht_aktiv WARMUEBERWACHUNG_BL_R nicht_aktiv WARMUEBERWACHUNG_BL_M_1 nicht_aktiv WARMUEBERW_RL_BL_1_L nicht_aktiv WARMUEBERW_RL_BL_1_R nicht_aktiv WARMUEBERW_RL_BL_2_L nicht_aktiv WARMUEBERW_RL_BL_2_R nicht_aktiv FEHLERMELDUNG_CC_BL_L aktiv FEHLERMELDUNG_CC_BL_R aktiv FEHLERMELD_CC_RL_BL_1_L aktiv FEHLERMELD_CC_RL_BL_2_R aktiv FEHLERMELD_CC_RL_BL_1_R aktiv FEHLERMELD_CC_RL_BL_2_L aktiv PWM_ANST_FL_BIXENON wert_03 MIND_ANZ_ZYKL_TIPP_BLK wert_02 DEF_ZYKL_TIPP_BLK_CKM wert_02 BFD_1_DEAKTIV_BEI_NSL aktiv BEHOERDEN_FZG nicht_aktiv BEHRD_FZG_ASYNCHRON_BLK nicht_aktiv DUAL_SP__AL_L nicht_aktiv DUAL_SP__AL_R nicht_aktiv DUAL_SP__NSL_L aktiv DUAL_SP__NSL_R aktiv DUAL_SP__NSW_L aktiv DUAL_SP__NSW_R aktiv DUAL_SP_PARAMETER wert_01 PWM_ANSTEUERUNG_NSW wert_01 QUITT_BLK_IGNORE_MOTORH nicht_aktiv DUAL_SP__FL_L aktiv DUAL_SP__FL_R aktiv DUAL_SP__KZL_L aktiv DUAL_SP__KZL_R aktiv DUAL_SP__SL_V_L aktiv DUAL_SP__SL_V_R aktiv GESCHW_DOWN wert_01 wert_02 GESCHW_UP wert_01 wert_02 PROZENT_EE wert_01 ALC_SCHWENK_BEI_S_FLC nicht_aktiv FLC_OHNE_RLS nicht_aktiv UNTERDRUECK_BL_BLITZEN nicht_aktiv TIPP_BLK_ABBRUCH aktiv TIPP_BLK_ABBRUCH_IMMER aktiv ABSCHW_D_TAU_HI wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 ABSCHW_D_TAU_LO wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 ABSCHWAECH_D_TAU wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 ABSTELLPOS_CUSTOM nicht_aktiv ABSTELLPOS_SMC aktiv AEND_V_SCHWENK_N_AUSSEN wert_01 wert_04 wert_07 wert_11 wert_16 ALC_ABSENKUNG_10_KM/H wert_01 wert_04 wert_05 wert_06 wert_07 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_ABTASTRATE_DYN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_ABTASTRATE_TREND wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_ABWEICHUNG_TREND wert_01 wert_04 wert_05 wert_06 wert_07 ALC_ANHEBUNG_175_KM/H wert_01 wert_04 wert_05 wert_06 wert_07 wert_10 wert_12 wert_13 wert_14 wert_15 ALC_AUSWERT_GRADIENT aktiv ALC_AUSWERT_PROP_ABWEICH aktiv ALC_DAUER_DYN_NACHFUEHR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_DEF_LWR_SENSOR_HI wert_01 wert_04 wert_07 wert_12 ALC_DIFFERENZ_MSP_DYN_STA wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_EINSCHALTBEDINGUNG wert_01 ALC_EPSILON_DELTA_A wert_07 ALC_EPSILON_DELTA_AV wert_01 wert_04 wert_07 ALC_GRADIENT_SCHLECHTWEG nicht_aktiv ALC_HOEHENWEG wert_01 wert_04 wert_05 wert_06 wert_07 ALC_KENNLIN_LWR_SENSOR_HI wert_01 wert_04 wert_07 wert_13 wert_18 wert_20 ALC_KENNLIN_LWR_SENSOR_VO wert_07 ALC_KLS_ENABLE aktiv ALC_LWR_NEIGUNG_KONSTANTE wert_07 ALC_LWR_VORZEICHEN vorn_aktiv ALC_MIN_STEIGUNG_VZ_WECHS wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_MINDESTANZAHL_VZ_WECH wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_12 wert_13 wert_14 wert_15 ALC_MITTELUNGSINT_VZ_WECH wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_MITTELUNGSINTERV_DYN wert_01 wert_04 wert_07 wert_11 wert_16 wert_17 ALC_MITTELUNGSINTERV_TREN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_NACHLAUF_SCHLECHTWEG wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_SAETT_TIMER_SCHLECHTW aktiv ALC_SCHW_GRAD_BESCHLEUNIG wert_01 wert_04 wert_07 wert_19 ALC_SCHW_GRAD_BREMSEN wert_01 wert_04 wert_07 wert_19 ALC_SCHW_GRAD_SCHLECHTWEG wert_01 ALC_SCHW_PROP_ABWEICHUNG wert_01 wert_04 wert_07 wert_15 ALC_SCHW_TREND wert_01 wert_04 wert_05 wert_06 wert_07 ALC_SCHWENK_LATCH aktiv ALC_VMAX_BESCHLEUNIGUNG wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 ALC_VMAX_BREMSEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 ALC_VMIN_BESCHLEUNIGUNG wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 ALC_VMIN_BREMSEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 wert_17 C_METER_NACH_INNEN_HI wert_07 CAN_11H nicht_aktiv D_TAU_MITTEL_GIERR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 D_TAU_MITTEL_LENKW wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 DRIFT_DEKR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 DRIFT_INKR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 DRIFT_SCHWELLE wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 ERR_LWR_L_IGNORIEREN nicht_aktiv ERR_LWR_R_IGNORIEREN nicht_aktiv ERR_SCHWENK_L_IGNORIEREN nicht_aktiv ERR_SCHWENK_R_IGNORIEREN nicht_aktiv IK_BUS_TEILNEMER nicht_aktiv KEINE_L_R_SYNCHRONISATION nicht_aktiv KENNL_MAX_UEBERST wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 KENNL_REDUZ_MAX_SCHWENK wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 KLASSIF_DRIFT_ENA aktiv KLASSIF_LENKM_ENA aktiv KLASSIF_UEBERST_ENA aktiv KLS_BEI_AL_AKTIV nicht_aktiv LENK_UEBERSETZUNG wert_11 LENK_UEBERSETZUNG_LO wert_01 wert_02 wert_05 wert_06 wert_07 wert_08 wert_09 wert_10 wert_11 wert_14 wert_15 wert_16 wert_17 wert_18 wert_19 wert_20 LICHTZ_R_L_FAKTOR wert_05 wert_06 wert_07 wert_09 wert_10 wert_12 wert_13 wert_14 wert_15 wert_17 wert_18 wert_19 wert_20 LINKSVERKEHR aktiv MAX_DELTA_KEINE_VERR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MAX_SW_SCHWENK_V_HORIZ wert_01 wert_04 wert_07 wert_11 wert_16 MAX_SW_SCHWENK_V_VERTI wert_01 wert_04 wert_07 wert_11 wert_13 wert_14 wert_15 wert_16 wert_17 wert_18 wert_19 wert_20 wert_21 wert_22 MAX_SW_SCHWENK_W_AUSSEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_10 wert_12 wert_14 wert_15 wert_16 wert_18 MAX_SW_SCHWENK_W_INNEN wert_01 wert_04 wert_07 wert_10 wert_11 wert_12 wert_16 MAX_VERRINGERUNG_V_SCHW wert_01 wert_04 wert_07 wert_11 wert_16 MERKM_1_BEGR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MERKM_1_DEKR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MERKM_1_INKR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MERKM_1_MAX wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MIN_DELTA_MAX_VERR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 NORM_LEUCHTWEITE wert_07 OHNE_GIERRATE nicht_aktiv RAUSCH wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 RECHTSVERKEHR nicht_aktiv REDUZIERUNG_V_SCHWENK_HI wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 REDUZIERUNG_V_SCHWENK_LO wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 SCHALTER_R_GANG nicht_aktiv SCHW_TAU_LW_GR wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 SW_NULL_BEREICH wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_F_GIERRATE_DEF wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_DYN_LZ wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_GIERRATE wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_LENKWINKEL wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_TAU_LW wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_UEBERST wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_V_VEH wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 TAU_ABSCHWAECHUNG wert_01 wert_04 wert_07 wert_11 wert_15 wert_16 V_HI_ABSCHW_D_TAU wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_AENDER_LENK_UEBERS wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_RED_SCHWENK_W wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_REDUZIER_V_SCHWENK wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_SW_MITLENKEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_SW_NACH_INNEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_TAU_GIERRATE wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_ABSCHW_D_TAU wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_AENDER_LENK_UEBERS wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_RED_SCHWENK_W wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_REDUZIER_V_SCHWENK wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_SW_MITLENKEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_SW_NACH_INNEN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_TAU_GIERRATE wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_M_HI_REDUZIER_V_SCHWENK wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_M_LO_REDUZIER_V_SCHWENK wert_01 wert_04 wert_05 wert_06 wert_07 wert_11 wert_16 V_REFERENZLAUF_EN wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 ZEITK_TRIGGER1 wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 QUITT_BLK_ZU_CHECK_1 aktiv SMART_BEAM aktiv IBUS_R_GANG nicht_aktiv FL_ASSIST_FUNKTIONS_ANZ nicht_aktiv LWR_TERMO_MODEL_EIN aktiv HEIMLEUCHTEN_ENABLE aktiv NSL_BREMSL_FKT nicht_aktiv HECKD_REV_BLK_DOPPELB aktiv HECKDECK_REVERS_BLK wert_00 ALC_NSW_BEDIEN_MOEGL aktiv CC_MELD_SW_CI_NOT_AKTIV nicht_aktiv CI_KODIERDATEN wert_01 FL_ASSIST_CC_NOT_AKTIV nicht_aktiv FL_ASSIST_ZUST_22_32 aktiv NEUE_FAHRT_BEI_SICHERN aktiv NEUE_FAHRT_BEI_SLEEP aktiv NEUE_FAHRT_KL_15_NACHL nicht_aktiv ALC_FAILSAVE_AHL aktiv FL_AUS_BEI_BIX_IN_S_FLC aktiv FSP_MASKIERUNG wert_01 ISP_MASKIERUNG wert_01 LS_UMSCHALT_FEHLER_ZEIT wert_01 DEF_QUITT_BLK_ENTSI_CKM nicht_aktiv DEF_QUITT_BLK_SICH_CKM nicht_aktiv ALC_CC_127_ZUST_4_OFF aktiv ALC_CC_127_ZUST_5_OFF aktiv ALC_CC_AL_OFF nicht_aktiv ALC_CC_ALC_ERR_OFF nicht_aktiv ALC_DEFEKT_TIMER wert_01 ALC_EIN_DAEMMERUNGSSTUFE wert_01 ALC_ENPRELL_AL_NIO wert_01 ALC_ENPRELL_AL_OK wert_01 ALC_ERR_NSW_ZUSCHALTEN aktiv ALC_REF_LAUF_AL_AUS wert_01 ALC_ZUSTANDS_AUTOM wert_02 HEIMLEUCHTEN_FUNKSCHL aktiv CHECK_FGN_SMC_ALC_OFF aktiv MIN_SW_SCHWENK_V_HORIZ wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 LWR_ABSTELLPOS wert_01 ABBIEGELICHT_CKM_0 nicht_aktiv ABBIEGELICHT_CKM_1 nicht_aktiv ABBIEGELICHT_CKM_2 nicht_aktiv ABBIEGELICHT_CKM_3 nicht_aktiv ABBL_LZ_RKW wert_01 ABK_KNICK wert_01 ABK_MIN_PROZ wert_01 ABK_VERLAENG wert_01 ABSCHALTUNG_RFS_1 aktiv ABSCHW_D_TAU_HI_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 FL_ABSCHALT_OPT nicht_aktiv MAX_BETAETIGUNG_FOMEHO wert_01 UMSCHALTOPT_LICHTSCHALTER aktiv ABSCHW_D_TAU_LO_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 BLEND_CHECK_IST_WINKEL aktiv BLEND_CHECK_SOLL_WINKEL nicht_aktiv CKM_ALC wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 CKM_ALC_DEF wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MIN_SW_SCHWENK_V_VERTI wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 WINKEL_BLENDUNG wert_01 ABSCHWAECH_D_TAU_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 AEND_V_SCHWENK_N_AUSSE_SP wert_01 wert_04 wert_07 wert_11 wert_16 AHL_MODE_CKM_0 wert_01 AHL_MODE_CKM_1 wert_01 AHL_MODE_CKM_2 wert_01 AHL_MODE_CKM_3 wert_01 ALC_ERR_BLK_AL_EIN aktiv ALC_SCHWENK_IM_STAND aktiv AUTO_LWR_ENABLE_LM2 aktiv BFD_2_DEAKTIV_BEI_NSL nicht_aktiv BL_2_PARKL_FKT nicht_aktiv BL_2_RL_FKT nicht_aktiv BLK_TIMER_STAND wert_01 CC_MELD_AL_OFF nicht_aktiv CC_MELD_NSL_BFD nicht_aktiv CC_MELD_NSL_SL nicht_aktiv CC_MELD_PARKLICHT nicht_aktiv DEF_ABBIEGELICHT_CKM nicht_aktiv DEF_AHL_MODE_CKM wert_01 DEF_SMART_BEAM_CKM aktiv DEF_WELCOMELIGHT_CKM nicht_aktiv DRL_TFL_BLK_V_GED nicht_aktiv DRL_TFL_KZL nicht_aktiv DRL_TFL_RL_BL nicht_aktiv DUAL_SP__BL_L nicht_aktiv DUAL_SP__BL_M_1 nicht_aktiv DUAL_SP__BL_R nicht_aktiv DUAL_SP__BLK_2_VL nicht_aktiv DUAL_SP__BLK_2_VR nicht_aktiv DUAL_SP__BLK_H_L nicht_aktiv DUAL_SP__BLK_H_R nicht_aktiv DUAL_SP__BLK_V_L nicht_aktiv DUAL_SP__BLK_V_R nicht_aktiv DUAL_SP__RFS_L nicht_aktiv DUAL_SP__RFS_R nicht_aktiv DUAL_SP__RL_BL_1_L nicht_aktiv DUAL_SP__RL_BL_1_R nicht_aktiv DUAL_SP__RL_BL_2_L nicht_aktiv DUAL_SP__RL_BL_2_R nicht_aktiv DUAL_SP__SML nicht_aktiv DUAL_SP__TFL_L nicht_aktiv DUAL_SP__TFL_R nicht_aktiv DYNAM_LWR_ENABLE_LM2 aktiv EINLENKEN_RKW aktiv ENDE_ABBL wert_01 ENTGEGENGES_RKW aktiv FEHLERMELD_CC_NSW_L aktiv FEHLERMELD_CC_NSW_R aktiv FEHLERMELDUNG_CC_BL_M_2 nicht_aktiv FEHLERMELDUNG_CC_BLK_2_VL aktiv FEHLERMELDUNG_CC_BLK_2_VR aktiv FEHLERMELDUNG_CC_SML_L nicht_aktiv FEHLERMELDUNG_CC_TFL_L nicht_aktiv FEHLERMELDUNG_CC_TFL_R nicht_aktiv FSP_ISP_SPERREN_1 wert_00 GETRIEBE_HANDSCHALTER nicht_aktiv HEIMLEUCHTEN_1 wert_02 HEIMLEUCHTEN_2 wert_02 HEIMLEUCHTEN_3 wert_02 HEIZ_ANF wert_01 HEIZ_KNICK wert_01 HW_NOTLAUF_CHECK_COUNT wert_01 HYST_RKW wert_01 HYST_STAND_KRV wert_01 PROGRAMMPARAM_ALC_SG_1 wert_01 PROGRAMMPARAM_ALC_SG_2 wert_01 KALTUEBERWACHUNG_BLK_2_VL aktiv KALTUEBERWACHUNG_BLK_2_VR aktiv CHECK_SMC_ERROR aktiv KALTUEBERWACHUNG_TFL_L aktiv KALTUEBERWACHUNG_TFL_R aktiv KENNL_MAX_UEBERST_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 KENNL_REDUZ_MAX_SCHWEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 KURZSCHL_WIERHOL_ZAEHLER wert_01 KURZSCHLUSS_CHECK_DISA wert_01 KURZSCHLUSS_CHECK_TIME wert_01 KURZSCHLUSS_ENTPRELL wert_01 LENK_UEBERSETZUNG_LO_SP wert_01 wert_02 wert_05 wert_06 wert_07 wert_08 wert_09 wert_10 wert_11 wert_14 wert_15 wert_16 wert_17 wert_18 wert_19 wert_20 LH_UND_NSW_NICHT_GLEICHZ nicht_aktiv LICHT_AN_WARN_NORM aktiv MAX_DELTA_KEINE_VERR_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MAX_HEIZZEIT wert_01 wert_03 wert_04 wert_05 MAX_SCHWENK_V_H_BEGR wert_01 wert_04 wert_07 wert_11 wert_13 wert_14 wert_16 MAX_SCHWENK_V_H_BEGR_SP wert_01 wert_04 wert_07 wert_11 wert_16 MAX_VERRINGERUNG_V_SCH_SP wert_01 wert_04 wert_07 wert_11 wert_16 MIN_DELTA_MAX_VERR_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MIN_SW_SCHWENK_V_HORIZ_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 MIND_ANZ_ZYKL_TIPP_BLK_1 wert_02 MIND_ANZ_ZYKL_TIPP_BLK_2 wert_02 MIND_ANZ_ZYKL_TIPP_BLK_3 wert_02 NACHL_RKW wert_01 NO_BLK_RKW nicht_aktiv NSL_ERS_DEF_RL_BL_1 nicht_aktiv NSL_VERBAU_OTP wert_01 PWM_ANST_1_UNBELEGT wert_01 PWM_ANST_2_UNBELEGT wert_01 PWM_ANST_3_UNBELEGT wert_01 PWM_ANST_BL_2_SL wert_01 PWM_ANSTEUERUNG_BL wert_02 wert_04 PWM_FL_NSW_FKT_ABBLIEGELI wert_02 PWM_NSL_ODER_BFD_ALS_BL wert_02 PWM_PIN_22_68_24_39 wert_01 PWM_PIN_25_40 wert_03 wert_07 PWM_SIDEMARKER_BLK_V wert_01 QUITT_BLK_ENTSICHERN_1 nicht_aktiv QUITT_BLK_ENTSICHERN_2 nicht_aktiv QUITT_BLK_ENTSICHERN_3 nicht_aktiv QUITT_BLK_SICHERN_1 nicht_aktiv QUITT_BLK_SICHERN_2 nicht_aktiv QUITT_BLK_SICHERN_3 nicht_aktiv RAMPE_AUS_BLK wert_01 RAMPE_AUS_KRV wert_01 RAMPE_AUS_RUE wert_01 RAMPE_EIN_BLK wert_01 RAMPE_EIN_KRV wert_01 RAMPE_EIN_RUE wert_01 REDUZIERUNG_V_SCHWE_HI_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 REDUZIERUNG_V_SCHWE_LO_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 RLS_RESTART_COMM wert_01 RLS_VERBAUT nicht_aktiv SENSEWID_PIN_22_68 aktiv SENSEWID_PIN_24_39 aktiv SENSEWID_PIN_30 nicht_aktiv SENSEWID_PIN_42 nicht_aktiv SL_ABSCH_OHNE_ECE aktiv SL_BL_ERS_DEF_RL_BL_1 nicht_aktiv SMART_BEAM_CKM_0 aktiv SMART_BEAM_CKM_1 aktiv SMART_BEAM_CKM_2 aktiv SMART_BEAM_CKM_3 aktiv SP_GRENZE wert_01 START_ABBL wert_01 SW_NULL_BEREICH_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_UEBERST_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 T_FILTER_V_VEH_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 TAGFAHRLICHT_ECE_1 nicht_aktiv TAGFAHRLICHT_ECE_2 nicht_aktiv TAGFAHRLICHT_ECE_3 nicht_aktiv TASTVERH_BEL_FLC_LED wert_03 TAU_ABSCHWAECHUNG_SP wert_01 wert_04 wert_07 wert_11 wert_15 wert_16 TIMEOUT_SET_DTC aktiv TIPP_BLK nicht_aktiv UNP_ABBIEGELICHT_CKM nicht_aktiv UNP_AHL_MODE_CKM wert_01 UNP_HEIMLEUCHTEN_CKM wert_02 UNP_QUITT_BLK_ENTSI_CKM nicht_aktiv UNP_QUITT_BLK_SICH_CKM nicht_aktiv UNP_SMART_BEAM_CKM aktiv UNP_TAGFAHRLICHT_ECE_CKM nicht_aktiv UNP_WELCOMELIGHT_CKM nicht_aktiv UNP_ZYKL_TIPP_BLK_CKM wert_02 V_E_HI_BLK wert_01 V_E_HI_KRV wert_02 wert_03 wert_05 wert_06 wert_08 V_E_LO_BLK wert_01 V_E_LO_KRV wert_02 wert_03 wert_05 wert_06 wert_08 V_HI_ABSCHW_D_TAU_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_AENDER_LENK_UEBER_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_RED_SCHWENK_W_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_REDUZIER_V_SCHWEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_SW_MITLENKEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_HI_SW_NACH_INNEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_ABSCHW_D_TAU_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_AENDER_LENK_UEBER_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_RED_SCHWENK_W_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_REDUZIER_V_SCHWEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_SW_MITLENKEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_LO_SW_NACH_INNEN_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_M_HI_REDUZIER_V_SCHW_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_09 wert_10 wert_11 wert_12 wert_13 wert_14 wert_15 wert_16 V_M_LO_REDUZIER_V_SCHW_SP wert_01 wert_04 wert_05 wert_06 wert_07 wert_11 wert_16 V_S_HI_BLK wert_01 V_S_HI_KRV wert_01 V_S_LO_BLK wert_01 V_S_LO_KRV wert_01 WARMUEBERWACHUNG_BLK_2_VL aktiv WARMUEBERWACHUNG_BLK_2_VR aktiv WARMUEBERWACHUNG_TFL_L aktiv WARMUEBERWACHUNG_TFL_R aktiv WELCOME_LIGHT_ACTIVE nicht_aktiv WELCOMELIGHT_CKM_0 nicht_aktiv WELCOMELIGHT_CKM_1 nicht_aktiv WELCOMELIGHT_CKM_2 nicht_aktiv WELCOMELIGHT_CKM_3 nicht_aktiv WL_AL nicht_aktiv WL_BLK_H nicht_aktiv WL_BLK_V nicht_aktiv WL_DAUER wert_01 WL_FL nicht_aktiv WL_KZL soft_einschalten WL_MAX_DAUER wert_01 WL_NSL nicht_aktiv WL_NSW nicht_aktiv WL_POL aktiv WL_SL_1 nicht_aktiv WL_SL_2 hart_einschalten ZUWACHS_TASTVERH_FLC_LED wert_03 ABBL_LZ_STAND wert_01 ABL_AUS_BEI_FL_LH_EIN aktiv BFD_1_BL_2_ERSCH_BILD wert_01 BFD_2_BL_2_ERSCH_BILD wert_01 CC_MEL_SL_BEI_DEF_RL_BL_1 nicht_aktiv DWA_UEBERFALL_ALARM wert_02 ENERGIE_UBATT_LIMIT wert_01 ENERGIE_ZEIT_ENTPRELL wert_01 ENERGIE_ZEIT_LIMIT wert_01 FSP_LAMPEN_MASK wert_01 KALTUEBERWACHUNG_SML nicht_aktiv LOAD_DUMP_DIMM_AL aktiv LOAD_DUMP_DIMM_BL aktiv LWR_MAX_POS_NORM wert_01 LWR_MAX_POS_REF wert_01 LWR_OFFSET_PLATTLAUF_L wert_01 LWR_OFFSET_PLATTLAUF_R wert_01 NSL_AUS_BEI_FE_MODE nicht_aktiv SL_SCHALT_UMSCHALT_OPT wert_01 STANDVERBRAUCHER_ANMELD nicht_aktiv VORH_HEIZZ wert_01 WARMUEBERWACHUNG_SML nicht_aktiv WL_MIT_FLC nicht_aktiv WL_ZYKLEN wert_01 FZG_RADSTAND_LM wert_07 ALC_SG_VERBAUT nicht_aktiv BL_2_BREMSL_FKT_33 aktiv CC_MELD_ABIEGL_BEI_DEF_FL nicht_aktiv DRL_TFL_RL_BL_1_33 nicht_aktiv DRL_TFL_RL_BL_2_33 nicht_aktiv DRL_TFL_SML_33 nicht_aktiv DRL_TFL_TFL_33 nicht_aktiv LWR_ABS_MIN_STELL_2 wert_01 LWR_SCHRITTE_STELL_0 wert_01 LWR_SCHRITTE_STELL_1 wert_01 LWR_SCHRITTE_STELL_2 wert_01 PIN_CONFIGURATION_33 wert_01 PWM_AN_NSL_SL wert_01 PWM_ANS_RL_BL_2_AL_33 wert_05 PWM_ANS_RL_BL_2_FL_33 wert_05 PWM_ANST_RL_BL_BL_33 wert_02 PWM_ANSTEUERUNG_NSL_33 wert_01 PWM_ANSTEUERUNG_RL_33 wert_04 PWM_ANSTEUERUNG_SML_33 wert_03 PWM_FL_FKT_DRL_33 wert_02 PWM_PIN_11_63_33 wert_01 PWM_RL_BL_1_FKT_PARKL_33 wert_03 wert_05 RL_BL_1_BREMSL_FKT_33 aktiv RL_BL_1_PARKL_FKT_33 aktiv RL_BL_2_PARKL_FKT_33 aktiv RL_BL_2_PO_RL_FKT_33 aktiv RL_BL_PO_RL_FKT_33 nicht_aktiv SENSEWID_PIN_04_33 aktiv SENSEWID_PIN_05_33 nicht_aktiv SENSEWID_PIN_10_33 nicht_aktiv SENSEWID_PIN_11_33 aktiv SENSEWID_PIN_25_33 aktiv SENSEWID_PIN_40_33 aktiv SENSEWID_PIN_61_33 aktiv SENSEWID_PIN_62_33 nicht_aktiv SENSEWID_PIN_63_33 aktiv SENSEWID_PIN_64_33 nicht_aktiv SL_PARKL_ABSCH_12H nicht_aktiv VERHALTEN_DRL_TFL_33 drl_tfl_off ENABLE_KL_GR_BL nicht_aktiv ENABLE_KL_VA nicht_aktiv ENABLE_RL1_ERS_BL1 nicht_aktiv IGR_MIT_SL_AL aktiv PWM_ANSTEUERUNG_AL_33 wert_01 PWM_ANSTEUERUNG_KZL_33 wert_01 PWM_BL1__GR_BL wert_03 PWM_BL1__KL_BL wert_02 PWM_BL2__GR_BL wert_03 PWM_RL1_ERS_BL1 wert_01 WL_BL nicht_aktiv WL_SM soft_einschalten LWR_MAX_POS_NORM_2 wert_02 LWR_DIAG_ANSTIEG wert_01 wert_02 LWR_DIAG_OFFSET wert_01 ZEIT_PARKL_AKTIVIERUNG wert_03 AG_M_ALWR wert_01 AHL2_ENABLE nicht_aktiv ALC_DIS_AUSGL_NICK_GW nicht_aktiv ALWR_ENABLE nicht_aktiv C1_HORI_BF wert_01 C1_HORI_FA wert_01 C1_VERT_BF wert_01 C1_VERT_FA wert_01 C2_HORI_BF wert_01 C2_HORI_FA wert_01 C2_VERT_BF wert_01 C2_VERT_FA wert_01 E__HORI_BF wert_01 E__HORI_FA wert_01 wert_02 E__VERT_BF wert_01 E__VERT_FA wert_01 wert_02 LWR_DIAG_ANSTIEG_2 wert_01 wert_02 LWR_DIAG_OFFSET_2 wert_01 NSW_AUTOBAHN wert_02 OFFSET_GESCHW wert_02 REF_DEMO wert_01 wert_07 wert_08 V__HORI_BF wert_01 V__HORI_FA wert_01 V__VERT_BF wert_01 V__VERT_FA wert_01 VERZ_REF_DEMO wert_01 wert_02 E3_HORI_BF wert_01 E3_HORI_FA wert_01 E3_VERT_BF wert_01 E3_VERT_FA wert_01 F_A_ALWR wert_01 F_ALWR wert_01 F_SWEG_ALWR wert_01 GL_ALWR wert_01 MAX_KRUEMM wert_01 R_SWEG_ALWR wert_01 STRST_MAXDIFF_ALWR wert_01 T_ALWR_AM wert_01 T_ALWR_AUS wert_01 T_ALWR_MKR wert_01 T_ALWR_NST wert_01 T_ALWR_SW wert_01 V_ALWR_AM wert_01 V_ALWR_AN wert_01 V_ALWR_AUS wert_01 V_ALWR_BAB1 wert_01 V_ALWR_BAB2 wert_01 V_HI_AUTOB wert_01 V_HI_STADT wert_01 V_LO_AUTOB wert_01 V_LO_STADT wert_01 V_MID_LANDSTR wert_01 V_MIN_KRUEMM wert_01 V_NSW wert_01 W_ALWR_EKR wert_01 W_ALWR_MKR wert_01 W_ALWR_SW wert_01 WEG_GERADE wert_01 Z_ALWR_NST wert_01 Z_ALWR_SW wert_01 ZEIT_AUTOB wert_01 ALC_OFFSET_LWR_34 wert_07 wert_18 wert_19 LWR_HEBEL_34 wert_01 PWM_AN_BLK_H_34 wert_01 PWM_AN_SL_V_AL_1_34 wert_08 PWM_AN_SL_V_FL_1_34 wert_09 PWM_ANSTEUERUNG_FL_34 wert_01 PWM_ANSTEUERUNG_RFS_34 wert_01 PWM_PIN_05_62_34 wert_04 CC_MEL_POL_BEI_DEF_TFL nicht_aktiv CC_MEL_SL_BEI_DEF_RL_BL_2 nicht_aktiv
My 760Li - Fully Loaded ![]() |
#142
ACE, Im 99% sure you need an LM2 to have the adaptive headlights (turn as you go round corners) there dont appear to be any parameters in the NCS coding files for this function, Mr Burger has the LM2 file posted up which is alot larger than the standard LMA file as it has loads more options for welcome lights, and settings for the adaptive head lights (steering wheel ratios etc...)
I picked my LM2 up for £65 here in the UK, its a generic module though, used on the 5 and 6 series, the module needs coding to the car as the lights are wired differently, the only way I managed to do this successfully was to allow NCS to code the module automatically using the vehicle order information. I couldn't find anywhere in the coding file where you set what chassis its fitted to, it kept thinking it was in an E60, I would only get one indicator light and the rear fog lights were on instead of the rear markers/sides. The only way to get it to work properly was to allow NCS to code it based on the vehicle order, i think you would struggle using dashsoft, there are loads of PWM values to set for the brightness of the LEDS in the lights etc... also the memory locations that hold the coding data are completely different between the old LMA and the new LM2, you wouldnt be able to copy stuff over very easily. Once coded with NCS expert profile i then coded welcome lights and lights on via fob etc... If you use NCS edit you VO in the CAS and LMA to add the options for adaptive headlights etc... and code it. Hope this helps!? Stuart Last edited by stuartjohn24; 07-28-2012 at 07:58 AM. |
#143
Thanks guys, I clearly need to get NCS then....and I have purchased an LM2 for an E66. It is on it's way to me in the mail now.
But first , I must get NCS running ![]() HELP...... |
#144
The only other thing is the LM is one of the modules that stores the vehicle order code, the other being the CAS. It's used by NCS and other diagnostic software to determine what modules are fitted. It's basically a string of numbers derived from the actual option codes when the car was first ordered. I don't know what implications this will have for you, probably none if you just use dashsoft, 9 times out of 10 the vehicle order code is read from the CAS, the LM is just used as a backup copy. I guess these can be different and the car accept it? You may be able to write this order code using dashsoft, I think having the correct VIN is the most important part. I can help you with some of the coding if you wish, I bet adaptive headlights will already be coded of its from a facelift E66. How's the CA coming along? Stuart |
#145
Looks like both door harnesses need to be changed for me! The main harness is specific to comfort access also,
What a disaster! According to the parts catalog mine should be wired for CA as the CA and soft close are the same harness! ACE, where were the plugs when you removed the handle? Tucked away or taped to something? All I can see is this: I will check WDS later and hope I can buy the pins/sockets and add the wiring to my harness, I don't fancy buying 8 harnesses at £40-50 each, let alone replacing them! Lol. Stuart |
#146
Stuart
![]() I had exactly the same wiring in my doors as you have! I only had to change the small additional loom that connects to the main door harness....... That is what I have been doing today and everything is working fine Ace
#147
Stuart......
...... you are always having 'disasters' ![]() I already told you in an earlier post what you need........ and I will tell you again....
Thats it ....... Not the main door harness .... just these supplementery ones ![]() Ace
#148
Stuart
I bought all four door harnesses, main and supplementary for 125 GBP.... and I later learned I only needed the supplementary looms..... so you should be able to get all four for 60 GBP.... Ace
#149
Ahh ok, what I was getting at was the main loom has a standard version and a version for CA and soft close.
I have soft close so technically I should have the main and supplementary looms specified for comfort close and CA. But as I have already found out the supplementary loom which is supposed to have the CA wiring.... Hasn't! What I'm getting at is what's to say the wiring for CA isn't in the main loom? And not missing like in the supplimenatry door loom? I will pull the battery and check the connector pin out going from the door to the car body and see if the correct pin locations are populated. Will report back later. Just want to know how much work I'm letting myself in for lol! Thanks for your help ACE, much appreciated. Last edited by stuartjohn24; 07-29-2012 at 05:15 AM. |
#150
Just checked WDS, As you know the CA handle has 4 wires, one of them is the PA Bus wire, this comes from the handle to the door module, via the internal PCB its then routed through to the main loom where it connects to the door/chassis connector.
Is this wire present in the standard door loom? The other connections are GND, Hall sensor and the TAG signal, all three of these go into the door module. This has something to do with the comfort closing system I believe. I cant see any coding parameters for CA in the door modules, which is good! Last edited by stuartjohn24; 07-29-2012 at 06:23 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
