7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#176
That's right ACE, there is another module though, look up A214 in WDS.
It sits on the CAN bus and has the level sensors wired to it. It then communicates with the headlight modules on the LIN bus. Another simple system by BMW! Lol Stuart |
#177
Stuart |
#178
Yes, I had parts from an old wiring loom so it made it simple. Looking at diagrams now. The part number of my LM2 with adaptive headlight control is 9153273
Ace
#179
Hey Stuart,
A214 is the adaptive headlight module for pre-facelift cars. With the facelift headlights, the LM2 incorporates the adaptive control within it and A214 does not exist. FACELIFT....... no A214, now controlled by LM2 ![]() PRE-FACELIFT....... A214 instead of LM ![]() Ace
#180
Odd, I have different diagrams!? Are you using a CD or online version?
That's right come to think of it, I had to buy the LWR version just for vertical aim control. Sounds like you have it all under control! There is a wire change by the way, for the led output to the light switch that indicates automatic lights are on. Stuart |
#181
I am using the online WDS diagrams......
What is the wire change you are referring too? ![]() Ace
#182
Spaghetti or BMW planet?
Yeah it's the wire that drives the LED in the light switch panel, someone cocked up on the LM2 I think! You need to move wire is pos 17 to pos 60. It's detailed in BMW TIS 61 35 285 Stuart |
#183
Ok, thanks for that. Spaghetti does show it as pin 60
![]() Ace
#184
Odd I know! I can confirm it works though!
Think I will use spaghetti from now on, BMW planet must be out dated or schematics linked incorrectly! Stuart |
#185
So you have retrofitted Adaptive Headlights to your pre-facelift car?
![]() Ace
#186
Hey, no.
I bricked my original LMA when coding the VO. I just upgraded it to an LM2 because I wanted to have welcome lights. My LM2 is just the standard version for headlight levelling and not the adaptive version. Mine says E6X LMII LWR, yours should be the AHL version I think, I can't remember off hand. Stuart |
#187
This is a sick probect wow Nice work ace what's next
Bayerische Motoren Werke ![]() |
#188
Hi
Lastcombo,I am working on retrofitting Adaptive Headlights, High Beam Assist (FLA) and Rear A/C........coming soon to a Fest near you ....... ![]() Ace
#189
Hi
#190
This CA retrofit is nearly finished...... just got to code my keys and do the last wiring this weekend to the CAS
![]() Ace
#191
I tried this today and loaded up NCS to read the EHC and it used EHC_E65.PRG (from C:\EDIABAS\ECU I believe), so I went in to Tool32 and used the c_fg_lessen and attached is what it returned.. It seems INPA is seeing one VIN and Tool32 is seeing the correct one..wtf Anyways, please switch this to PM as I don't want to hijack Ace's thread any further (it's just I couldn't attach the image to the PM lol) Cheers
My 760Li - Fully Loaded ![]() |
#192
I bought a key programmer on eBay last night.
I will let you know how it goes as soon as it arrives ![]() Ace
#193
No stress Burger, it's all interesting to me too.
I need code help on Adaptive Headlights and FLA. Does your car have these? Ace
#194
Hey Stuart, I have completed re-coded my old LM with new codes and it worked, and I didn't brick it........ I am now wondering what you and PAPER did that killed yours?
![]() Ace
#195
I was just about to ask about that and boom, you and ebay eh...I'd hate to be your postman lol
![]() Is it a 'program with it in the CAS' programmer?
#196
My car has everything except rear a/c & fridge, backup camera, DAB and HUD I think
#197
Hey Burger, does your car have your LM coded for two stage Brake Lights?
![]() I am trying to work out that code too. Here is what I bought on eBay ![]() http://www.ebay.com.au/itm/170784562...ht_2635wt_1180 I got this from the same seller that sold me the Dashsoft. Ace
#198
Cool
![]() Are you talking about the Brake Force Indicator? If so, then I think it's standard on facelift 7s (isn't it).
#199
Yes, i wasn't sure if it was standard or not. But I do know that it is coded on the LM.
Can you provide a dump of your LM? Ace
#200
The reason it got partially bricked was cause the battery on the car died as I was coding the LCM . I didn't realize I had been in the car for over 4 hours reading & experimenting with production dates for some members on this site . My car light came on & said low battery in the middle of coding & the LCM was affected by it .
If you need a Custom 2013 DVD Navigation Map East or West for your E65 E66 PM me for price . Or if you Need an AUX Plug for your car hit me up |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
