BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#276
What cable are you having built, as whatever it is, it will work on one and not the other, and do you already have the other cable?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
#277
Some success...some not with F25 coding.
Software and cable work great (thanks April1), But I am having partial success on my coding changes. I've got a 2012 X2 with HUD and Msport and DHP and PDC.
Working: Add power/torque meters Add pressure and time temp reading Disable all disclaimers Unlock all doors when stopped...one pull open DVD in motion...I see not way to change to Value=ff for either speedlock...this is not an option on my screen. Close mirrors and windows with a touch to the handle lock...I made both changes, but nothing seems different. Have to wait? Disable seat belt gongs...I see no SPW_BF or SPW_FA in the ACMS/3000 Ausstattungsflags section. Not working: Radio menu in HUD ...again, not HUD_ENTERTAINMENT_ENABLE choice in 3000HMI Telephone info in HUD...again, no HUD_TELEFONANRUF_ENABLE in 3000 HMI. I'll look again for all of this, but if someone knows what I am missing, let me know. Last edited by lair12; 02-13-2013 at 05:31 AM. |
#278
Thanks for the guide; in addition to the installation section --> I've installed on my "D" drive because my "C" is a small SSD disk... If you do a [find and replace "C:\" with "D:\"] in file ["X:\EDIABAS\Bin\EDIABAS.INI"] everything works just fine
#279
Hi April1, I'm a very beginner for coding. I would to know how can activate the sport display on my 2012 F30 328i. I have downloaded the e-sys 3.18 with psdzdata 4.75. I've tried thousand times following the guide but no success. It shows the cafd file not found and I don't know what can I do to due with it
Could you please lend me a helping hand? Thank you so much
#280
#281
#282
Here's my initial experience with ESys coding of my 2011 F02 760Li Individual. I have never before done anything on a BMW, by the way.
Got the Enet cable from April-1 today. Had all the software downloaded and configured according to Shawn's instructions. I typed up a condensed version of the F10 cheat sheet with the codes that I wanted, so that I'm not looking at dozens of other codes that may not apply to me. Connected the car to the laptop computer, and launched ESys program. Took a few tries before the program registered the "FA" and ran "VSM" successfully. Back-up of all original configurations of modules done without a hitch. Started coding some modules--holding my breath while doing the first one (seatbelt warning). Forgot to activate FA and the code FDL was not successful. Saw the dreaded "red" banner with word "unexecutable", had some cold sweat--did I just F*** it up? Re-read the instructions, realized the missing step, and redid the code process. Result is "green"! Unbelievable relief, big sigh! Closed ESys program, disconnected computer from car, and cycle on the ignition............. No seatbelt warning, gong, or reminder except for right after ignition on. ALRIGHT! I can do this! Went on to code for: Mirror folding with comfort access & key fob. Closing trunk with key fob and cabin button. This one took about half hour to activate. Turn signal on HUD. Logic-7 sign. VIM. Disabled legal disclaimers. The whole process took about 4 hours from receiving the cable to final test drive. I'm so excited! Thank you April-1 and Shawnsheridan! I thought VAG-COM was fun, but this really rocks! |
#283
#284
Hi i just start try to do this coding stuff following all the instruction in "getting started codding".
My win7 64 bit succesfully connected and can read and edit the files, however when i want to "activate FA", it does nothing (There is no green light besides the FA and no error messages) and when i try to click "coded FDL", the program said i have to activate FA first. Anyone facing this problem? |
#285
Update on coding of 2011 F02 760Li Individual:
Today I coded the following: Double press of the start button to start the car without pressing on brake pedal. Shutting off radio & Navi after car shuts off and opening the driver's door, without having to double press the stop button or lock the door. Allow automatic windows up and down on all doors when door is open. Unlocks doors when engine is stopped, allowing single-pull to open door. |
#286
Hi Guys
My F30 will be arriving in April and am looking to get a head start on understanding the coding. Requesting a link to the E-Sys files & a connection to April1 for the cable. Any help would be greatly appreciated. |
#288
PM sent.
#289
Hello
Got my 13 335xi a few weeks ago and want to learn how to code myself. Requesting a link to the needed software and how to get a connection cable. I would like to code the following and would like direction on where to make these changes: Navi/radio off when opening door Auto wipers set to on Single pull unlock ASS off Driving mode sport + Turn signals in hud Curious what other cool coding changes others have done as well. Just not sure what the options are. Thanks in advance. |
#290
#291
Dear Sir,
Would you please give me a link of Psz 47.4 for my 2013 X3 F25? I greatly appreciate your timely help! |
#292
PM sent.
#293
Coding is like a drug; once you start, you can't give it up.
2011 750i |
#294
#295
No Connection
I have the software, a cable from One-Stop, and two computers (I first tried with Win8 using Ethernet via a USB dongle and then with Win7 with a built-in Ethernet jack). Neither computer seems to get a connection to my F30 (built in mid-January). ZGW_Search finds nothing and E-Sys won't enable the VIN connection option.
The computers both appear to self-assign IP addresses in the 169 space. Any ideas to get me started? Last edited by manicottiK; 03-02-2013 at 05:03 PM. |
#296
EDIABAS.INI.PDF For ENET, just make sure it has: Interface =ENET
#298
I assume the cable is an ENET Cable, and that the Win8 machine without an Ethernet Adapter is some sort of Tablet? Get it working first on the Win7 machine before attempting it on the Tablet. Make sure the car is turned on and run ZGW_Search in the XP SP3 Compatibility Mode, and see if you can see the car's IP Address. Make sure you are connecting to the F25 Target (without the _DIRECT after it).
#299
#300
Thanks! |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
