Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 07-09-2012, 12:51 PM
tom@3dproducts's Avatar
tom@3dproducts tom@3dproducts is offline
Mein Auto:
3D Ultra Protectant Thick
Ultra Protectant - Thick
water based dressing
Leaves long-lasting high gloss shine
Wipe on formula
Protect your tires with Ultra Protectant-Thick TM tire dressing product
3D Professional Detailing Products Ultra Protectant is the best product in the market, as it leaves a long lasting glossy shine on your tires. It incorporates UV filters that help preserve your tires built in sunblock from getting depleted over time. By keeping the rubber of your tires protected from Ultraviolet damage, the sidewalls are kept supple, so that they'll look and feel new even after months of usage. It is the perfect touch to any detail job. Beads and repels water through it’s protective formula. Use it on other vinyl and rubber portions of your vehicle.
If you want a shiny, sparkling-new tire, perhaps you'd consider using Ultra Protectant tire dressing products. Tire dressing products are applied to your tires in order to make them look shiny, clean, and new. These products are used by detailing shops and conscious car enthusiasts to keep their tires looking great every time. There are solvent-based and water-based water protectants, and it's up to you to choose which one suits your car's tire best. But if you want great results, use water-based Ultra Protectant tire dressing with an applicator. This tire dressing is really advantageous because it is environmentally friendly, and doesn't pose any risks to your tires, it also has a nice consistency that allows you to spread the formula onto your tires using an applicator.
There are different methods to apply Ultra Protectant to your tires. One of which is to use the 3Ds squeeze bottle to apply it onto a sponge applicator or a brush and spread to the tire surface.
Ultra protectant Thick is a water based dressing intended to be wiped on. Tire dressings are great ways to highlight the beauty of your esteemed cars. After having it polished and waxed, removing its odors and stains, and inspecting its upholstery, you can already proceed to shining your tires. After all, glossy tires are the heart and soul of great looking cars. They complete the certain look that auto detailers want to see from the cars of their clients. Once you have found the right tire dressing, you can give your tires a sleek and shiny look that will surely impress the biggest car enthusiasts.
Common question: I like spreading my water based dressing, which is the best water based dressing that I can apply to my tires using a sponge or brush? You can use 3D Ultra Protectant Thick. It is similar to 3D Ultra Protectant, but that is a spray on formula.
Is there a water based tire dressing that is green and biodegradable? Yes, 3D Ultra Protectant
3D Professional, the number one manufacturer of auto detailing products, has released a well-formulated Ultra Protectant that can change the way you add gloss to your tires. Its water-based dressing acts as a great solution for leaving long-lasting shine on tires. For best results, you should clean your tires with 3D Yellow Degreaser first.
Since it has a thick formula, you can apply it by using 3D Squeeze Bottle and applying the dressing into a sponge applicator. It can quickly dry up to leave a smooth, non-tacky, and gloss finish to your tires that can prevent them from accumulating dust and dirt.
DIRECTIONS:
For best performance on tires, clean with Yellow Degreaser. As this is a thick formula, we recommend to use our 3D Squeeze Bottle (Part # C-01) to apply the dressing onto a sponge applicator or a brush and spread on to the desired surface. For long lasting “High Shine” on tires, DO NOT DILUTE. This product dries to a non-tacky, smooth glossy finish preventing dust collection.
DETAILING MADE SIMPLE
www.3dproducts.com
First time buyers, use coupon code TD5
www.autopia.org
www.hdcarcare.com
