Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > The Detail Department
Detailing tips, tricks to keep your bimmer in showroom condition.
Old 07-09-2012, 01:03 PM
tom@3dproducts's Avatar
tom@3dproducts tom@3dproducts is offline
Mein Auto:
3D Foaming Carpet & Upholstery Cleaner
Super rich foaming upholstery and carpet cleaning shampoo. Releases ground-in dirt from carpets, upholstery, and rugs including velour. This can cleans 9' x 12' rug. Spot cleaning ideal for spills and spots.
Directions:
If rug is being cleaned for the first time, check small area for color fastness.
1. Vacuum rug and place wax paper under furniture legs.
2. Spray about two feet from carpet. Use sweeping motion to cover an area about three feet square with light, even layer of foam.
3. Wet sponge or sponge mop in clean water and spreading foam in evenly. Gradually increase sponge pressure and go across the same area at right angles until foam disappears. Then sponge in one direction to raise nap. Scrubbing may be necessary if rug is badly soiled.
4. After rug is dry (2-4 hours), vacuum to remove dried cleaners and loosened soil.
Upholstery / Carpet
Do NOT use on silk. Check hidden area for color fastness.
1. Vacuum piece thoroughly
2. Spray about two feet from upholster or carpet. Use sweeping motion to cover area with a light, even layer of foam.
3. Wet a sponge or terry cloth in clean water and spread foam in evenly. Gradually increase pressure and go across until foam disappears. Scrubbing may be necessary if badly soiled.
4. After the upholstery or carpet is dry (2-4 hours), vacuum to remove dried cleaner and loosened soil.
DETAILING MADE SIMPLE
www.3dproducts.com
First time buyers, use coupon code TD5
www.autopia.org
www.hdcarcare.com
Old 04-04-2013, 02:09 AM
carlmartinclmn carlmartinclmn is offline
Mein Auto: BMW
Originally Posted by tom@3dproducts View Post
Super rich foaming upholstery and .Carpet cleaning brisbane. shampoo. Releases ground-in dirt from carpets, upholstery, and rugs including velour. This can cleans 9' x 12' rug. Spot cleaning ideal for spills and spots.
Directions:
Carpet Cleaning Sunshine Coast water and spreading foam in evenly. Gradually increase sponge pressure and go across the same area at right angles until foam disappears. Then sponge in one direction to raise nap. Scrubbing may be necessary if rug is badly soiled.
Upholstery / Carpet
Hello guys Carl here. I was searching for good carpet and upholstery cleaning products and I believe I found the right thread. Apart from super rich foaming if you know effective and reliable cleaning products please share your views. Thanks for reading my post _sl_
