Old 09-04-2012, 06:06 PM
Munich77 Munich77 is offline
Mein Auto: 2014 E550 4matic
Name that problem - 535 xi related
A week ago Saturday I was driving my car running errands when the check engine light when on. No I-drive message but the care was not running 100%. Given that my N54 engine has been a bit temperamental (HPFP issues, fuel injectors and carbon cleaning), I decided to bring in the car. Well it has been 5 working days and not even BMW knows what is going wrong. The car is running lean and throwing codes but no clear cause. Now BMW is saying to replace the oxygen sensors. Has anyone had that problem? I find it funny that BMW does not know how to fix its car....
2008 535 xi, space grey, black dakota leather, premium package, sport package, cold weather package, nav, folding seats, PDC
BMW CCA Member
Old 09-05-2012, 07:15 AM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
if you get momentary "engine" icon (not fail safe, drive moderately message) then it most likely the fuel injector. I've seen it on My N54 and a friend's N55, both cases the SA says no action can be taken until it becomes permanent (i.e. the code appears and misfiring persistently).
If you hook it up to BT tools you can see the shadow code, at least on mine telling which cylinder, time and mileage. And in my case and my friend case the car is back to normal now so I am just keeping an eye on it.
Old 09-05-2012, 09:07 AM
gcollins gcollins is offline
Mein Auto: 2008 535i
I had the same problem and turned out to be an injector. It did take them about a week working with BMW NA to figure out the problem. They replaced the injector and all was fine....
Old 09-05-2012, 05:50 PM
Not a momentary engine icon - icon went on and never off!
BMW CCA Member
Old 09-05-2012, 08:53 PM
NoQuarter's Avatar
NoQuarter NoQuarter is online now
Mein Auto: 2008 535xi
Do you know the codes?
Old 09-06-2012, 05:24 PM
Not of the top of my head - apparently BMW does not even know what is going on...latest hypothesis - leaking valve gasket.
BMW CCA Member
Old 09-07-2012, 08:07 AM
You mean valve cover gasket or valve seal?
The latter is N62 4.8i V8 problem, I have not heard it on I6
Old 09-07-2012, 06:02 PM
Valve cover gasket is what they said. According to the dealership, BMW only has had one other 535 that has had that problem. I guess my car is "special".
BMW CCA Member
Old 09-07-2012, 08:36 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
I seriously doubt that is the problem. Would have to be a giant leak, and it would then cause lots of black streaks on the engine block. Some day when you get the intake valves walnut blasted, be sure to replace the gasket.
It might very well be one of the oxygen sensors, assume you have ruled out hpfp and injectors.
Were they able to pull any fault codes? How many miles on the car? Assume plugs and coils are good, fuel line is clean?
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 09-08-2012, 05:24 AM
It was not the oxygen sensors (they replaced those). Changing the seal seems to have fixed it - per the work order "tech replaced valve cover was leaking internally." Oh and the intake valves were blasted in February.
BMW CCA Member
Old 09-16-2012, 01:02 PM
As an update - today I was driving the car and the check engine line went on yet again . I guess I will see what it is this time around.
BMW CCA Member
Old 09-22-2012, 04:37 AM
NoQuarter's Avatar
Try this to attempt to cause a better error: this is a 535 with lots of Power. Many problems only reveal themselves when attempting to use all of it.
Get someplace where you can really floor the pedal and go wide open for about 10 seconds or so. Manual shifter mode, third gear, ~3000 rpm, floor it to almost redline on the rpms.
Old 09-24-2012, 03:46 PM
I doubt that would have fixed it - the problem was - drum roll please -
A faulty low pressure sensor and a faulty DTML pump.
BMW CCA Member
Old 09-24-2012, 08:29 PM
NoQuarter's Avatar
My suggestion wasn't that this would fix it. My suggestion was to stress the engine in order to induce a more significant error condition that would result in the ECU recording the error.
As I continue to tune my engine and increase the horsepower (about 420 hp at the wheels) weaknesses only reveal themselves under higher stress - improve the condition and move on up to the next level!
But probably would not have helped with that pump error anyway. Glad you got it sorted!
Old 09-25-2012, 03:19 AM
Gotcha - I am hoping that the error is gone....
BMW CCA Member
Old 09-26-2012, 08:42 AM
mission hills mission hills is offline
Mein Auto: 2008 535x1
i have a 2008 535xi, the remote key does not work. it,s not the comfort access key. any suggestions
Old 09-26-2012, 12:19 PM
You may want to start a new thread for fob problem, BTW both keys or just one?
