E36 (1991 - 1999)
Old 07-10-2012, 05:50 PM
dprater2008 dprater2008 is offline
Mein Auto: 96 neon, 92 325is
1992 325is IDEAS?
I bought a 1992 325is build date 6/92 crashed for $400. the body work has already been taken care of, but the car has been sitting for the past 11 years inside a shop untouched. It has 156,xxxmi on it. Besides my plans of changing the the water pump, fuelpump, alternator, belts and hoses, raidatior, and resivor tank, what other areas should i pay most attention to and focus on the most. The car does run very well actually. after sitting all those years it fired right up. I drove it a short distance and it felt like the clutch was slipping and when i would be comming to a stop and had the clutch pedel down and tried to put it in gear again it would grind and wouldn't engauge untill i was at a slow creep. what could cause this? then when i parked the car i noticed a small ammount of oil comming from what looked like either the oil pan, or where the transmission meets up to the engine. please if anyone can give me some ideas it would be awsome and much appreciated. From what I understand this non vanos model is much better? is it true that there is no speed governor? and is there any good stuff you can get from ebay for these cars? lol I really do want to make the most out of this car because personally i think its an awsome car. what do you guys think?
Old 07-11-2012, 08:08 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
not sure about some of your first points tho im very surprised that it "fired right up" after sitting for 11yrs. I'd check the tires to make sure they're not flat-spotted.
and about getting things from ebay: don't... most of the stuff sold there is crap. there are a few things wother checking ebay for but for the most part buy from the forum sponsors, wrecking yards, and forum members.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 07-11-2012, 08:17 AM
jkmeisl's Avatar
jkmeisl jkmeisl is offline
Josh
Mein Auto: Built inze Fatherland 325
i have to agree about the ebay comment. dont ebay pimp out our car, try to buy quality parts, a car thats been sitting that long deserves it. bmw's were never ment to be cheap cars so dont make it look cheap with a bunch of ebay crap all over the side of it haha the best looking bmws are clean bmws
Old 07-11-2012, 08:41 AM
Time2Fly's Avatar
Time2Fly Time2Fly is offline
Sometimes Out To Lunch!!!
Mein Auto: 1993 318i 1994 325i 1998
Replace the slave cylinder for the clutch, run some sea foam in the gas tank for a couple of tanks, also run some in the oil for a couple of days before you change it, that may soften the seals a bit and stop the leaks. Nice find, post pics. Seems that you're on the right track on getting it fixed up. Replace the cabin filter also. The ICV will probably need to be cleaned too, it's under the intake manifold. Replace the fuel filter too. Good Luck
Old 07-11-2012, 08:50 AM
jkmeisl's Avatar
Josh
any pictures of the car?
M3GT sedan - my slow progress thread ->http://www.bimmerfest.com/forums/sho...040&highlight=
Old 07-11-2012, 09:59 AM
I need to get a manual for the car yet so I know where and what everything is what is the ICV? I do want to keep the car clean looking and avoid eBay I was just wondering if there was anything worth checking out. I do have some pictures of the car i will try to post later. It's dark metallic blue. I picked up a set of m3 rims for it also which are not on the car at the moment. I can't wait to get it on the road especially because my brother has a 94 325is and it will be interesting to see how they compare. Again I'm welcome to any ideas and tips form you guys. What are some benifits from non vanos?
Old 07-11-2012, 10:12 AM
jkmeisl's Avatar
Josh
I had an 92 325i same colour, beautiful paint when its looked after.
Old 07-11-2012, 10:15 AM
The passenger side is good it got hit on the driver side door and smashed the piller its got a ways to go ill put some pics up after class
Old 07-11-2012, 10:50 AM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
Agreed with previous posters...you said the leak you see may be coming from the oil pan or where the engine meets the tranny right?? Well I would first tighten up the bolts from the oil pan to see if that's your issue its a 10mm socket, sometimes they can get a little loose. If not then you may want to look into the rear main seal from the engine. This job requires removal of tranny and this would be the perfect time to replace that clutch.
I would also look into your tires, being parked that long with air pressure in them is not that good. I can tell you that from a truck my dad had purchased that had been parked for 4 years needed a little tlc and tires looked brand new. About a month after he fixed what it needed his left rear tire blew in the freeway doing about 60ishh mph and flipped about 6 times ending up down a hill on the side of the freeway. Thank good no one died in that accident, but it just goes to show you that even a new looking tire that has been parked for a long time can blow.
Good luck!
Old 07-11-2012, 11:07 AM
Yeah my dad had mentioned it might be the rear main seal, if the slave cylinder is good, this coukd be the issue causing the clutch to slip? Isint this a complicated job? Or pretty basic considering its a rwd car and transmission access is decent? I also noticed that the engine compartment is very clean and really shows no signs of leaking anything in the past. Would a aftermarket exhaust be a bad idea? It already sounds good. From what I understand I have the better engine. Do they react different from the vanos models when upgraded?
Old 07-11-2012, 11:14 AM
jkmeisl's Avatar
Josh
I would take care of any issues that you have at the moment before upgrading the exhaust. you can do the golf tee trick but I'm not sure if its a vanos only mod or not. I have a magnaflow on my 328 and it sounds AMAZING just saying, I would never go back.
Old 07-11-2012, 12:14 PM
veteran011's Avatar
Mein Auto: 97 328is
They should be the same. dont think there were any changes from 92-94... maybe a TU on the engine?
Also leaking from the rear main seal could DEF cause the clutch to slip. you dont want to get oil on teh clutch. its a friction plate and oil is an anti-friction material. haha. check the easy stuff first. oil pan bolts. gasket. etc. Pulling the tranny isnt fun so if it can be avoided that'd be optimal.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-11-2012, 12:35 PM
Hectorml07's Avatar
WYKDBMR
Rear main seal can pose to be a difficult job, but with the right tools a little know how and the time it can be done..I'm a DIY type of guy so I would problably tackle it...
As far as modifications are concerned I would suggest you fix the issues you have at hand first then when your car is on the road and happy you can start putting the good stuff. I had an HKS Klasse exhaust, no cats, with straight 3" piping and it sounded like a beast. I took it off about a year ago because of a ticket I got for it and haven't put it back on. I loved the sound but it gets a little annoying after a while and attracts attention so I put my cats and stock exhaust back .
Old 07-11-2012, 12:44 PM
veteran011's Avatar
Mein Auto: 97 328is
How'd you pass emissions with no cats in Cali?
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
Old 07-11-2012, 03:15 PM
i put a couple pictures in my alblums i couldnt get the rest to work. ill try more later.
Old 07-11-2012, 06:39 PM
Hectorml07's Avatar
WYKDBMR
I know a guy that knows a guy that can hook me up haha
Old 07-11-2012, 06:49 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
1998 BMW 328is
1966 Pontiac GTO
Old 07-12-2012, 07:04 PM
hey guys i also found an 89 325i with 170,000mi the paint is kinda rough with some rust but looks in ok conditon the guy is asking 1000 he replaced one of the fans and said it started leaking oil after he fixed it. he told me that he fixed the oil leak, said it was a line that he knocked loose? it also has a slight power steering leak. im interested in the car to replace my current daily driver. i havent seen the car in person yet but plan to in the next day or so. heres the link. http://appleton.craigslist.org/cto/3120600125.html do you think its worth checking out? or should i just stay clear of this one? any information would be greatly appreciated. thanks
Old 07-12-2012, 07:43 PM
hornhospital's Avatar
D'oh, You Kids!
That's an E30, not an E36, and it looks ROUGH. That's "minimal rust"?
I wouldn't pay more than $400-$500 for it, max.
Quotes to live by:
Old 07-12-2012, 07:48 PM
I know its an e30 I just wanted some other opinions on it. Lol @ the minmal rust. So I'm guessing I should stay away from it? What if mechanically its good? Chances are not likely judging from that comment.
Old 07-12-2012, 07:59 PM
D'oh, You Kids!
I wouldn't touch it for $1k, and I'd think long and hard before offering even half that. It's been maintained by someone that, by their own admission, "isn't very mechanical". It could well be a huge money pit. I'd keep looking.
Quotes to live by:
Old 07-12-2012, 08:02 PM
For sure thanks man
Old 07-25-2012, 08:47 AM
what do you guys think about the pictures of my car that i posted? it has a way to go. think it was a good deal for $400? gonna start work on it in about 2 weeks
Old 07-25-2012, 11:13 AM
bmw-mania bmw-mania is offline
Mein Auto: BMW
put her on a diet.. i mean.. anorexic style.
after you get your maintenance up..
address your leaks, fluids, etc..
in this order.
brakes
suspension
intake
headers
exhaust
Do a good Rattle can job. (yes, it can be done)
NOT GLOSS, Satin, or flat.
Sell off any parts you dont need.. (yes, there are)
Subsidize your BMW habit.
Originally Posted by cj.surr View Post
I don't have to read the username on these posts to know who wrote it.
Bmw-Mania, Ladies and Gentlemen.
Old 07-25-2012, 11:21 AM
Thanks good tip for the order in which to adress things. Sick picture man. It made me geek out though. Trying to find a metallic blue to match is becomeing stressful. Started painting with one and sanded it back off because it was too dark. Should the calipers be replaced or just rebuilt? It looks like new replacements are kind of expenseive which I expected. Is pelican parts a good site to order off of? What do you reccomend?
e36 1992325is
