ModBargains.com l P3 Cars Vent Integrated Digital Gauge l BMW F30 328i/335i - Bimmerfest - BMW Forums
Old 07-11-2012, 11:51 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
ModBargains.com is proud to bring to the Bimmerfest community the P3 Cars Vent Integrated Digital Gauge for your BMW F30 328i/335i! If you are looking for an all-in-one digital gauge that's easy to install for the BMW, then the P3 Cars Vent Integrated Digital Gauge is the perfect fit for you. The P3 Cars Digital Gauge for the BMW F30 328i/335i is able to give you all the performance and diagnostic information you need.
From boost and vacuum numbers to intake air temperature to current speed, the P3 Cars Vent Gauge can give you all the performance data you need an in easy to read display that integrates perfectly in the E9X air vent. The P3 Cars Vent Integrated Digital Interface matches the OEM BMW styling perfectly and is an OEM+ style mod; you would think that this vent gauge came stock from the factory!
Questions? Need Help? Give me a call here at 714-582-3330 x 8006 or ask for Alan !!
Features:
OEM-styled gauge that adds a sleek, unique look
Display output matches OEM BMW interior lighting
All data is read directly from OBDII for most accurate readings
All performance data is shown in real time with no delay
Reads and Clears BMW Diagnostic Trouble Codes
3 extra 0-5v AUX inputs for extra data sensors
Simple installation, plugs into OBDII port
Pre-installed option is available for easier installation*
Functions:
RPM with Shift light
Boost/Vacuum
Speed
Exhaust Gas Temperature
Throttle Plate
Intake Air Temperature
Coolant Temperature
Battery Voltage
On the fly configuration menu
...And Many More!!!
Installation
Installation is as simple as removing the air vent, installing the vent gauge, and plugging in the vent gauge to the OBD II port. To make installation even simpler, we include an option of an OEM BMW air vent pre-installed with the P3 Cars Vent Integrated Digital Gauge.*
Applications:
2012+ F30 BMW 328i
2012+ F30 BMW 335i
*Note: Pre-installed gauge option only available for left-hand drive models
Options:
Left-Hand Drive P3 Cars Gauge
Left-Hand Drive P3 Cars Gauge + OEM Vent (most popular choice and easiest to install)
Right-Hand Drive P3 Cars Gauge
Interested in other BMW Parts from ModBargains.com? Questions? Need Help? Give me a call here at 714-582-3330 x 8006 or ask for Alan !!
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 07-11-2012, 01:12 PM
ws6616 ws6616 is offline
Mein Auto: 97 Toyota Camry
wow! this is pretty cool! well, can this can replace the HUD for F30s without nav?
are you guys going to make one that works with navs too?
Old 08-16-2012, 09:36 AM
The P3 digital gauge works as an independent unit and will not affect the HUD or the Nav.
Old 08-16-2012, 12:51 PM
Itinj6's Avatar
Itinj6 Itinj6 is offline
Mein Auto: 2012 650i Convertible
Any chance of seeing a similar unit being compatible with the F12/13. I'm really interested.
Old 07-24-2013, 12:15 PM
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Moderator
Mein Auto: 320i (F30)
This looks interesting.
What is the value of knowing coolant temperature versus oil temperature? I am not a skeptic because this is the most important gauge of the P3 to me.
Boost/vacuum is a substitute for a turbo gauge so that's fun.
Voltage is good to check the battery.
These are the top 3 uses I can see for me.
Old 07-25-2013, 01:37 AM
hans007 hans007 is offline
Mein Auto: 2013 328i m-sport EB2
does it come in other colors besides the red trim?
Old 07-25-2013, 05:22 AM
Dave 20T's Avatar
Moderator
The red trim is the car's, not the gauge. What you get is just the gauge. It's a option to get the gauge already installed into the vents so you can install it as one larger unit.
