Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great!
Old 07-12-2012, 09:00 AM
bmwBill001 bmwBill001 is offline
Mein Auto: tbd
What's Going on Here? - Conclusion
I got my car back yesterday. Per the SA, the codes indicated that the throttle motor which controls the opening and closing of the throttle valve was not working properly;
46301 throttle valve faults in throttle valve diagcode D1160-00000000_10_002
Parts replaced;
1 11-71-7-804-384 Throttle: 116015
1 13-54-7-792-098 O-ring: 138520
Milage in/out 46301/46305
All repairs N/C.
Anyone run into this issue with their 335D? As I will be going out of warranty in a month or so, should I have any concerns? Thanks for your comments.
Old 07-12-2012, 03:03 PM
Snipe656 Snipe656 is offline
Mein Auto: 2009 335d
I am only aware of one other person saying that part went bad on them. They had well over 100k miles. Get an extended warranty of it makes you feel more comfortable but I'd not make that parts failure weigh highly on the decision.
Curious if you asked of the extended warrant would even cover that part or what the cost would be out of warranty for the repair?
--Aaron
Old 07-12-2012, 03:33 PM
Mein Auto: tbd
I looked it up. The part cost $480 list. It was probably a 1000 dollar repair job at the dealer. maybe 700-800 at my independent shop. Never-the-less, I am not inclined to get an extended warranty. Since I drive over 35k miles per year, the warranty would cost me around $150 per month. I'm relying on the car to be reliable for hopefully the next 125k miles or so. If it's not, I'll get rid of it and get something else.
Old 07-12-2012, 06:43 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Your biggest risk is the auto transmission -- it is not that unusual for them to fail in BMW's at 100K or less... not common, but not at all unusual. And if it does, the only reliable repair is a re-manufactured one from BMW, as few, if any, independent shops have any expertise in rebuilding the autos used in BMWs.
Do a Google on BMW automatic transmission failures
Old 07-13-2012, 02:42 AM
Pierre Louis Pierre Louis is offline
Mein Auto: 2011 335d Sport
The 335d apparently has the more robust auto transmission that is also used in the big 7 series, not the one used in the other 3 series cars. My personal experience and preference is to change the transmission fluid earlier, especially if the color is no longer "pink" and use a full synthetic to the manufacturer's specs.
PL
Rose Castorini: I just want you to know no matter what you do, you're gonna die, just like everybody else.
Cosmo Castorini: Thank you, Rose. - Moonstruck
Old 07-13-2012, 05:20 AM
KeithS KeithS is offline
Mein Auto: '11 335d, '00 540iT
My understanding is the trans in the D is the same one that was used in the X5 4.8. Changing the fluid certainly helps for wear type failures, am planning on doing mine at about 90K while still under extended warranty (just in case).
But there are also metal fatigue failures that can occur. The cracked foward drum in our 540iT (142K miles) just cost me $5K to get fixed. Actually found an small independent shop that has been around 30+ years that rebuilt mine with a 3 year warranty. A chain shop such as Lee Miles or Aamco couldn't touch this.
Old 07-13-2012, 07:15 AM
Mein Auto: tbd
I am well aware that the D has the more robust ZF tranny. I changed my fluid at 35k miles.
Old 07-13-2012, 10:08 AM
There is a place stateside that specializes not only in rebuilding ZF transmissions but also modifying them to handle more power. I can't recall the name or location right now, I stumbled upon it when looking for a rebuild kit for an older ZF. I know here in Houston we have a place that specializes in ZF transmission parts but they do not do the rebuilds themselves.
--Aaron
Old 07-14-2012, 12:52 PM
BMWTurboDzl BMWTurboDzl is offline
Mein Auto: 335D
Yes. At 50k miles the car will being to self destruct. At that time I will buy it from your for $100.
Old 07-14-2012, 12:53 PM
Mein Auto: 335D
Actually the ZF 6HP is fairly robust.
Old 07-14-2012, 01:21 PM
Unless it goes through a CPO check then it magically becomes good for 100k miles.
--Aaron
HTML code is Off
